 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 - Akü ışığı</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 - Akü ışığı]]></description>
  <pubDate>Mon, 04 May 2026 18:38:46 +0000</pubDate>
  <lastBuildDate>Thu, 24 Nov 2022 07:59:09 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=51547</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 - Akü ışığı :   altnyunuss Yazd&#305;:Bu dedi&#287;iniz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631657&amp;title=206-aku-isigi#631657</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26867">ByYlmzZz</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Kasım&nbsp;2022 Saat 07:59<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: altnyunuss" alt="Orjinalini yazan: altnyunuss" style="vertical-align: text-bottom;" /> <strong>altnyunuss Yazdı:</strong><br /><br />Bu dediğiniz bsi araç icindeki direksiyonun altindaki sigorta kutusumu yoksa motorun yanındaki olan sigorta kutusumu</td></tr></table><div><br></div><div>Kaputu kaldırdığınıza sağ tarafta siyah kapak altında olan parça. hemen amortisör kulesinin dibinde.</div>]]>
   </description>
   <pubDate>Thu, 24 Nov 2022 07:59:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631657&amp;title=206-aku-isigi#631657</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : Bu dedi&#287;iniz bsi ara&#231; icindeki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631635&amp;title=206-aku-isigi#631635</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=27513">altnyunuss</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2022 Saat 14:41<br /><br />Bu dediğiniz bsi araç icindeki direksiyonun altindaki sigorta kutusumu yoksa motorun yanındaki olan sigorta kutusumu]]>
   </description>
   <pubDate>Thu, 17 Nov 2022 14:41:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631635&amp;title=206-aku-isigi#631635</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : arac&#305;n&#305;z&#305;n BS&#304; dedi&#287;imiz sigortalar&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631634&amp;title=206-aku-isigi#631634</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=26867">ByYlmzZz</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2022 Saat 10:06<br /><br />aracınızın BSİ dediğimiz sigortaları barındırdığı parçayı söktürüp baktırın. iyi izole edilmiş bir parça değil aslında. üzerinde röleler , sigortalar var. oksitlenme durumunda dediklerinizi ve daha fazlasını yapabiliyor. Birde şase hattının kotrolünü yapın.]]>
   </description>
   <pubDate>Thu, 17 Nov 2022 10:06:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631634&amp;title=206-aku-isigi#631634</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : Selam karde&#351;im, ayn&#305; sorunu bende...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631604&amp;title=206-aku-isigi#631604</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=27513">altnyunuss</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Kasım&nbsp;2022 Saat 12:23<br /><br />Selam kardeşim, aynı sorunu bende yaşıyorum,acaba cozebildinmi]]>
   </description>
   <pubDate>Sun, 13 Nov 2022 12:23:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=631604&amp;title=206-aku-isigi#631604</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : Merhabalar ayn&#305; problemleri bire...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629817&amp;title=206-aku-isigi#629817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=27014">Cihanmutlu</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Şubat&nbsp;2022 Saat 21:21<br /><br />Merhabalar aynı problemleri bire bir 2006 model 206 x-design 1.4 hdi aracımda bende yaşıyorum. Yaklaşık bir yıl oldu ve tanıdık bilindik bir ustam olmadığından sanayiye götürme ürküyorum açıkçası(Şanlıurfa)]]>
   </description>
   <pubDate>Wed, 16 Feb 2022 21:21:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629817&amp;title=206-aku-isigi#629817</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : Sorun muhtemelen ara&#231; i&#231;i si&#287;orta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629789&amp;title=206-aku-isigi#629789</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Şubat&nbsp;2022 Saat 11:51<br /><br />Sorun muhtemelen araç içi siğorta kutusunda gibi kardeşim yani bsı. yada aracın elektrik şaselerinden birinde oksitlenme vs. olabilir.&nbsp; v kayışı sağlam deilmi eğer v kayışı ısındıkça gevşiyorsa şarj dinamosunu düzğün çevirmez dengesizliğne sebepte olabilir.&nbsp;]]>
   </description>
   <pubDate>Mon, 14 Feb 2022 11:51:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629789&amp;title=206-aku-isigi#629789</guid>
  </item>
  <item>
   <title><![CDATA[206 - Akü ışığı : Merhaba arac&#305;m seyir halindeyken...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629764&amp;title=206-aku-isigi#629764</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=27003">muratdt</a><br /><strong>Konu:</strong> 51547<br /><strong>Gönderim Zamanı:</strong> 12&nbsp;Şubat&nbsp;2022 Saat 12:04<br /><br />Merhaba aracım seyir halindeyken akü ışığı yanıyor ve 3 kez uyarı sesi veriyor. (Yakıt bitmeye yakın gelen uyarı gibi)<div>&nbsp;</div><div>Akü ışığı yandığında:</div><div><br></div><div>-Farlarda, camlarda, teypte herhangi bir değişim olmuyor.&nbsp;</div><div>-Aracın tavan ışıklarına ve çakmak gözüne elektrik gelmiyor.&nbsp;</div><div>-Orta konsoldaki merkezi kilit ve dörtlüleri açan tuşlara bazen elektrik geliyor bazen gelmiyor.&nbsp;</div><div><br></div><div><br></div><div>İlk elektrikçiye götürdüm, o anda akü ışığı yanmıyordu, akü sorunsuz sarj ediyordu ama konjoktürün değişim kmsi geçtiği için değiştirdik.&nbsp;</div><div><br></div><div>4-5 gün sorunsuz çalıştı, yağışlı soğuk bir gece dışarıda kaldıktan sonra (alakası var mıdır emin değilim) tekrar tavan ışıklarına-çakmak gözüne elektrik gelmemeye başladı. Akü ışığı bazen yanıyor, yandıktan 3-5 dkk sonra sönüyor. Sönmediği de oldu.&nbsp;</div><div><br></div><div>Yaklaşık 100km yol yaptıktan sonra tekrar elektrikçide gittik baktık, akü normal bir şekilde şarj ediyor ve aküde bir zayıflama yok.&nbsp;</div><div><br></div><div>Yani akü ışığı yandığında aküde veya akünün şarjında bir problem yok gibi görünüyor ama tavan lambalarına-çakmak gözüne ve bazen merkezi kilidin bulunduğu orta konsola elektrik gelmiyor.&nbsp;</div><div><br></div><div>Olabildiğince ayrıntısıyla yazmaya çalıştım.</div><div>Sorunu yaşayan-çözen var mı? İstanbul mümkünse anadolu yakası usta önerilerinizi bekliyorum.&nbsp;</div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Sat, 12 Feb 2022 12:04:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=51547&amp;PID=629764&amp;title=206-aku-isigi#629764</guid>
  </item>
 </channel>
</rss>
