08.05.2020 17:08 # 1
dRhkn
can be deleted dRhkn 2013-01-31 12:31:21
08.05.2020 17:08 # 2
phoenix.1905
If there is a problem in the swings, the rod does not keep the adjustment. It gets old again .. & nbsp;
08.05.2020 17:08 # 3
Serkan
As the friend says, the rot balancer does not usually adjust, even if the rot balancer does not adjust, change the following points, it is not a big expense on the swing, if I am not mistaken, the equivalent part is about 60 TL, you give it to work at 30-40 TL, I have changed it 3 years ago.
08.05.2020 17:08 # 4
bilici04
you also finish the tires, and maintenance is not necessary.
08.05.2020 17:08 # 5
dRhkn
I went today, I made rot balance, as I thought, I did not offer anything, I built standard. This is the state of the car that has cooled down from life.
08.05.2020 17:08 # 6
MagicPerformance
your expenses are not big, go to the mechanical chassis.
08.05.2020 17:08 # 7
dRhkn
[QUOTE = umutrizaergen] your expense is not big, go to the mechanical chassis. [/ QUOTE]
I couldn't tell you what you said, sir, to the nation. I don't know who would worry. I was nervous about the narratives as if there was a huge job. they even seem to escape from work ...
