 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : partner araçlarından anlayanlar :(</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Partner : partner araçlarından anlayanlar :(]]></description>
  <pubDate>Fri, 01 May 2026 21:02:09 +0000</pubDate>
  <lastBuildDate>Mon, 03 May 2010 21:02:29 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=9094</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : hdi ler turbolu olsagerek ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130173&amp;title=partner-araclarindan-anlayanlar#130173</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2925">TheEchoes</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 21:02<br /><br />hdi ler turbolu olsagerek]]>
   </description>
   <pubDate>Mon, 03 May 2010 21:02:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130173&amp;title=partner-araclarindan-anlayanlar#130173</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : turbolu o partnerlar duydu&#287;unuzda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130135&amp;title=partner-araclarindan-anlayanlar#130135</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3046">saw50</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 19:07<br /><br />turbolu o partnerlar duyduğunuzda turbo sesi....]]>
   </description>
   <pubDate>Mon, 03 May 2010 19:07:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130135&amp;title=partner-araclarindan-anlayanlar#130135</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : 1997 silindir hacmi yaz&#305;yor gerisine...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130124&amp;title=partner-araclarindan-anlayanlar#130124</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3019">aopena</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 18:24<br /><br />1997 silindir hacmi yazıyor gerisine bakmadım ama turboyla ilgili hiç birşey yazmıyor araç suanda burda deil gelince bakıp herseyi yazcam ancak turbo görülmüyor ama gaz verince ssss sesleri duyuluyor üfleme sesi var hafiften ama nedir anlamadık ıslık sesi gibi ama pek net deil acaba omudur :/ arızası nasıl anlasılır ?]]>
   </description>
   <pubDate>Mon, 03 May 2010 18:24:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130124&amp;title=partner-araclarindan-anlayanlar#130124</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( :   aopena Yazd&#305;:bakt&#305;&#287;&#305;m&#305;z zmana...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130123&amp;title=partner-araclarindan-anlayanlar#130123</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1265">CIHANGIR_DONMEZ</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 18:06<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: aopena" alt="Orjinalini yazan: aopena" style="vertical-align: text-bottom;" /> <strong>aopena Yazdı:</strong><br /><br />baktığımız zmana bir yerinde turbo yok görülmüyor :D nasıl birşey açıkcası turbo neresinde tam oalrak&nbsp;</td></tr></table> ruhsatınızda ne yazıyor buraya yazarsanız daha ıyı olur kac kw ve kac cc motor hacmı kısmı ]]>
   </description>
   <pubDate>Mon, 03 May 2010 18:06:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130123&amp;title=partner-araclarindan-anlayanlar#130123</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( :   aopena Yazd&#305;:arkada&#351;lar bende...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130122&amp;title=partner-araclarindan-anlayanlar#130122</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1265">CIHANGIR_DONMEZ</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 18:04<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: aopena" alt="Orjinalini yazan: aopena" style="vertical-align: text-bottom;" /> <strong>aopena Yazdı:</strong><br /><br />arkadaşlar bende partner hdi 2.0 motor olanı var bu 2004 model bu araçta turbo varmıdır ? ben pek iyi anlamıyorum birde bu araç tutulan modelimidir ? kimisi tutulmaz diyor kimisi daha iyi diyor :S sizce&nbsp;</td></tr></table> partnerde 1.9 70 hp turbosuz duz dızel 2.0 90 hp turbolu motor bulunmaktadır 2.0 motorlar tutulan modeldır sayet 1.9 lar gıtmıyor 140 150 km yı zor yapıo&nbsp; ]]>
   </description>
   <pubDate>Mon, 03 May 2010 18:04:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130122&amp;title=partner-araclarindan-anlayanlar#130122</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : bakt&#305;&#287;&#305;m&#305;z zmana bir yerinde turbo...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130104&amp;title=partner-araclarindan-anlayanlar#130104</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3019">aopena</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 17:14<br /><br />baktığımız zmana bir yerinde turbo yok görülmüyor :D nasıl birşey açıkcası turbo neresinde tam oalrak&nbsp;]]>
   </description>
   <pubDate>Mon, 03 May 2010 17:14:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130104&amp;title=partner-araclarindan-anlayanlar#130104</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : b&#305;ldg&#305;m kadar&#305;yla turbolu  ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130099&amp;title=partner-araclarindan-anlayanlar#130099</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 17:10<br /><br /><b>bıldgım kadarıyla turbolu&nbsp;</b>]]>
   </description>
   <pubDate>Mon, 03 May 2010 17:10:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130099&amp;title=partner-araclarindan-anlayanlar#130099</guid>
  </item> 
  <item>
   <title><![CDATA[partner araçlarından anlayanlar :( : arkada&#351;lar bende partner hdi 2.0...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130096&amp;title=partner-araclarindan-anlayanlar#130096</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=3019">aopena</a><br /><strong>Konu:</strong> 9094<br /><strong>Gönderim Zamanı:</strong> 03&nbsp;Mayıs&nbsp;2010 Saat 17:04<br /><br />arkadaşlar bende partner hdi 2.0 motor olanı var bu 2004 model bu araçta turbo varmıdır ? ben pek iyi anlamıyorum birde bu araç tutulan modelimidir ? kimisi tutulmaz diyor kimisi daha iyi diyor :S sizce&nbsp;]]>
   </description>
   <pubDate>Mon, 03 May 2010 17:04:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=9094&amp;PID=130096&amp;title=partner-araclarindan-anlayanlar#130096</guid>
  </item> 
 </channel>
</rss>
