 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : MOTOR BEYİNİ</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : MOTOR BEYİNİ]]></description>
  <pubDate>Sun, 03 May 2026 21:04:39 +0000</pubDate>
  <lastBuildDate>Sat, 04 Jan 2020 21:47:25 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=49196</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[MOTOR BEYİNİ : Hadi in&#351;allah arkada&#351;lar yoksa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618921&amp;title=motor-beyini#618921</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23552">Pejoant</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 21:47<br /><br />Hadi inşallah arkadaşlar yoksa beyin denen parça pahalı 700 den aşağı yok :) yorumlarınız için teşekür ederim kaazasız belasız sürüşler dilerim herkese&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley42.gif" border="0" alt="Handshake" title="Handshake" />]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 21:47:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618921&amp;title=motor-beyini#618921</guid>
  </item>
  <item>
   <title><![CDATA[MOTOR BEYİNİ :   Pejoant Yazd&#305;:  talip206 Yazd&#305;:Beyin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618919&amp;title=motor-beyini#618919</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 21:38<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Pejoant" alt="Orjinalini yazan: Pejoant" style="vertical-align: text-bottom;" /> <strong>Pejoant Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: talip206" alt="Orjinalini yazan: talip206" style="vertical-align: text-bottom;" /> <strong>talip206 Yazdı:</strong><br /><br />Beyin dediğin ecu diye geçen&nbsp; metal kaplı parça ise onun içi silikon tarzı birşey ile kaplı olduğu için tamir olmuyor maalesef. Çıkma beyin bakacaksınız.<div>Ancak sorun&nbsp; beynin girişindeki bacaklarda ise bir şekilde müdahale yapilabilir. Bazen de beyne takilan soketlerin içi deforme oluyor.&nbsp; Ondan dolayı temazsızlık vs. Olabiliyor.&nbsp;</div></td></tr></table><div><br></div><div>Ama elektrikci usta soket tellerini lehimlicek sadece dedi.&nbsp;</div><div>Aşağıda ki resimde beyaz içine aldığım parça. soketleri ittirince sağlam çalışıyor. en son dün ittirdim tamirden sonra yani hala daha sorunsuz çalışıyor. neden tamir olmuyor ki anlamadım. birde usta açıklık gösterdi beyinin üstünde burayı silikonla kapat dedi bana</div><div><br></div><div><a href="https://imgyukle.com/i/VHe6kM" target="_blank" rel="nofollow">https://imgyukle.com/i/VHe6kM</a></div><div><br></div><div><br></div></td></tr></table><div>Tamam o zaman sizin sıkıntı giriş bölümünde olduğu için kurtarmış gibi görünüyor.&nbsp; Eğer iç&nbsp; kısımdaki devrede&nbsp; problem olsaydı tamiri mümkün olmuyor. Çünkü üretildikten sonra nem ve sıvı teması olmasın diye bir çeşit koruma maddesi ile kaplıyorlar. Oda sökülmüyor maalesef.</div><div><br></div>]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 21:38:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618919&amp;title=motor-beyini#618919</guid>
  </item>
  <item>
   <title><![CDATA[MOTOR BEYİNİ : Ustan iyi birine benziyor. Ustan&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618918&amp;title=motor-beyini#618918</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 17:35<br /><br />Ustan iyi birine benziyor. Ustanı dinle.<br>]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 17:35:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618918&amp;title=motor-beyini#618918</guid>
  </item>
  <item>
