 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Sağ ön davlumbaz...</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Sağ ön davlumbaz...]]></description>
  <pubDate>Sat, 02 May 2026 19:28:42 +0000</pubDate>
  <lastBuildDate>Mon, 05 Apr 2010 17:38:15 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=8665</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : Herhangi bir sorun yok o zaman.Te&#351;ekk&#252;rler.. ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123806&amp;title=sag-on-davlumbaz#123806</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2010 Saat 17:38<br /><br />Herhangi bir sorun yok o zaman.Teşekkürler..]]>
   </description>
   <pubDate>Mon, 05 Apr 2010 17:38:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123806&amp;title=sag-on-davlumbaz#123806</guid>
  </item>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : mar&#351;a basmadan &#246;nce yanan abs...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123804&amp;title=sag-on-davlumbaz#123804</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1589">peugeotefe</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2010 Saat 17:36<br /><br />marşa basmadan önce yanan abs ışığı normal o fişlerde balata ikaz kablosu olabilir]]>
   </description>
   <pubDate>Mon, 05 Apr 2010 17:36:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123804&amp;title=sag-on-davlumbaz#123804</guid>
  </item>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : Ara&#231; y&#252;r&#252;r durumdayken abs &#305;&#351;&#305;&#287;&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123802&amp;title=sag-on-davlumbaz#123802</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2010 Saat 17:31<br /><br />Araç yürür durumdayken abs ışığı yanmıyor sadece marşa basmadan 3 sn kadar yanıp sonra sönüyor..Kablo da tam soketin olduğu yerde kırmızı,mavi olarak görünür vaziyette.]]>
   </description>
   <pubDate>Mon, 05 Apr 2010 17:31:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123802&amp;title=sag-on-davlumbaz#123802</guid>
  </item>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : ara&#231; &#231;al&#305;&#351;&#305;p y&#252;r&#252;rken abs &#305;&#351;&#305;&#287;&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123798&amp;title=sag-on-davlumbaz#123798</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1589">peugeotefe</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2010 Saat 17:00<br /><br />araç çalışıp yürürken abs ışığı yanıyomu yanmıyomu onuda söylerseniz daha detaylı yardımcı oluruz kablo tam olarak nerden sarkıyo onuda belirtirseniz yardımcı oluruz]]>
   </description>
   <pubDate>Mon, 05 Apr 2010 17:00:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123798&amp;title=sag-on-davlumbaz#123798</guid>
  </item>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : Bir arkada&#351;&#305;m cevap verirse sevinirim..Al&#305;nmas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123797&amp;title=sag-on-davlumbaz#123797</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2010 Saat 16:29<br /><br />Bir arkadaşım cevap verirse sevinirim..Alınması gereken bir önlem varsa alayım..]]>
   </description>
   <pubDate>Mon, 05 Apr 2010 16:29:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123797&amp;title=sag-on-davlumbaz#123797</guid>
  </item>
  <item>
   <title><![CDATA[Sağ ön davlumbaz... : Bug&#252;n arac&#305;m&#305; y&#305;karken sa&#287; &#246;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123650&amp;title=sag-on-davlumbaz#123650</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 8665<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Nisan&nbsp;2010 Saat 19:22<br /><br />Bugün aracımı yıkarken sağ ön davlumbazın oynadığını fark ettim.. Heralde vidalardan biri yok..Kurcalarken elime bir soket ilişti,Diske giden bir soketti,,Her zaman davlumbazın içini temizlerim suyla ve soketteki kablolardan birinin içininin açıldığını gördüm içindeki mavi,kırmızı kablo görünüyordu...Bu kablolar suyla temas ediyor..Herhangi bir sorun olur mu acaba?(Kontağı çeviridğimde abs ışığı 5 saniye kadar yanıp sonra sönüyor)<br>&nbsp;Aracım 2002 307&nbsp; xs..<br>]]>
   </description>
   <pubDate>Sun, 04 Apr 2010 19:22:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=8665&amp;PID=123650&amp;title=sag-on-davlumbaz#123650</guid>
  </item>
 </channel>
</rss>
