Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:03 # 1
awanger33
HELLO
I PARTICIPATED WITH YOU NEW !!!
ALFA ROMEO 147 AFTER MY VEHICLE 2005 307 SW OTM I RECEIVED MY VEHICLE FRIDAY: D
I WANT TO INSTALL THE SOUND SYSTEM FROM MY PREVIOUS VEHICLE
I WANT THE LUGGAGE VOLUME WIDE STAY THAT IS THE ONLY REASON WHEN I CHANGE THE VEHICLE !!!
WHAT ARE YOUR RECOMMENDATIONS FOR THIS VEHICLE
I HAVE 1 ANFI AND 2 38 CM WOFER IN HAND: D
awanger33 2014-03-20 10:18:35
08.05.2020 18:03 # 2
samet206
Welcome, Good luck forums in your vehicle ... I can not comment on the systems, more knowledgeable friends will help you.
08.05.2020 18:03 # 3
awanger33
I think nobody has any idea?
08.05.2020 18:03 # 4
awanger33
thank you for your good wishes.
of course my priority is to use what I have, but there may be a new system, of course.
but I am looking for something that will appeal to our ears that will be elegant to the eye.
I even saw one, there was a work in the form of a spare tire,
08.05.2020 18:03 # 5
qqyyxx
Unfortunately the door speaker loudspeaker of 307 is bad. It was not so efficient to put on a mid-team that could feed with its amp, I tried to produce only the speakers in the solution with 2-way speakers and active woofer reinforcement in the trunk without changing the original tape in my 307 vehicle. With the loudspeaker in the tape and the trunk in the trunk, you can solve the heat with a single voofer. May your vehicle be good.
