 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Teyp, Multimedya, Can Bus, cruise control konuları</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Partner Tepee : Teyp, Multimedya, Can Bus, cruise control konuları]]></description>
  <pubDate>Fri, 01 May 2026 22:14:29 +0000</pubDate>
  <lastBuildDate>Tue, 10 Oct 2023 14:05:44 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=52491</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Teyp, Multimedya, Can Bus, cruise control konuları : Merhabalar &#246;yle bozmas&#305; zor hocam...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=52491&amp;PID=632917&amp;title=teyp-multimedya-can-bus-cruise-control-konulari#632917</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 52491<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Ekim&nbsp;2023 Saat 14:05<br /><br />Merhabalar öyle bozması zor hocam ben hiç duymadım açıkcası. hatalı balantı sonucu problem olabilir belki.&nbsp;]]>
   </description>
   <pubDate>Tue, 10 Oct 2023 14:05:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=52491&amp;PID=632917&amp;title=teyp-multimedya-can-bus-cruise-control-konulari#632917</guid>
  </item> 
  <item>
   <title><![CDATA[Teyp, Multimedya, Can Bus, cruise control konuları : Merhaba Arkada&#351;lar, 2012 ledli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=52491&amp;PID=632885&amp;title=teyp-multimedya-can-bus-cruise-control-konulari#632885</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=28123">TunaAlp</a><br /><strong>Konu:</strong> 52491<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ekim&nbsp;2023 Saat 15:11<br /><br />Merhaba Arkadaşlar, 2012 ledli kasa aracıma güzel ses almak için teyp araştırması yaptım. herkes 9 inçlik Çin malı multimedyaları öneriyor. tüm fonksiyonların eksiksiz çalışması için. ( yol bilgisayarı ve kumanda kolu için ) ancak ses kalitesi ve aşırı pahalılığı sebebiyle almadım. evde pioneer teybim vardı. onu bağlamak için soket araştırırken Can-buss buldum ve sipariş ettim. montajı da kendim yaptım şu an sıkıntısız vaziyette çalışıyor.&nbsp;<div id="CSChromeExtensi&#111;n"></div><div id="CSChromeExtensi&#111;nVersi&#111;n" versi&#111;n="1.0.12"></div><div><br></div><div>Daha önce aracıma cruise control takan bir arkadaş vardı. onunla paylaştım bu şekilde çözdüm diye. aracın zamanla Bsi problemi yaşar dedi. onu da araştırdım beyin diyebileceğimiz sistemi bozuyormuş. bu hususta daha önce kullanan, sıkıntıya giren var mıdır ? çin malı multimedya larda araç için özel ne var ? bilen var mıdır ?</div><div><br></div><div>aldığım ürünleri merak eden arkadaşlar için link paylaşımı yapabilirim...</div>]]>
   </description>
   <pubDate>Wed, 04 Oct 2023 15:11:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=52491&amp;PID=632885&amp;title=teyp-multimedya-can-bus-cruise-control-konulari#632885</guid>
  </item> 
 </channel>
</rss>
