08.05.2020 17:44 # 1
hLL
hll 2013-07-07 23:44:27
08.05.2020 17:44 # 2
Mustafa-almanya
Get well soon, bro, you will get it done cheaply.
08.05.2020 17:44 # 3
hLL
I added the photos.
the @onurazg
I'm going to add the missing oil, but enough to be done. Thanks.
@ Mustafa Germany
I hope brother. I don't want to spend any more money on the car. Thanks.
08.05.2020 17:44 # 4
hLL
Also this oil; Is it 75w80?
08.05.2020 17:44 # 5
Zagorka
Get well, the problem may be from kater Wink Zagorka 2013-06-26 20:40:45
08.05.2020 17:44 # 6
samet206
Get well soon ...
08.05.2020 17:44 # 7
hLL
[QUOTE = Zagorka] Get well, the problem may be from kater Wink [/ QUOTE]
Thank you mate. I was coming right this weekend Confused He's done it in a way. I hope that I will not have to take it by check until the oil runs out until I find the opportunity and take it to the service.
08.05.2020 17:44 # 8
qqyyxx
is missing from the axle times, made here for 20 TL. In addition, the oil will flow during the change.
08.05.2020 17:44 # 9
hLL
[QUOTE = qqyyxx] is missing from the axle times, where it is made for 20 TL. In addition, the oil will flow during the change and its liter is around 25 [/ QUOTE]
Hopefully, as you said, there is no extra expense from the axle seal. I will drain the oil completely and put it on new. Just let them handle this leak.
I know the capacity of the gearbox is 2 liters. I looked around 20 liters. Total brand. As I said, the oil is easy to handle the leak Sleepy
08.05.2020 17:44 # 10
Zagorka
You come to chate 1 - 2 Let's talk to you Tongue
08.05.2020 17:44 # 11
hLL
Current.
08.05.2020 17:44 # 12
SDYMZ
my teacher misses from love felt, I changed it 20tl but the gearbox is completely down workmanship 200 tl oil 2lt room 40tl bidet shaft seal has room 17tl cost me
08.05.2020 17:44 # 13
qqyyxx
[QUOTE = SDYMZ] my teacher misses from love felt I changed it 20tl but the gearbox is completely down workmanship 200 tl oil 2lt room 40tl bidet shaft seal has cost me 17tl
A gearbox was taken to replace the axle seal. If it does not happen, it is for robbery purposes or there is another problem.
08.05.2020 17:44 # 14
hLL
Sir, I understood the oil, okay, should the big transmission go down to install 20 lira materials ???? Workmanship came to me. I made an appointment for Monday. I pulled the battery and put it in the closed garage. He will sleep until Monday.
08.05.2020 17:44 # 15
hLL
[QUOTE = qqyyxx] [QUOTE = SDYMZ] my kid is missing from the love felt, I changed it, 20tl but the gearbox is completely down workmanship 200 tl oil 2lt room 40tl bidet shaft seal has cost me 17tl
I hope that as you say, the transmission will not be taken down completely. In case there is a problem other than extra. As you said, you need to be vigilant against cunning mechanics.
08.05.2020 17:44 # 16
hLL
The Yohar!
hll 2013-06-27 23:44:40
08.05.2020 17:44 # 17
hLL
Any other idea? I don't want to wait for Monday. I want to have it done if I find another master tomorrow. Very spoiled here, masters. If I was in TR, the repair was over the same day. Can't they just finish a job?
08.05.2020 17:44 # 18
hLL
hll 2013-07-07 23:44:43
08.05.2020 17:44 # 19
Serkan
Get well, Halil, you got it done.
08.05.2020 17:44 # 20
hLL
[QUOTE = Serkan] Get well done, Halil, you got it done with the specialist [/ QUOTE]
The gearbox would have scared me, and the comments were scared, but it was just as cheap :) Thanks a lot.
Page : / 2
