1.4 Anybody who uses 16 rims? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 14:57 | # 1 |
phaselispa |
This week I'm going to get into the wheel tire business. I think the following: I want to buy a 16 inch rim and wear a thin sidewall, a wide base tire. my question is Are there any tires among you? I am especially curious about the loss of performance. to what extent is it affected? how much the fuel situation changes. Is there a slight way for a rim in this way? |
| 08.05.2020 14:57 | # 2 |
I'm using 17. Road holding is increasing. fuel is increasing. Traction is falling and naturally slows down at acceleration. But the image looks good. My advice is. Do not think of a rim other than the 15 "206 gti or 206 cc (quiksilver) rim. The original rim is always better and stronger than the other choices. I think 1.4 hdi more than 15".
| 08.05.2020 14:57 | # 3 |
phaselispa |
I wish I could make a 16-point, 206-hdi, let me make the best decision. I don't know where to find the original rim in the bidet.
| 08.05.2020 14:57 | # 4 |
I think 16 wheels, but .. steel or cast material is definitely not recommended.
| 08.05.2020 14:57 | # 5 |
phaselispa |
I need to buy aluminum, both lighter
| 08.05.2020 14:57 | # 6 |
phaselispa |
Is Gökhan Bey your aluminum or steel?
| 08.05.2020 14:57 | # 7 |
[QUOTE = phaselispa] I wish I could make a 16-point 206 hdi, I will make the best decision. I don't know where to find the original rim in the bidet. [/ QUOTE] Otherwise, it is difficult to find these wheels. |
| 08.05.2020 14:57 | # 8 |
Of course the most beautiful and the healthiest aluminum .. I think someone else is a lie
| 08.05.2020 14:57 | # 9 |
There is also a benefit in research
| 08.05.2020 14:57 | # 10 |
[QUOTE = phaselispa] Gokhan Bey, is yours aluminum or steel? [/ QUOTE] Peugeot Original Steel rim. o Aluminum is the hair rims on vehicles I know. |
| 08.05.2020 14:57 | # 11 |
[QUOTE = GökhaN] [QUOTE = phaselispa] is your beyhan aluminum or steel? [/ QUOTE] Peugeot Original Steel rim. o Aluminum is the hair rims on vehicles I know. [/ QUOTE] No, brother, you're wrong. The sheet metal wheels on the vehicle are not called tin wheels aluminum. FE37 is the iron that you know ...: D is the alloy wheels, which is basically called the rim in its memory.
| 08.05.2020 14:57 | # 12 |
it is true that I am not interested in the raw material of the rims Otherwise, I changed the rim 5 times in my old 106, and the 206 rim became the second, except for the original rim.
| 08.05.2020 14:57 | # 13 |
I join the sky and think about fuel, traction and originality, and say gti or cc wheels.
| 08.05.2020 14:57 | # 14 |
Japon |
