 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Vuruntu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 207 : Vuruntu]]></description>
  <pubDate>Mon, 04 May 2026 03:55:56 +0000</pubDate>
  <lastBuildDate>Sat, 15 Aug 2020 01:22:45 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=50152</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Vuruntu : Insallah cok masrafli birsey degildir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623966&amp;title=vuruntu#623966</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=24392">M3rt</a><br /><strong>Konu:</strong> 50152<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Ağustos&nbsp;2020 Saat 01:22<br /><br />Insallah cok masrafli birsey degildir biktim ugrasmaktan sorunu bitmiyor&nbsp;]]>
   </description>
   <pubDate>Sat, 15 Aug 2020 01:22:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623966&amp;title=vuruntu#623966</guid>
  </item>
  <item>
   <title><![CDATA[Vuruntu : gaz potansiometresinde sorun olabilir.ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623956&amp;title=vuruntu#623956</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18336">maximusti</a><br /><strong>Konu:</strong> 50152<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Ağustos&nbsp;2020 Saat 17:00<br /><br />gaz potansiometresinde sorun olabilir.&nbsp;<div>ama önce kelebeğin temizlenmesi lazım.&nbsp;</div>]]>
   </description>
   <pubDate>Fri, 14 Aug 2020 17:00:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623956&amp;title=vuruntu#623956</guid>
  </item>
  <item>
   <title><![CDATA[Vuruntu : Muhtemelen sorun gaz kele&#287;i temizli&#287;i...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623945&amp;title=vuruntu#623945</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 50152<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Ağustos&nbsp;2020 Saat 09:27<br /><br />Muhtemelen sorun gaz keleği temizliği düzelir kendi kendine gaz vermesi. vuruntu olayı şanzuman takazu ve motor takzolarından kanaklı olabilir.]]>
   </description>
   <pubDate>Fri, 14 Aug 2020 09:27:06 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623945&amp;title=vuruntu#623945</guid>
  </item>
  <item>
   <title><![CDATA[Vuruntu : Merhaba arkada&#351;lar 1.4 benzinli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623943&amp;title=vuruntu#623943</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=24392">M3rt</a><br /><strong>Konu:</strong> 50152<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Ağustos&nbsp;2020 Saat 08:40<br /><br />Merhaba arkadaşlar 1.4 benzinli trendy modeli 207 kullanıyorum 1. Viteste kalkışta sıkıştırmıyorum 2. Vitese attigim zaman ayağımı gazdan çekmeme rağmen devir saati yükseliyor yani ben debriyaja basinca araba bağırıyor boşta gaza başarmış gibi bu neden olabilir birde vites yükselttigimde tak diye vuruntu yapıyor bilgisi olan yardımcı olabilirmi tamircilere hiç güven yok izmirde gerçekten bu işi bilen varsa söyleyebilirmisiniz]]>
   </description>
   <pubDate>Fri, 14 Aug 2020 08:40:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=50152&amp;PID=623943&amp;title=vuruntu#623943</guid>
  </item>
 </channel>
</rss>
