08.05.2020 18:08 # 1
awanger33
I was unable to start an automatic headlight on my pewgout 307 vehicle, it used to conflict before, but awanger33 2014-03-20 10:15:58
08.05.2020 18:08 # 2
When the key is in the second position (battery on) the headlights are on the same button as the key of the trip computer. Press and hold until you hear text and sound on the screen that will hurt. dogancanguden 2013-12-10 12:00:06
08.05.2020 18:08 # 3
awanger33
teacher, I have not tried Confused
yesterday, the battery ran out, we removed the head, it didn't work after that, there is no problem in the wipers but
08.05.2020 18:08 # 4
Serkan
When the key is in the first position, try it when the teacher is not in the second position, turn the ignition to one level, press the button on the end of the signal lever until it sounds.
08.05.2020 18:08 # 5
That was what I meant to say :) Only the battery light will be on the panel, the battery will be on. from dogancangu 2013-12-10 17:41:26
08.05.2020 18:08 # 6
awanger33
THANK YOU IT WORKED WORKED
