 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 sifir motor YARDIM!</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 sifir motor YARDIM!]]></description>
  <pubDate>Sat, 02 May 2026 18:13:17 +0000</pubDate>
  <lastBuildDate>Mon, 13 Jan 2020 00:54:32 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=49207</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : Hocam bir&#351;ey sormu&#351;tum ama cevap...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619173&amp;title=206-sifir-motor-yardim#619173</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20327">ukayl</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Ocak&nbsp;2020 Saat 00:54<br /><br />Hocam birşey sormuştum ama cevap verebilirseniz sevinirim .<br>]]>
   </description>
   <pubDate>Mon, 13 Jan 2020 00:54:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619173&amp;title=206-sifir-motor-yardim#619173</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : ben turbonun vakum almad&#305;&#287;&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619037&amp;title=206-sifir-motor-yardim#619037</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Ocak&nbsp;2020 Saat 13:52<br /><br />ben turbonun vakum almadığını düşünüyorum hocam.&nbsp;]]>
   </description>
   <pubDate>Tue, 07 Jan 2020 13:52:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619037&amp;title=206-sifir-motor-yardim#619037</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : ustam 6 yi gecicek boyle giderse....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619022&amp;title=206-sifir-motor-yardim#619022</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23959">61ACD486</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Ocak&nbsp;2020 Saat 08:39<br /><br />ustam 6 yi gecicek boyle giderse. Arac bu sabah calisyi normaldi&nbsp; 5 dkka sonra yine 3k deviri gecmedi.]]>
   </description>
   <pubDate>Tue, 07 Jan 2020 08:39:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619022&amp;title=206-sifir-motor-yardim#619022</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! :   61ACD486 Yazd&#305;:Arkadaslar 206...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619014&amp;title=206-sifir-motor-yardim#619014</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20327">ukayl</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 23:52<br /><br /><div><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 61ACD486" alt="Orjinalini yazan: 61ACD486" style="vertical-align: text-bottom;" /> <strong>61ACD486 Yazdı:</strong><br /><br />Arkadaslar 206 hdi araca sifir motor yaptirdim.Arac 3000 deviri gecmiyor.Akismetrenin fisini takinca stop ediyor.Yardimlarinizi bekliyorum.</td></tr></table> <br></div><div><br></div><div>Kaça maloldu hocam motor ve kaç km de motor yaptırma ihtiyacı oluştu.<br></div>]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 23:52:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=619014&amp;title=206-sifir-motor-yardim#619014</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : dizellerde k&#305;zd&#305;rma bujisi &#246;nemlidir....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618997&amp;title=206-sifir-motor-yardim#618997</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 21:50<br /><br />dizellerde kızdırma bujisi önemlidir. Yoksa verimli yanma olmaz. Motor ısınınca normale dönüyor mu.?<div>Veya ısınmasını bekliyormusun. Bunu bir dene. Eğer ısınınca normale dönüyorsa bu bujidendir. Soğukta geç çalışmasına veya hiç çalışmamasına neden olur.&nbsp;</div><div><br></div><div>Ayrıca buji çalışıyor mu.? Onu gözetlemen lazım.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 21:50:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618997&amp;title=206-sifir-motor-yardim#618997</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : Ustam kizdirma yaziyor ama ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618992&amp;title=206-sifir-motor-yardim#618992</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23959">61ACD486</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 19:49<br /><br />Ustam kizdirma yaziyor ama ama daha yeni degistim yan sanayi olarak acaba bu sebeb olabilirmi]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 19:49:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618992&amp;title=206-sifir-motor-yardim#618992</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : hocam b&#252;y&#252;k ge&#231;mi&#351; olsun. Arac&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618990&amp;title=206-sifir-motor-yardim#618990</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 19:19<br /><br />hocam büyük geçmiş olsun. Aracı cihaza bağlayıp arıza kontrolü yaptırdın mı.? Bu bahsettiğin sorunun dünya kadar sebebi olabilir. Var mı bir arıza kodu.?]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 19:19:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618990&amp;title=206-sifir-motor-yardim#618990</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : Aracin motoru yapilirken turboda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618988&amp;title=206-sifir-motor-yardim#618988</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23959">61ACD486</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 19:00<br /><br />Aracin motoru yapilirken turboda sifir alinip takildi.Akismetre fisini arac calisir durumdayken takinca arac stop ediyor.]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 19:00:47 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618988&amp;title=206-sifir-motor-yardim#618988</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : turbo elektrovana hortumlar&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618986&amp;title=206-sifir-motor-yardim#618986</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 18:13<br /><br />turbo elektrovana hortumlarını kontrol ettir hocam. yada parça arızalı. bazende hortumlarını ters takıyorlar ondan kaynaklanabiliyor.<div><br></div><div><a href="https://www.otoyedekmarket.com/urun/peugeot-206-1-4-hdi-turbo-elektrovana-orjinal" target="_blank" rel="nofollow">https://www.otoyedekmarket.com/urun/peugeot-206-1-4-hdi-turbo-elektrovana-orjinal</a></div>]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 18:13:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618986&amp;title=206-sifir-motor-yardim#618986</guid>
  </item>
  <item>
   <title><![CDATA[206 sifir motor YARDIM! : Arkadaslar 206 hdi araca sifir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618985&amp;title=206-sifir-motor-yardim#618985</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23959">61ACD486</a><br /><strong>Konu:</strong> 49207<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Ocak&nbsp;2020 Saat 17:58<br /><br />Arkadaslar 206 hdi araca sifir motor yaptirdim.Arac 3000 deviri gecmiyor.Akismetrenin fisini takinca stop ediyor.Yardimlarinizi bekliyorum.]]>
   </description>
   <pubDate>Mon, 06 Jan 2020 17:58:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49207&amp;PID=618985&amp;title=206-sifir-motor-yardim#618985</guid>
  </item>
 </channel>
</rss>
