1.2-click sound
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:21 # 1
Tuna0618
Good evening with the sentence. I have a 2012 model 1.6 HDI ALLURE 301 im. For about 4 months there has been a popping sound at the front of the right front and gas intersection. In other words, when I put it in 1st gear, I get the click sound when it gets up. I throw it in traffic, I press the gas in the vehicle gear, I pull my foot off the gas, there is a sound like click I had many things checked, shock absorber, front gear, wedges, etc. But I can't find the sound. Rather, something has been displaced, it gives a sound like hitting the chassis as the engine flexes in the first and second gear transitions. The sound comes from the right. Anybody happened to you? Or what solution would you suggest, guys?
Strange thing is, it sounds a few days. Then suddenly it does not stop. And my impression is that when we lift the car on a jack or fiber, the sound goes away. So something seems to be sitting in place and the sound is muted. 2. While driving in gear, suddenly there is a clicking sound. As if something had been displaced. Then this voice starts to come and repeats like this
Tuna0618 2019-11-14 20:51:21
08.05.2020 21:21 # 2
omerb
hello sound event is a little troubled. It didn't happen to me, but I may have some advice like this. Go to an exhaust mechanic. They have tunnel-shaped places. You can hear the sound as you slowly move the vehicle over it. When you take it to the lift, the engine gets on the ears of the engine completely, the shock absorbers get on the chocks so you don't hear the sound. You have to find your solution in the exhaust tunnel.
08.05.2020 21:21 # 3
Tuna0618
On Saturday I will put the car in the channel and look at it, and I think it might be something that has been overlooked because I will remove the engine lower casing. There are also brake records, the metal brake fluid tube comes to the wheels from the edge of that chassis, and any metal holding it is broken, it may come in and out of the way and then crash into the chassis?
08.05.2020 21:21 # 4
omerb
anything can happen. Remove the casing. You will most likely solve the problem
08.05.2020 21:21 # 5
Tuna0618
If somewhere is broken, the sound continues without interruption, no sound occasionally. I am sure it is a very simple problem, but it annoys one's nerves
27.11.2020 12:18 # 6
XPerience
[QUOTE = Tuna0618] Good evening in a sentence. 2012 model 1.6 HDI ALLURE 301 I have. For about 4 months, there has been a chirp at the front of the right and at the gas intersection. So I put on the 1st gear, when I get up, there is a click. I'm throwing, I'm in traffic, I'm pushing the accelerator in the car gear, I'm pulling my foot off the gas. I had many things checked, such as the shock absorber, the front gear, the wedges, etc. I personally worked hard and looked over and over again. But I can't find the sound. When something is more out of place, it gives a sound like hitting the chassis as the engine flexes during the first and second gear shifts. Sound is coming from the right. Has anyone happened to it? Or what kind of solution do you suggest, friends? The odd thing is that it sounds like a few days. Then suddenly it does not come. And my impression is that when we lift the car on the jack or the lift, the sound goes away. So something fits into place and the sound seems to be dropping. While cruising in 2nd gear, there is a sudden click sound. As if something was knocked out. Then it starts to sound and keeps repeating like this [/ QUOTE] Hi, have you solved the problem? I have the exact same problem on the right, but I think I have at the back. It sounded like it might be related to the shock absorber mounts. If it is resolved, please can you give me information.
27.11.2020 21:35 # 7
Tuna0618
Hello, Unfortunately I could not solve the problem, but I had many masters checked it. Even the body shop looked, let me tell you that:) All I know is a chronic 301 problem. There were many people who bought zero from the dealer and came just for this problem. If you ask whether it is resolved, unfortunately. It was not resolved for me either. The sound continued to come on at regular intervals, disappeared for a while, then came back. I spent a lot of money for that sound, wedges, shock absorbers etc. I guess the only thing I can think of is the sound of a metal part hitting the chassis or another metal part with the flexing movement of the motor. And I could not stand it anymore, I decided to sell my car. It was successful whether it was going or fuel, but I could not be satisfied in terms of quality. But I did not give up on the peugeot again and bought the 207 1.4 hdi premium :) Except for the crackles coming from the small trim, there is no noise from the engine undercarriage and the walker. My advice is to ignore that sound, I tried really hard, but we couldn't find the source of the sound. Different masters different services .. only your money goes.
