08.05.2020 17:06 # 1
dRhkn
can be deleted < / font>
dRhkn 2013-01-31 12:31:57
08.05.2020 17:06 # 2
sezar206
It is most likely that the chassis of the hit side has slipped. My father had an old van too, I know from there. The car was turning very easily to the right as the right wheel was behind, left & nbsp; it could turn at a wider angle.
& nbsp;
As for the trip computer & nbsp; One of the bulbs behind it exploded, you don't need to change it. The right side of the screen had darkened in me. An electrician in Eskisehir immediately put two bulbs behind him & nbsp; The problem is solved.
08.05.2020 17:06 # 3
I know that if the chassis slipped, it would be difficult to adjust You must find a good master in this regard.
08.05.2020 17:06 # 4
dRhkn
hmm the trouble is so great ....
08.05.2020 17:06 # 5
MagicPerformance
It is not a problem that it is slipped back and mechanical chassis performs in 1 hour.
08.05.2020 17:06 # 6
dRhkn
[QUOTE = umutrizaergen] It is not a problem that it slipped back and mechanical chassis work in 1 hour. [/ QUOTE]
I'm confused now but ..
08.05.2020 17:06 # 7
MagicPerformance
nothing to confuse you will go to the mechanical chassis you will play for 2 hours max. Money at 200 TL & nbsp; You will give your job will be solved :)
08.05.2020 17:06 # 8
dRhkn
[QUOTE = umutrizaergen] nothing to confuse you will go to the mechanical chassis you will play for 2 hours max. Money at 200 TL & nbsp; You will give your job to be solved :) [/ QUOTE]
I will be interested after the feast, I hope. :)
08.05.2020 17:06 # 9
sezar206
there is no problem to do
08.05.2020 17:06 # 10
mev347
I have the same problem with me. At first, I said my tire is thin but not. I don't have anything like swiping & nbsp;
