 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 407 Titreme</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : 407 Titreme]]></description>
  <pubDate>Mon, 04 May 2026 11:21:59 +0000</pubDate>
  <lastBuildDate>Wed, 09 Jun 2010 12:05:22 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=9509</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[407 Titreme : evet do&#287;ru diyorsunuz yorumlar&#305;n&#305;z...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=136314&amp;title=407-titreme#136314</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Haziran&nbsp;2010 Saat 12:05<br /><br />evet doğru diyorsunuz yorumlarınız için tşk ederim arkadaşlar]]>
   </description>
   <pubDate>Wed, 09 Jun 2010 12:05:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=136314&amp;title=407-titreme#136314</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : bence de bunlar&#305;n hepsi normal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135892&amp;title=407-titreme#135892</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2586">sdurmus61</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Haziran&nbsp;2010 Saat 10:16<br /><br />bence de bunların hepsi normal aynısı bende de var ama gaza basmadan araç kaldırırken araçta tabiki titreme olur bunları büyütmeyin derim ben ]]>
   </description>
   <pubDate>Mon, 07 Jun 2010 10:16:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135892&amp;title=407-titreme#135892</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : benim arac&#305;n volant&#305; &#231;ift yayl&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135813&amp;title=407-titreme#135813</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Haziran&nbsp;2010 Saat 20:51<br /><br />benim aracın volantı çift yaylı volantmış tamiri olmuyormuş]]>
   </description>
   <pubDate>Sun, 06 Jun 2010 20:51:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135813&amp;title=407-titreme#135813</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : Bu titreme normal bir durum say&#305;l&#305;r.Ayn&#305;s&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135790&amp;title=407-titreme#135790</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18">İsmailAteş</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Haziran&nbsp;2010 Saat 17:48<br /><br />Bu titreme normal bir durum sayılır.Aynısını bendeki 307'de de yapıyor.Sebebi ise volant.Baskı balata değişiminden sonra volantı torna ettirmediğim için bu şekilde kullanıyorum.Herhangi bir sıkıntı çıkarmıyor şuan ilerde de çıkaracağını sanmıyorum.<div>Takmamaya ve mümkün olduğunca devirli kalkmaya bakın derim.</div>]]>
   </description>
   <pubDate>Sun, 06 Jun 2010 17:48:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135790&amp;title=407-titreme#135790</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : otomatik peugeotlar&#305;n dizel modellerinin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135779&amp;title=407-titreme#135779</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Haziran&nbsp;2010 Saat 16:01<br /><br />otomatik peugeotların dizel modellerinin huyu sanırım bu gazla kalkacaz artık ya da takmıyacağız ]]>
   </description>
   <pubDate>Sun, 06 Jun 2010 16:01:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135779&amp;title=407-titreme#135779</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : benim eski ford arac&#305;mda da olurdu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135695&amp;title=407-titreme#135695</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3254">BAHTİYAR</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 21:05<br /><br /><P><FONT style=": #9cb9e1">benim eski ford aracımda da olurdu duruken biraz erken boşa atın vitesde titrme normal aracı çok az gazla veya rolanti ile kaldırmak zararlı bir durum araç üst kapak vb yağ bulanan yerlerden yağ atar +pistonlar la iligili bi uzantısı daha var tam hatırlamıyorum&nbsp;hatırladığım kadarı ile&nbsp;piston duvarlara baskı mı ne yapıyormuş titreme ondan saygılar</FONT></P>]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 21:05:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135695&amp;title=407-titreme#135695</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : merhaba arkada&#351;lar benim de buna...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135681&amp;title=407-titreme#135681</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 19:56<br /><br />merhaba arkadaşlar benim de buna benzer sıkıntım var aracımı 1. viteste kaldırırken eğer gaz pedalına basmassam araçta titreme oluyor ama gaza biraz basınca bu titreme kesiliyor aracı çok tamirciye gösterdim debriyajını herkes debriyaj normal dedi ilk defa dizel kullanıyorum acaba benzinli ile dizel arasında kalkışta fark oluyormu titremede dizel biraz daha gaza basarakmı kaldırmak lazım ]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 19:56:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135681&amp;title=407-titreme#135681</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : evet do&#287;ru diyorsun takmamak daha...