 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Rolantide sarsıntı</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Rolantide sarsıntı]]></description>
  <pubDate>Sat, 02 May 2026 23:46:24 +0000</pubDate>
  <lastBuildDate>Tue, 06 Jul 2010 11:55:30 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=9847</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Rolantide sarsıntı : sen&#246;r veya gaz kelebegindeki kirlenme...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=140558&amp;title=rolantide-sarsinti#140558</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1791">BurçUMUL</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Temmuz&nbsp;2010 Saat 11:55<br /><br />senör veya gaz kelebegindeki kirlenme neden&nbsp;olabilir . ]]>
   </description>
   <pubDate>Tue, 06 Jul 2010 11:55:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=140558&amp;title=rolantide-sarsinti#140558</guid>
  </item>
  <item>
   <title><![CDATA[Rolantide sarsıntı :   BuR&#199;aK Yazd&#305;:LPG de bu durumun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=140552&amp;title=rolantide-sarsinti#140552</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Temmuz&nbsp;2010 Saat 10:19<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: BuRÇaK" alt="Orjinalini yazan: BuRÇaK" style="vertical-align: text-bottom;" /> <strong>BuRÇaK Yazdı:</strong><br /><br />LPG de bu durumun normal olduğunu biliyorum ama LPG deki rolanti ayarına LPG kitinizin servisinde baktırmanızı ve bilgisayara bağlatmanızı tavsiye ederim. Eski aracımda bendeki sorun böyle çözülmüştü.</td></tr></table> <DIV>&nbsp;</DIV><DIV>kusura bakma ama&nbsp;"LPG de bu durum normal" cumlene katılmıyorum. duzgun uygulanmıs lpg sıstemınde benzınden hıcbırsekılde fark olmaz. lpg de sarsıntılı calısır dıye bır kaıde yok. eger bu sekılde bır durum varsa sıstemde sıkıntı var demektır. cozulebılır ve cozulmesı gerekır. herkesın bıldıgının aksıne lpg de arac daha yumusak calısıyor. bu durum lpg oktanının benzıne gore daha yuksek&nbsp;olmasından&nbsp;ılerı gelıyor.</DIV>]]>
   </description>
   <pubDate>Tue, 06 Jul 2010 10:19:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=140552&amp;title=rolantide-sarsinti#140552</guid>
  </item>
  <item>
   <title><![CDATA[Rolantide sarsıntı : oksijen sens&#246;r&#252;ndendir, arkadas&#305;m&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139835&amp;title=rolantide-sarsinti#139835</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2739">okankrgz</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Temmuz&nbsp;2010 Saat 08:13<br /><br />oksijen sensöründendir, arkadasımın 206 sında da aynı sorun vardı, beynin sensörü bir algılayıp bi algılamamasından kaynaklanıyor.]]>
   </description>
   <pubDate>Sat, 03 Jul 2010 08:13:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139835&amp;title=rolantide-sarsinti#139835</guid>
  </item>
  <item>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139825&amp;title=rolantide-sarsinti#139825</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2544">mhakan71</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Temmuz&nbsp;2010 Saat 01:10<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: BuRÇaK" alt="Orjinalini yazan: BuRÇaK" style="vertical-align: text-bottom;" /> <strong>BuRÇaK Yazdı:</strong><br /><br />LPG de bu durumun normal olduğunu biliyorum ama LPG deki rolanti ayarına LPG kitinizin servisinde baktırmanızı ve bilgisayara bağlatmanızı tavsiye ederim. Eski aracımda bendeki sorun böyle çözülmüştü.</td></tr></table><br><br><br>lpg rolanti ayarınada bakıldı herşey normal<br>]]>
   </description>
   <pubDate>Sat, 03 Jul 2010 01:10:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139825&amp;title=rolantide-sarsinti#139825</guid>
  </item>
  <item>
   <title><![CDATA[Rolantide sarsıntı : LPG de bu durumun normal oldu&#287;unu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139822&amp;title=rolantide-sarsinti#139822</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2626">BuRÇaK</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Temmuz&nbsp;2010 Saat 01:06<br /><br />LPG de bu durumun normal olduğunu biliyorum ama LPG deki rolanti ayarına LPG kitinizin servisinde baktırmanızı ve bilgisayara bağlatmanızı tavsiye ederim. Eski aracımda bendeki sorun böyle çözülmüştü.]]>
   </description>
   <pubDate>Sat, 03 Jul 2010 01:06:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139822&amp;title=rolantide-sarsinti#139822</guid>
  </item>
  <item>
   <title><![CDATA[Rolantide sarsıntı : 2002 307 xr 1,6 110 hp (lpg+benzin)...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139816&amp;title=rolantide-sarsinti#139816</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2544">mhakan71</a><br /><strong>Konu:</strong> 9847<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Temmuz&nbsp;2010 Saat 00:26<br /><br />2002 307 xr 1,6 110 hp (lpg+benzin) kullanıyorum araç rolantide iken (benzinde veya lpg de farketmiyor) hafif ara ara bir sarsıntı var içeriden hissediliyor, rolanti devir sayacında bir oynama yok normal,<br><br>çok usta gezdim ankarada;<br><br>Kimi motor kulağı dedi<br>kimi hava emiş kirli dedi<br>kimi triger sente atmış olabilir dedi (değişeli 5000 km oldu)<br>bujiden dediler (4 yeni buji taktım)<br><br>kısacası kimse anlamıyor herkes usta olmuş, pc ye bağlayıncada bir arıza vermiyor<br>motor yazılımını yenilediler yine düzelmedi<br><br>yardım ve görüşlerinizi bekliyorum<br><br>saygılarımla<br>]]>
   </description>
   <pubDate>Sat, 03 Jul 2010 00:26:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9847&amp;PID=139816&amp;title=rolantide-sarsinti#139816</guid>
  </item>
 </channel>
</rss>
