 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Su Sesi..</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 106 : Su Sesi..]]></description>
  <pubDate>Sun, 03 May 2026 11:59:51 +0000</pubDate>
  <lastBuildDate>Sat, 02 May 2009 19:42:24 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=5675</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Su Sesi.. :   hasimayaz Yazd&#305;:Devirdaim pompas&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80982&amp;title=su-sesi#80982</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1273">Carmania</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mayıs&nbsp;2009 Saat 19:42<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hasimayaz" alt="Orjinalini yazan: hasimayaz" style="vertical-align: text-bottom;" /> <strong>hasimayaz Yazdı:</strong><br /><br />Devirdaim pompası ideal basıncı üretemiyorsa su sesi yapabilir.</td></tr></table> <DIV></DIV>İnşallah öledir haşim usta , onada bi baktırayım conta yakmasından iyidir, teşekkürler ]]>
   </description>
   <pubDate>Sat, 02 May 2009 19:42:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80982&amp;title=su-sesi#80982</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. :   ADRENAL&#304;N Yazd&#305;: radyat&#246;r...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80981&amp;title=su-sesi#80981</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1273">Carmania</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mayıs&nbsp;2009 Saat 19:40<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: ADRENALİN" alt="Orjinalini yazan: ADRENALİN" style="vertical-align: text-bottom;" /> <strong>ADRENALİN Yazdı:</strong><br /><br /><P><FONT>radyatör kapağını soğukkan açıyorsundur diye düşünüyorum,</P><DIV>eğer sıcakken açıyorsan suyu dışarı atması normal,</DIV><DIV></DIV>birde radyötöre&nbsp; suyu ağzına kadar doldurmaman gerek,&nbsp; ozaman dışarı atma yapmaz, <DIV></DIV>su sesine gelince sadece motor soğukken sabahları yapıyordur <DIV></DIV></FONT></td></tr></table> <DIV></DIV>&nbsp;evet ama nedense sıcakkende su sesi geliyo ,teşekkürler]]>
   </description>
   <pubDate>Sat, 02 May 2009 19:40:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80981&amp;title=su-sesi#80981</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. :   GKN Yazd&#305;:Pek anlamam ama direksiyon...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80980&amp;title=su-sesi#80980</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1273">Carmania</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mayıs&nbsp;2009 Saat 19:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: GKN" alt="Orjinalini yazan: GKN" style="vertical-align: text-bottom;" /> <strong>GKN Yazdı:</strong><br /><br />Pek anlamam ama direksiyon hidrolik yagı bosalırken bendede su sesi vardı.</td></tr></table>&nbsp; <DIV>Hayır gökhan direksiyon hidrolik yağı tam dolu arabamın yağı 2 ayda bir zamanı gelmeden deişirim yani öle bakımsız bırakmıyorum neyse teşekkürler.</DIV><DIV>&nbsp;</DIV>]]>
   </description>
   <pubDate>Sat, 02 May 2009 19:38:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80980&amp;title=su-sesi#80980</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. : Devirdaim pompas&#305; ideal bas&#305;nc&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80944&amp;title=su-sesi#80944</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=81">hasimayaz</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Mayıs&nbsp;2009 Saat 09:58<br /><br />Devirdaim pompası ideal basıncı üretemiyorsa su sesi yapabilir.]]>
   </description>
   <pubDate>Sat, 02 May 2009 09:58:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80944&amp;title=su-sesi#80944</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. : Pek anlamam ama direksiyon hidrolik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80919&amp;title=su-sesi#80919</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1">GökhaN</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Mayıs&nbsp;2009 Saat 23:34<br /><br />Pek anlamam ama direksiyon hidrolik yagı bosalırken bendede su sesi vardı.]]>
   </description>
   <pubDate>Fri, 01 May 2009 23:34:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80919&amp;title=su-sesi#80919</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. : radyat&#246;r kapa&#287;&#305;n&#305; so&#287;ukkan a&#231;&#305;yorsundur...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80915&amp;title=su-sesi#80915</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=388">TOLGA</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Mayıs&nbsp;2009 Saat 23:24<br /><br /><P><FONT style=": #336699">radyatör kapağını soğukkan açıyorsundur diye düşünüyorum,</P><DIV>eğer sıcakken açıyorsan suyu dışarı atması normal,</DIV><DIV></DIV>birde radyötöre&nbsp; suyu ağzına kadar doldurmaman gerek,&nbsp; ozaman dışarı atma yapmaz,<DIV></DIV>su sesine gelince sadece motor soğukken sabahları yapıyordur<DIV></DIV></FONT>]]>
   </description>
   <pubDate>Fri, 01 May 2009 23:24:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80915&amp;title=su-sesi#80915</guid>
  </item>
  <item>
   <title><![CDATA[Su Sesi.. : Arkada&#351;lar gecenlerde 106 Xs arabam&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80900&amp;title=su-sesi#80900</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1273">Carmania</a><br /><strong>Konu:</strong> 5675<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Mayıs&nbsp;2009 Saat 22:29<br /><br />Arkadaşlar gecenlerde 106 Xs arabamın su radyatörü çatladı ve deiştirdim. Sonra aradan biraz zaman geçti arabamı ilk çalıştırdığım anda her gaza basışımda ön torpidodan bildiğimiz su sesi geliyodu torpidoyu felan söktürdüm kalorifer radyatörü çatlamış dediler sonra kalorifer radyatörünüde deiştirttim ve sorun hala çözülmedi ve halada her gaza bastığımda su sesi geliyo ,usta contan yanmış olabilir dedi ama yağa bakıyorum ne köpükler var nede beyaz bişeyler var yağ kapağını açıp bakıyorum oradada beyazlaşma yok su radyatörüne bakıyorum oradada yağ yok kafayı yedim ilk defa arabamdan nefret eder oldum ya <img src="http://forum.peugeotturkey.com/smileys/smiley19.gif" height="17" width="17" border="0" alt="Cry" title="Cry" />. Usta hava vardır diyo havasını alıyorum su ilave ediyorum&nbsp;çalıştırıyorum 5 dk sonra radyatörden su dışarı çıkıyo. bikaçgün sonra o ses kesilir dıyo usta, ama peki su neden dışarıya çıkıyo <DIV>(Radyatör kapağını ilk ilk açtığımda ilk fışkıran su soğuk geliyo ve ardından&nbsp; sıcak geliyo) Yardımlarınızı bekliyorum</DIV>]]>
   </description>
   <pubDate>Fri, 01 May 2009 22:29:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=5675&amp;PID=80900&amp;title=su-sesi#80900</guid>
  </item>
 </channel>
</rss>
