 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : -10 derecede hararet</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : -10 derecede hararet]]></description>
  <pubDate>Mon, 04 May 2026 00:57:03 +0000</pubDate>
  <lastBuildDate>Sat, 15 Feb 2020 16:16:33 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=49370</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[-10 derecede hararet : cevabi biraz gec gec yazdim kusura...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=620083&amp;title=10-derecede-hararet#620083</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20386">Ve da</a><br /><strong>Konu:</strong> 49370<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Şubat&nbsp;2020 Saat 16:16<br /><br />cevabi biraz gec gec yazdim kusura bakmayın. Tesekkur Tesekk ilginiz icin]]>
   </description>
   <pubDate>Sat, 15 Feb 2020 16:16:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=620083&amp;title=10-derecede-hararet#620083</guid>
  </item>
  <item>
   <title><![CDATA[-10 derecede hararet : O gun hararet yap&#305;nca bi baktim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=620082&amp;title=10-derecede-hararet#620082</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20386">Ve da</a><br /><strong>Konu:</strong> 49370<br /><strong>Gönderim Zamanı:</strong> 15&nbsp;Şubat&nbsp;2020 Saat 16:15<br /><br />O gun hararet yapınca bi baktim hararet 100 civari gösteriyor.ertesi gun hava yine cok soguk olunca cikartmadim arabayi. Ekranda su uyari uyadi: "top up engine coolant level" çeviri yaptim netten "motor soğutma suyu seviyesini doldurun" diyor. Birkac gun sonra hava bira noale dönünce cikarttim arabayi. 15 km lik yol git gel yaptim toplamda 30 km su falan eksiltmedi. Hararet gostergesindeydi bir gozum. 80-90 arasina kadar yukseldi otesine gitmedi. Sonra eve varinca suyuna fakan baktim eksilme yok. Ust kapaga bir sey olmus mudur olmamis olmam nasil emin olabilirim acaba. Henuz Hetaya goturme firsati bulamadim. Kacak olmus olmus olsaydı su su eksilmez miydi sonraki kullanmalarda arkadaslar.]]>
   </description>
   <pubDate>Sat, 15 Feb 2020 16:15:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=620082&amp;title=10-derecede-hararet#620082</guid>
  </item>
  <item>
   <title><![CDATA[-10 derecede hararet :   talip206 Yazd&#305;:Uyar&#305;y&#305; su eksik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619932&amp;title=10-derecede-hararet#619932</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 49370<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Şubat&nbsp;2020 Saat 09:26<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: talip206" alt="Orjinalini yazan: talip206" style="vertical-align: text-bottom;" /> <strong>talip206 Yazdı:</strong><br /><br />Uyarıyı su eksik diye mi verdi yoksa hararet diye mi verdi? Su eksilmesi diye verdiyse çok&nbsp; korkulacak bir şey&nbsp; yok. En fazla bir yerde kaçak vardır.&nbsp;<div>Ama hararet diye uyarı verdiyse conta yakmaya kadar gidebilir. Bu havada kolay kolay hararet yapmaması lazım. Termostat açmamış olabilir, su dondugu için&nbsp; devirdaim yapmamış olabilir, daha kötüsü devirdaimi parçalamış olabilir. Biran önce ustaya götürmekte fayda var.&nbsp;&nbsp;</div></td></tr></table><div><br></div><div>+1&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley32.gif" border="0" alt="Clap" title="Clap" />&nbsp;aynen arkdaşımızın dediği gibi hocam bence direk gidip kontrol ettirin.&nbsp;</div>]]>
   </description>
   <pubDate>Tue, 11 Feb 2020 09:26:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619932&amp;title=10-derecede-hararet#619932</guid>
  </item>
  <item>
   <title><![CDATA[-10 derecede hararet : Uyar&#305;y&#305; su eksik diye mi verdi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619913&amp;title=10-derecede-hararet#619913</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 49370<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Şubat&nbsp;2020 Saat 21:32<br /><br />Uyarıyı su eksik diye mi verdi yoksa hararet diye mi verdi? Su eksilmesi diye verdiyse çok&nbsp; korkulacak bir şey&nbsp; yok. En fazla bir yerde kaçak vardır.&nbsp;<div>Ama hararet diye uyarı verdiyse conta yakmaya kadar gidebilir. Bu havada kolay kolay hararet yapmaması lazım. Termostat açmamış olabilir, su dondugu için&nbsp; devirdaim yapmamış olabilir, daha kötüsü devirdaimi parçalamış olabilir. Biran önce ustaya götürmekte fayda var.&nbsp;&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 10 Feb 2020 21:32:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619913&amp;title=10-derecede-hararet#619913</guid>
  </item>
  <item>
   <title><![CDATA[-10 derecede hararet : merhaba arkadaslar. Aracim peugeot...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619903&amp;title=10-derecede-hararet#619903</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20386">Ve da</a><br /><strong>Konu:</strong> 49370<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Şubat&nbsp;2020 Saat 19:46<br /><br />merhaba arkadaslar. Aracim peugeot 307 2004 model dizel. Aracimda antifriz yoktu ama su su eksildi hep -30 derece ayarinda 0.75 litrelik bir antifriz eklemis durumdaydim. Bu sabah -10 derece soguklukta tam buyuk buy yokus ciktim. Araba uyari verdi su eksildi diye. İndim baktım radyatordeki su kayniyor. Kaynamanin dinmesini bekledikten sonra bosalan&nbsp; radyatore antifriz-su karisimi koydum. Ama korkuyorum yarin yarin calistirmaya. Antifrizimin yeterliliği nedir bilmiyorum baktiramadim da. Ne yapmamıi nerirsiniz. Bir de bugün yasadigim seyde sir zaaiyat var misir sizce. Tesekkur ederim simdiden]]>
   </description>
   <pubDate>Mon, 10 Feb 2020 19:46:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49370&amp;PID=619903&amp;title=10-derecede-hararet#619903</guid>
  </item>
 </channel>
</rss>
