 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : P1336 p1340</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 308 T7 (2008-2013) : P1336 p1340]]></description>
  <pubDate>Mon, 04 May 2026 02:57:51 +0000</pubDate>
  <lastBuildDate>Wed, 16 Aug 2023 18:57:48 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=51758</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[P1336 p1340 :   Katip55 Yazd&#305;:Sorun kataliz&#246;r&#252;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=632758&amp;title=p1336-p1340#632758</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=28041">Kadir 6530</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Ağustos&nbsp;2023 Saat 18:57<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Katip55" alt="Orjinalini yazan: Katip55" style="vertical-align: text-bottom;" /> <strong>Katip55 Yazdı:</strong><br /><br />Sorun katalizörün doldurulmasıyla ilgili çıktı. 300liraya boş katalizör için alt sensöre takılan aparat takıldı. Katalizör boşaltılmadı. 1336 ve 40 şuan için yok</td></tr></table><div><br></div><div><br></div><div>O aparat tam olarak nedir acaba?</div>]]>
   </description>
   <pubDate>Wed, 16 Aug 2023 18:57:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=632758&amp;title=p1336-p1340#632758</guid>
  </item>
  <item>
   <title><![CDATA[P1336 p1340 : Sorun kataliz&#246;r&#252;n doldurulmas&#305;yla...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630699&amp;title=p1336-p1340#630699</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26900">Katip55</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Haziran&nbsp;2022 Saat 11:44<br /><br />Sorun katalizörün doldurulmasıyla ilgili çıktı. 300liraya boş katalizör için alt sensöre takılan aparat takıldı. Katalizör boşaltılmadı. 1336 ve 40 şuan için yok]]>
   </description>
   <pubDate>Wed, 01 Jun 2022 11:44:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630699&amp;title=p1336-p1340#630699</guid>
  </item>
  <item>
   <title><![CDATA[P1336 p1340 : Zaten herkes test yapmadan &#252;st...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630655&amp;title=p1336-p1340#630655</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26900">Katip55</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2022 Saat 14:49<br /><br />Zaten herkes test yapmadan üst kapak diyip sallıyor kardeşim. Aracın kompresyon testinde değerleri iyi. Baya araştırdım. Yanık çatlak olsa komprisyonun bozuk çıkması lazımmış. Bende öyle bişey yok. Ne olduysa katalizörü doldurduktan sonra oldu. Üzt kapak arızası vermiyor ki<span style="font-size:10px"><br /><br />Düzenleyen Katip55 - 29&nbsp;Mayıs&nbsp;2022 Saat 14:50</span>]]>
   </description>
   <pubDate>Sun, 29 May 2022 14:49:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630655&amp;title=p1336-p1340#630655</guid>
  </item>
  <item>
   <title><![CDATA[P1336 p1340 : Aleyk&#252;m selam hocam,&#220;st kapak...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630654&amp;title=p1336-p1340#630654</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12669">oktan24</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2022 Saat 13:00<br /><br />Aleyküm selam hocam,&nbsp;<div>Üst kapak ile alakalı diye biliyorum p1336 ve p1340</div><div>Vti’dan anlayan usta bulmak çok zor maalesef&nbsp;</div><div>Testler yapılmadan motora girmek mantıklı değil</div><div>Bende de 308 1.6vti manuel var &#129315; P0011 ile mücadele ediyorum&nbsp;</div><div><a href="https://youtu.be/2TTn2NP7734" target="_blank" rel="nofollow">https://youtu.be/2TTn2NP7734</a></div>]]>
   </description>
   <pubDate>Sun, 29 May 2022 13:00:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630654&amp;title=p1336-p1340#630654</guid>
  </item>
  <item>
   <title><![CDATA[P1336 p1340 : Esasen benim motorla ilgili b&#252;t&#252;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630651&amp;title=p1336-p1340#630651</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26900">Katip55</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Mayıs&nbsp;2022 Saat 00:23<br /><br />Esasen benim motorla ilgili bütün şikayetim şöyle başladı. Aracı aldığımda katalzör boştu. Doldurma yaptık. 0366 öyle verdi. Yabancı biri ile youtbeda konuştum şimdi aynı şeyi kat iptali ile halletmiş. Katalizör ateşlemeyi blokluyor diyor. Neden mantığını anlamadım ama olay örgüsüne bakınca mantıklı geldi]]>
   </description>
   <pubDate>Sun, 29 May 2022 00:23:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630651&amp;title=p1336-p1340#630651</guid>
  </item>
  <item>
   <title><![CDATA[P1336 p1340 : Selamun aleyk&#252;m. Arkada&#351;lar ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630650&amp;title=p1336-p1340#630650</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26900">Katip55</a><br /><strong>Konu:</strong> 51758<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Mayıs&nbsp;2022 Saat 22:57<br /><br />Selamun aleyküm. Arkadaşlar araç 1.6 vti 2011 al4 benzinli. 190bin kmde. Geçmişini bilmiyorum. Sadece tüp varmış sökülmüş. Aldıktan sorra p0366 hatası verdi bütün sensörlere bakıldı sağlamı ile denendi gitmeyince eksantrik mili değişti p0366 gitti ancak o gidince p1336 p1340 ve p0171 geldi. Oksijen sensörü değişti p0171 gitti. Bujiler bobunler değişti iridyumlu orjinal. Ama p1336 ve 40 gitmiyor. Aracın gidişinde bişey yok. Sabah motor soğukken arızaları veriyor ısınınca siliyorum sıcakken daha vermiyor. İşin içinden çıkamadım. Motora girmek de istemiyoruz. Sorunu bilen var mı ?]]>
   </description>
   <pubDate>Sat, 28 May 2022 22:57:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51758&amp;PID=630650&amp;title=p1336-p1340#630650</guid>
  </item>
 </channel>
</rss>
