08.05.2020 17:44 # 1
hLL
hll 2013-07-07 23:43:19
08.05.2020 17:44 # 2
samet206
There are stop paints, they paint with them similar to spray paint, but the paint can take both originality and spill. Also, I do not enter sandpaper paint or something.
08.05.2020 17:44 # 3
Gokhan Cetin
To be able to do it with paint should be experienced, I think the best is foil whenever you want.
08.05.2020 17:44 # 4
error
I guess it's not a movie, it's like a colored varnish.
08.05.2020 17:44 # 5
hLL
I think the foil is the best option. It can be removed when it is tight.
08.05.2020 17:44 # 6
aknard
foil will be the right choice. You can lose the stop as a result of painting :)
08.05.2020 17:44 # 7
usasd
I have an angel in the headlights but I did not dimming, would it be as good as dimming if I made foil?
08.05.2020 17:44 # 8
hLL
[QUOTE = usasd] my headlights have angel but I did not dimming, would it be as good as dimming if I made foil
Sample.
08.05.2020 17:44 # 9
usasd
[QUOTE = hLL] [QUOTE = usasd] my headlights have angel but I did not make dimming, would it be as good as dimming if I made foil
Sample.
I think angel is effective during the day, so brother
08.05.2020 17:44 # 10
opasno
There are stop paints, yes, but when you make it out of the paint, there is no problem if you paint it in the air in the air with water, and there is no problem when you notice it from the foil. ...
08.05.2020 17:44 # 11
hLL
[QUOTE = usasd] [QUOTE = hLL] [QUOTE = usasd] my headlights have an angel but I did not darken it would be as good as blackout if I made foil
Sample.
The car is not mine. I put it as an example. What do you mean by effect? I don't think it will prevent night vision. which is never a day
hll 2013-06-29 09:34:18
08.05.2020 17:44 # 12
tigerland
I think it's not a nice app, signal reversing etc. All the same color is burning .. On the way to the driver and trouble for you.
08.05.2020 17:45 # 13
tlp
Hop it's not my car, baby :))
Headlight foil light rents, has little effect at night
I did it because I don't have a certain kind of memory I know the way
Normally I bought this foil for the rear stops
The right stop was over-deformed I would do it to close it
Then I looked at you without them
His stance remained because I like it
Hee, if you have ten films on the window, your opinion
08.05.2020 17:45 # 14
usasd
[QUOTE = tlp] Hop it's not my car, baby :))
Hee, if you have ten films on the window, you can see 1 times more duser information [/ QUOTE]
I have an angel, it is not clear when I open it in the daytime.
08.05.2020 17:45 # 15
usasd
[QUOTE = hLL] [QUOTE = usasd] [QUOTE = hLL] [QUOTE = usasd] my headlights have angel but I did not dimming, would it be as good as dimming if I made foil
Sample.
During the day, angel is obvious, there is no blackout.
