 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 306 1.8 Aracımda Benzinde Tekleme</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 306 : 306 1.8 Aracımda Benzinde Tekleme]]></description>
  <pubDate>Mon, 04 May 2026 20:58:18 +0000</pubDate>
  <lastBuildDate>Tue, 16 Feb 2021 10:04:52 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=50432</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[306 1.8 Aracımda Benzinde Tekleme : Merhaba. Ustaya g&#246;sterdiniz mi?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=626669&amp;title=306-1-8-aracimda-benzinde-tekleme#626669</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=25630">Essentials</a><br /><strong>Konu:</strong> 50432<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Şubat&nbsp;2021 Saat 10:04<br /><br />Merhaba. Ustaya gösterdiniz mi? Son durumu nedir şuan arızanın?]]>
   </description>
   <pubDate>Tue, 16 Feb 2021 10:04:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=626669&amp;title=306-1-8-aracimda-benzinde-tekleme#626669</guid>
  </item>
  <item>
   <title><![CDATA[306 1.8 Aracımda Benzinde Tekleme : Merhaba Ustam Teskkurler Hafta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625474&amp;title=306-1-8-aracimda-benzinde-tekleme#625474</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=25618">Peace</a><br /><strong>Konu:</strong> 50432<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2020 Saat 14:15<br /><br />Merhaba Ustam&nbsp;<div><br></div><div>Teskkurler Hafta sonu ilk isim buraya gitmek olcak .</div>]]>
   </description>
   <pubDate>Wed, 18 Nov 2020 14:15:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625474&amp;title=306-1-8-aracimda-benzinde-tekleme#625474</guid>
  </item>
  <item>
   <title><![CDATA[306 1.8 Aracımda Benzinde Tekleme : Merhabalar hocam. bu tip sorunlar&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625465&amp;title=306-1-8-aracimda-benzinde-tekleme#625465</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 50432<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2020 Saat 10:33<br /><br />Merhabalar hocam. bu tip sorunların kaynağı genelde bobinlerden olur. ateşleme düzğün olmadığı için. ivedikte mas peugeot abdullah usta var isterseniz birde oraya götürüp baktırabilirsiniz. iyi ustalardır.]]>
   </description>
   <pubDate>Wed, 18 Nov 2020 10:33:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625465&amp;title=306-1-8-aracimda-benzinde-tekleme#625465</guid>
  </item>
  <item>
   <title><![CDATA[306 1.8 Aracımda Benzinde Tekleme : Merhaba Arkada&#351;lar Yeni 306 ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625459&amp;title=306-1-8-aracimda-benzinde-tekleme#625459</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=25618">Peace</a><br /><strong>Konu:</strong> 50432<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2020 Saat 22:01<br /><br />Merhaba Arkadaşlar<div><br></div><div>Yeni 306 araç aldım 1999 Model Otomatik Bir anda aracim Benzinde Tekleme yapıyor ve alt taraftan pat pat diye ses geliyor ufak bir yokuşu bile çıkmıyor benzinde usta bujileri değiştirdi benzin filitresini degistirdi fakat sonuç aynı son olarak benzin pompası diyor fakat fiyatlari yüksek bundan dolayı almadım ve alıp belki sonuçsuz olmasından korkuyorum Bundan dolayı sizlerin başına gelen oludumu aynı şekilde yardımcı olabilirseniz Çok Sevinirim.</div>]]>
   </description>
   <pubDate>Tue, 17 Nov 2020 22:01:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50432&amp;PID=625459&amp;title=306-1-8-aracimda-benzinde-tekleme#625459</guid>
  </item>
 </channel>
</rss>