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135672&amp;title=407-titreme#135672</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 18:20<br /><br />evet doğru diyorsun takmamak daha iyi. evet gt line bilgilerini paylaştığın için tşk ederim:D]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 18:20:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135672&amp;title=407-titreme#135672</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : &#351;irkette 1.6 hdi 407 kullan&#305;yordum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135590&amp;title=407-titreme#135590</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3131">can32</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 00:10<br /><br />şirkette 1.6 hdi 407 kullanıyordum onda az bşy vardı, verdim şimdi yine 1.6 hdi c5 kullanıyorum onda da aynı miktarda var, herşeyleri aynı bunların motorda zaten. seninde dediğin gibi hepsinde olabilir belki. inşallah ilk ve son sıkıntın olur servislerle uğraşmazsın. bence bi sıkıntı yoktur kafana takma derim. hayırlı sürüşler. araç GT LINE sanırım altta öle yazıor, 163bg in tadını çıkar :D]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 00:10:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135590&amp;title=407-titreme#135590</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : evet &#246;yle bir &#351;ey olabilir ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135589&amp;title=407-titreme#135589</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 00:05<br /><br />evet öyle bir şey olabilir ama sanırım bu peugeotlarda dizel otoların huyu . rahatsız etmiyor zaten ama passat da olmayınca ben taktım biraz:D]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 00:05:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135589&amp;title=407-titreme#135589</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : bi test arac&#305; kullanmay&#305; talep...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135587&amp;title=407-titreme#135587</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3131">can32</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Haziran&nbsp;2010 Saat 00:02<br /><br />bi test aracı kullanmayı talep edebilirsin, aynı şey onda varmı kıyaslarsın. belki karar vermene yardım eder.]]>
   </description>
   <pubDate>Sat, 05 Jun 2010 00:02:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135587&amp;title=407-titreme#135587</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : yok o kadar de&#287;il ama biraz daha...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135581&amp;title=407-titreme#135581</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2010 Saat 23:54<br /><br />yok o kadar değil ama biraz daha takip edicem araç ilk geldiği günden beri dikkatimi çekiyor haydi bakalım hayırlısı 2. peugeot da servisle kardeş olmasın diye her gün dua ediyorum :D]]>
   </description>
   <pubDate>Fri, 04 Jun 2010 23:54:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135581&amp;title=407-titreme#135581</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : akl&#305;ma benzilen dizele ge&#231;tinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135579&amp;title=407-titreme#135579</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3131">can32</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2010 Saat 23:51<br /><br />aklıma benzilen dizele geçtinde yadırgadınmı die bi soru geldi ondan sordum. yani kalkışta çok hafif bi titreme yapıyordu bnm kullandıklarım ancak ben dizelliğine veriyordum. bir arıza boyutunda bir titreme ise eğer belki baskı balatada sıkıntı olabilir. benim 307im de 7000km de baskı balata değişmişti fabrikasyon bi hatayı. garantiden yaptılar. çok rahatsız ediyorsa servise bi göster derim garantideyken.]]>
   </description>
   <pubDate>Fri, 04 Jun 2010 23:51:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135579&amp;title=407-titreme#135579</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : evet ikiside turbo dizeldi ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135577&amp;title=407-titreme#135577</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2010 Saat 23:46<br /><br />evet ikiside turbo dizeldi]]>
   </description>
   <pubDate>Fri, 04 Jun 2010 23:46:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135577&amp;title=407-titreme#135577</guid>
  </item>
  <item>
   <title><![CDATA[407 Titreme : daha &#246;nce kulland&#305;&#287;&#305;n ara&#231;ta dizelmiydi????...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135576&amp;title=407-titreme#135576</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3131">can32</a><br /><strong>Konu:</strong> 9509<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2010 Saat 23:44<br /><br />daha önce kullandığın araçta dizelmiydi????]]>
   </description>
   <pubDate>Fri, 04 Jun 2010 23:44:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9509&amp;PID=135576&amp;title=407-titreme#135576</guid>
  </item>
 </channel>
</rss>
