 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 407 motoru</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : 407 motoru]]></description>
  <pubDate>Sun, 03 May 2026 00:47:11 +0000</pubDate>
  <lastBuildDate>Tue, 11 May 2010 16:30:36 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=9171</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[407 motoru : evet evet 4 silindir ama onlar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131413&amp;title=407-motoru#131413</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Mayıs&nbsp;2010 Saat 16:30<br /><br />evet evet 4 silindir ama onlar 184 hp tşkler yorumlarınız için ellerinze sağlık:D]]>
   </description>
   <pubDate>Tue, 11 May 2010 16:30:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131413&amp;title=407-motoru#131413</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru :   saw50 Yazd&#305;:bu arada bmw nin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131328&amp;title=407-motoru#131328</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1526">H-a-d-i</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Mayıs&nbsp;2010 Saat 00:00<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: saw50" alt="Orjinalini yazan: saw50" style="vertical-align: text-bottom;" /> <strong>saw50 Yazdı:</strong><br /><br />bu arada bmw nin 5.20 modelleri 4 silindirmiş.. bmwnın kendi sitesinden baktım</td></tr></table> <br /><br />haklısınız...1996-2007 model BMW 520'lerin 6 silindir olduğuna eminim. ama 2008 den sonra 4 silindir üretildi diye biliyorum.]]>
   </description>
   <pubDate>Tue, 11 May 2010 00:00:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131328&amp;title=407-motoru#131328</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : hadi abinin de dedigi gbi peugeot...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131299&amp;title=407-motoru#131299</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2155">Onur</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 20:34<br /><br /><P><FONT style=": #9cb9e1">hadi abinin de dedigi gbi peugeot bazı motorları bmw ile ortak yapıyo hatta bmw yle resmen ortak oluyolar 4 silindirse olabilir</FONT></P>]]>
   </description>
   <pubDate>Mon, 10 May 2010 20:34:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131299&amp;title=407-motoru#131299</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : bu arada bmw nin 5.20 modelleri...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131260&amp;title=407-motoru#131260</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 14:47<br /><br />bu arada bmw nin 5.20 modelleri 4 silindirmiş.. bmwnın kendi sitesinden baktım]]>
   </description>
   <pubDate>Mon, 10 May 2010 14:47:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131260&amp;title=407-motoru#131260</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : tamam t&#351;kler...:D ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131258&amp;title=407-motoru#131258</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 14:43<br /><br />tamam tşkler...:D]]>
   </description>
   <pubDate>Mon, 10 May 2010 14:43:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131258&amp;title=407-motoru#131258</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : o halde BMW motoru olamaz diye...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131256&amp;title=407-motoru#131256</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1526">H-a-d-i</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 14:42<br /><br />o halde BMW motoru olamaz diye düşünüyorum. çünkü BMW 520 6 silindire sahiptir. bazıları 150, bazıları da 170 hp'dir. ama 308 lerin motorunun BMW ile ortaklaşa yapıldığını biliyorum. belki aynı durum 407 için de geçerli olabilir.]]>
   </description>
   <pubDate>Mon, 10 May 2010 14:42:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131256&amp;title=407-motoru#131256</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : de&#287;il san&#305;r&#305;m 2.0 163 hp motor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131255&amp;title=407-motoru#131255</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 14:35<br /><br />değil sanırım 2.0 163 hp motor var]]>
   </description>
   <pubDate>Mon, 10 May 2010 14:35:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131255&amp;title=407-motoru#131255</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : acaba yeni 407&amp;#039; ler 6 silindir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131249&amp;title=407-motoru#131249</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1526">H-a-d-i</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 13:54<br /><br />acaba yeni 407' ler 6 silindir mi?]]>
   </description>
   <pubDate>Mon, 10 May 2010 13:54:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131249&amp;title=407-motoru#131249</guid>
  </item>
  <item>
   <title><![CDATA[407 motoru : Arkada&#351;lar ben bir &#351;ey duydum....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131248&amp;title=407-motoru#131248</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9171<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Mayıs&nbsp;2010 Saat 13:44<br /><br />Arkadaşlar ben bir şey duydum. bu yeni çıkan 407 gt line ların motoru bmw 5.20 motoruymuş doğru mu?]]>
   </description>
   <pubDate>Mon, 10 May 2010 13:44:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9171&amp;PID=131248&amp;title=407-motoru#131248</guid>
  </item>
 </channel>
</rss>