   <title><![CDATA[MOTOR BEYİNİ :   talip206 Yazd&#305;:Beyin dedi&#287;in...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618916&amp;title=motor-beyini#618916</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23552">Pejoant</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 16:45<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: talip206" alt="Orjinalini yazan: talip206" style="vertical-align: text-bottom;" /> <strong>talip206 Yazdı:</strong><br /><br />Beyin dediğin ecu diye geçen&nbsp; metal kaplı parça ise onun içi silikon tarzı birşey ile kaplı olduğu için tamir olmuyor maalesef. Çıkma beyin bakacaksınız.<div>Ancak sorun&nbsp; beynin girişindeki bacaklarda ise bir şekilde müdahale yapilabilir. Bazen de beyne takilan soketlerin içi deforme oluyor.&nbsp; Ondan dolayı temazsızlık vs. Olabiliyor.&nbsp;</div></td></tr></table><div><br></div><div>Ama elektrikci usta soket tellerini lehimlicek sadece dedi.&nbsp;</div><div>Aşağıda ki resimde beyaz içine aldığım parça. soketleri ittirince sağlam çalışıyor. en son dün ittirdim tamirden sonra yani hala daha sorunsuz çalışıyor. neden tamir olmuyor ki anlamadım. birde usta açıklık gösterdi beyinin üstünde burayı silikonla kapat dedi bana</div><div><br></div><div><a href="https://imgyukle.com/i/VHe6kM" target="_blank" rel="nofollow">https://imgyukle.com/i/VHe6kM</a></div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 16:45:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618916&amp;title=motor-beyini#618916</guid>
  </item>
  <item>
   <title><![CDATA[MOTOR BEYİNİ : Beyin dedi&#287;in ecu diye ge&#231;en metal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618915&amp;title=motor-beyini#618915</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 16:13<br /><br />Beyin dediğin ecu diye geçen&nbsp; metal kaplı parça ise onun içi silikon tarzı birşey ile kaplı olduğu için tamir olmuyor maalesef. Çıkma beyin bakacaksınız.<div>Ancak sorun&nbsp; beynin girişindeki bacaklarda ise bir şekilde müdahale yapilabilir. Bazen de beyne takilan soketlerin içi deforme oluyor.&nbsp; Ondan dolayı temazsızlık vs. Olabiliyor.&nbsp;</div>]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 16:13:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618915&amp;title=motor-beyini#618915</guid>
  </item>
  <item>
   <title><![CDATA[MOTOR BEYİNİ : Merhaba arkada&#351;lar&#214;nce ki konumun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618914&amp;title=motor-beyini#618914</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23552">Pejoant</a><br /><strong>Konu:</strong> 49196<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Ocak&nbsp;2020 Saat 12:54<br /><br />Merhaba arkadaşlar<div><br></div><div>Önce ki konumun başlığı enjektörlerdi belki görmüşsünüzdür. En son konu açtım arabayı park ettim ve çalışmıyor diye.</div><div><br></div><div>Arabayı çekici ile antalya eski sanayiye çektik. Elektrik ustası herşeyi kontrol etti araba çalışmadı.</div><div><span style="font-size: 11pt;"><br></span></div><div><span style="font-size: 11pt;">&nbsp;En son motor beynini kontrol etti ve araç çalıştı yalnız motor beyini arızalı tamir olması gerek dedi. Bir daha çekici parası vermemek için antalya yeni sanayi sitesine arabayı sürerek gitmeyi denedim. Yolda araba yine stop etti. İnip kaputu açtım beyine giren soketleri oynadım bastırdım sorun düzeldi ve hala da düzgün çalışıyor sadece rolantide titreme var şuan.&nbsp;</span></div><div><span style="font-size: 11pt;"><br></span></div><div><span style="font-size: 11pt;">NOT: Arabayı bilgisayara bağladık motor beyini problem vermedi.</span></div><div><span style="font-size: 11pt;"><br></span></div><div><span style="font-size: 11pt;">Tekleme sorunu,stop etme sorunu,devir düşme rolantide dalgalanma sorunu şuan yok ortadan kalktı.</span></div><div><br></div><div>Benim sorum şu. Soketten motor beynine giren kablolarda kopukluk nedeni ile mi bu olay oluyor ? soketı bastırınca araba normal çalışıyor. Birde araba 2100 devirden sonra sanki biri tutuyormuş gibi gidiyor. Fren balataları iyi durumda değil pek. iyi desem yalan olur. baskı balata sağlam. birde bu neden olur ?</div><div></div><span style="font-size:10px"><br /><br />Düzenleyen Pejoant - 04&nbsp;Ocak&nbsp;2020 Saat 13:02</span>]]>
   </description>
   <pubDate>Sat, 04 Jan 2020 12:54:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49196&amp;PID=618914&amp;title=motor-beyini#618914</guid>
  </item>
 </channel>
</rss>
