1.4 206 xr me gti 15 gti rim |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 14:55 | # 1 |
| 08.05.2020 14:55 | # 2 |
[QUOTE = dukenukem82] Friends I think the gti rim to the car in summer, I can actually get it on the ourogan rim. I said let me ask you if I have a motor problem if it is strong. [/ QUOTE] There will be a fall in the traction. The 75 horsepower is the result, but do not make these rims so big. keep your gti rim on its way. |
| 08.05.2020 14:55 | # 3 |
If I play with the size of the tire, the traction would not drop, since the diameter does not change, I would throw the tire sidewall from 65 to 50, and the traction would remain normal. anyway thank you for the answer |
| 08.05.2020 14:55 | # 4 |
Onur |
[QUOTE = dukenukem82] If I play with the size of the tire, the traction does not fall, the diameter does not change, so I throw the tire sidewall from 65 to 50 if the traction remains normal. anyway thank you for the answer |
| 08.05.2020 14:55 | # 5 |
[QUOTE = Honor] [QUOTE = dukenukem82] If I play with the tire size, the traction does not drop, the diameter does not change, so I throw the tire sidewall from 50 to 50 if the traction remains normal. anyway thank you for the answer you have marketed 206 look rims ![]() |
| 08.05.2020 14:55 | # 6 |
I don't like the type of that rim even though it is from my avatar :). I will buy ouragan if he eats the engine, but he will not lift it.
| 08.05.2020 14:55 | # 7 |
You can use ideal with 185-55-15 tires ...
| 08.05.2020 14:55 | # 8 |
I guess the original tire should be 175-65-14. the exact balance in this tire is 185-55-15. |
| 08.05.2020 14:55 | # 9 |
yeah i think 50 or 55 cheeks gti rim really cut out for 206, it would be better to be 55 of course because of the roads known |
| 08.05.2020 14:55 | # 10 |
You shouldn't use it differently than I said. I think 50 does not matter ... it actually happens but the car gets harder, the rim tire malfunctions are more and the ten teams are broken more quickly, and with the car's face indicator, it starts to show more in the meter.
| 08.05.2020 14:55 | # 11 |
Thank you for the info. If I make 50, it will be like these hawks say we are reducing the wheel diameter and making 200 km. |
| 08.05.2020 14:55 | # 12 |
If you use the tire cap, the face decreases, but the speed increases ... there is no need to make 200 u on the straight road :)) and with a small tire, there is no need :) We saw the ramp down 190 km with the slx of your friend. but I wasn't using it ... and at that moment I decided not to overlap the bird series. Because I was feeling lightly like a bird ... |
| 08.05.2020 14:55 | # 13 |
I do not call it a hawk, but you are very belittling of the SLX 195 * 15 * 55 tire and rim, I saw 215km on the Istanbul highway very comfortably, my father came with me 407 and my speed was approved, a situation related to the engine of the vehicle, the vehicle I was talking about, 1993 model slx 26 rs 587 plate. There was only a valve grinding and playing with valves.
| 08.05.2020 14:55 | # 14 |
If you use the [QUOTE = cecoli] tire cap, the face will decrease but the stiffness will increase ... there is no need to make 200 u on the straight road :)) and with a small tire, there is no need :)))) We saw the ramp down 190 km with the slx of your friend. but I wasn't using it ... and at that moment I decided not to overlap the bird series. Because I was feeling lightly like a bird ... [/ QUOTE] dude also because they have simple system engines, a series of birds that have been mastered by a USTA-like biker will not make you feel like a bird when the augers of the car are cut and lowered to the ground.
| 08.05.2020 14:55 | # 15 |
I did 195 too in a short distance with the falcon, but here is the human trust I was in my car was 13 cms or something, here is my classic hawker's car |
| 08.05.2020 14:55 | # 16 |
[QUOTE = dukenukem82] either I did 195 with the hawk in a short distance but here is the person I can not trust my car was in my car 13 cm |
| 08.05.2020 14:55 | # 17 |
I have 206 Roland Garros. it has 206 look rims. I want rc wheels too. If we want to summer, we can talk like March-April. Then I can change it, I guess.
| 08.05.2020 14:55 | # 18 |
tigerland |
[QUOTE = 26NT023] friends do not call it a hawk but you are very belittling the slx 195 * 15 * 55 tire and rim I saw 215km on the highway in Istanbul very easily with me, my father was coming with 407, my speed was also confirmed, a vehicle related to the engine of the vehicle I was talking about 1993 model born slx At 26 rs 587, the plate has only grinding cover and playing with valves, the engine had no other operation. [/ QUOTE] There is a possibility to do 190-200 kmh without playing, if it is a well-maintained vehicle, it has 1.6 engine, it makes 190 if it is late but after the process you say, it makes 210 in 75 hp vehicles :)
| 08.05.2020 14:55 | # 19 |
[QUOTE = tigerland] [QUOTE = 26NT023] friends do not call it a falcon but you are very belittling the slx 195 * 15 * 55 tire and rim I saw 215km on the Istanbul highway very easily, my father was coming with me and my speed was approved about the engine of the vehicle. The vehicle was born in 1993 model slx 26 rs 587, the plate only has grinding cover and playing with valves, the engine had no other operation. [/ QUOTE] It is possible to do 190-200 kmh without playing, if it is a well-maintained vehicle, it has 1.6 engine, it makes 190 if it is late but it does 210 in 75 hp vehicles after the process you said. It didn't take long, my father grew longer :)
