0997 engine fuse box sound warning system
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
26.02.2021 20:18 # 1
KAHOMEN
Friends, I wish you all good night?
My vehicle Peugeot Partner Tepee Zenith 1.6 BlueHDI 120HP S & amp; S. The 2018 model is for traffic in January 2019. This morning the vehicle has reported a 0997 engine fuse box audio warning system failure. The computer showed it like this. It actually gave 2 malfunctions. 1.0997 engine fuse box audio warning system. Horn 2 (Horn is working). All insurances have been checked. None of them exploded, all intact. In the error code is not deleted from the computer. I would appreciate it if you could help.
Thank you.
01.03.2021 09:13 # 2
sonerkyl
Hello teacher, I think the new model of the vehicle, I recommend you to have a qualified service look. If the warranty has not expired, such malfunctions may be caused by the battery. I say don't deal in private, right and left. They can make the car worse.
03.03.2021 11:33 # 3
KAHOMEN
Today I went to Büyükçekmece Çetaş Peugeot authorized service. They said that neither today nor tomorrow is an empty hour for maintenance. They made an appointment at 10:00 in the morning on Friday. He said that they would connect the vehicle to the fault detection device, it takes about 3 hours or so. He said it could be a very minor malfunction or a major malfunction. Let's see what will happen. It was very odd that the fault lamp could not be fixed although it was connected to the computer outside.
The vehicle does not fall off traction.
No problem with the headlights.
None of the headlights are wrong.
No problem with shifting.
There is no problem with the air conditioner, the heater.
With digital displays, no problem.
Parking sensors are OK with not wearing seat belts.
No problem with the rear view camera.
No problem with fuses. There is no problem with the doors, interior ventilation system.
No no no no.
I don't understand, it's gone. Ouch C &# 111; nfused
12.05.2022 07:56 # 4
emresahin55
Did you get results?
