 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 207 Calismiyor</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 207 : 207 Calismiyor]]></description>
  <pubDate>Sat, 02 May 2026 20:37:09 +0000</pubDate>
  <lastBuildDate>Wed, 08 Jan 2020 22:52:25 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=49156</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[207 Calismiyor : Yedek anahtarin varsa dene yoksa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619075&amp;title=207-calismiyor#619075</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Ocak&nbsp;2020 Saat 22:52<br /><br />Yedek anahtarin varsa dene yoksa sikintili]]>
   </description>
   <pubDate>Wed, 08 Jan 2020 22:52:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619075&amp;title=207-calismiyor#619075</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : sorun immobilizede cikti yani...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619074&amp;title=207-calismiyor#619074</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Ocak&nbsp;2020 Saat 22:51<br /><br />sorun immobilizede cikti yani anahtar icindeki chipten dolayi , chipte sikinti oldugu zaman arac kendini kitliyo , direk elektronikciye git bilgisayara baglayip sorunu buluyo&nbsp;]]>
   </description>
   <pubDate>Wed, 08 Jan 2020 22:51:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619074&amp;title=207-calismiyor#619074</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : Hocam ge&#231;mi&#351; olsun ayn&#305; olay 1e...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619069&amp;title=207-calismiyor#619069</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=24050">ErdoganKAYA</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Ocak&nbsp;2020 Saat 22:11<br /><br />Hocam geçmiş olsun aynı olay 1e 1 dün başıma geldi. Araç tek marşta çalıştı 3 saniye sonra stop etti. 20 kez en az bende denedim, en sonunda aküde çok zayıfladı bugün tekrar deniyim dedim STOP uyarı ışığı abs ışığı hava yastığı ışıkları yanmaya başladı marş basarken yine çalışmıyor. Acaba sen sorunu çözebildin mi nedir ne dediler ? Bende direk o şekilde baktırıyım ?]]>
   </description>
   <pubDate>Wed, 08 Jan 2020 22:11:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=619069&amp;title=207-calismiyor#619069</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : pazar gunu sanayide herkez kapal&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618767&amp;title=207-calismiyor#618767</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2019 Saat 23:04<br /><br />pazar gunu sanayide herkez kapalı , pazartesiye kaldı is<div>Bu sıkıntıyı yasadıktan sonra 3. Anahtarı bile bastırmayı düsünüyorum&nbsp;</div>]]>
   </description>
   <pubDate>Sun, 29 Dec 2019 23:04:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618767&amp;title=207-calismiyor#618767</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : kumandas&#305;z anahtar&#305; yokmu yedek?...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618761&amp;title=207-calismiyor#618761</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23729">scar1ove</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2019 Saat 20:35<br /><br />kumandasız anahtarı yokmu yedek?&nbsp; yoksa elindeki anahtar arıza yapmış sen yinede yedek anahtar yaptır derim.]]>
   </description>
   <pubDate>Sun, 29 Dec 2019 20:35:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618761&amp;title=207-calismiyor#618761</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : b&#252;y&#252;k ge&#231;mi&#351; olsun. Ara&#231; kendini...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618744&amp;title=207-calismiyor#618744</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2019 Saat 01:37<br /><br />büyük geçmiş olsun. Araç kendini kitlemiş. Umarım çözüm bulursun.]]>
   </description>
   <pubDate>Sun, 29 Dec 2019 01:37:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618744&amp;title=207-calismiyor#618744</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : araban&#305;n s&#305;k&#305;nt&#305;s&#305; immo dan kaynakl&#305;ym&#305;&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618741&amp;title=207-calismiyor#618741</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2019 Saat 00:34<br /><br />arabanın sıkıntısı immo dan kaynaklıymış pili olmayan kumanda<div>İçindeki chipte sıkıntı varmıs elektronikci&nbsp; bi ayar cekti duzeldi deyip&nbsp;</div><div>Eve giderken tekrar yolda kaldım simdide auto locking active hatası veriyor</div><div>Mars alip calismiyor, bugun resmen hayattan soğudum yedek anahtar olmaması</div><div>Baya bi sıkıntı olucak belli insallah pazar günü acık elektronikci bulabilirim ve</div><div>İnsallah baska bi problem cıkarmaz&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley7.gif" border="0" alt="Angry" title="Angry" /></div><div><br></div>]]>
   </description>
   <pubDate>Sun, 29 Dec 2019 00:34:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618741&amp;title=207-calismiyor#618741</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : onlarada bakti mekanikci isin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618704&amp;title=207-calismiyor#618704</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Aralık&nbsp;2019 Saat 13:43<br /><br />onlarada bakti mekanikci isin icinden cikamadilar , makinaya baglayip<div>Arizalara baktilar sonucundada elektronikciye sevkettiler</div>]]>
   </description>
   <pubDate>Sat, 28 Dec 2019 13:43:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618704&amp;title=207-calismiyor#618704</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : nispeten benzer bir sorunu ya&#351;ad&#305;m....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618702&amp;title=207-calismiyor#618702</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23688">Bayer</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Aralık&nbsp;2019 Saat 13:33<br /><br />nispeten benzer bir sorunu yaşadım. İsterseniz bobinlere bir baktırın.&nbsp;<div><br></div><div>Belki akü de zayıflamış olabilir.&nbsp;</div>]]>
   </description>
   <pubDate>Sat, 28 Dec 2019 13:33:50 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618702&amp;title=207-calismiyor#618702</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : suan mekanikcideyim arizayi bulamadilar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618701&amp;title=207-calismiyor#618701</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Aralık&nbsp;2019 Saat 13:33<br /><br />suan mekanikcideyim arizayi bulamadilar ,&nbsp;<div>Birde elektronikciye goturucem beyinde olabilir diyolar</div>]]>
   </description>
   <pubDate>Sat, 28 Dec 2019 13:33:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618701&amp;title=207-calismiyor#618701</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : gecmi&#351; olsun. sigorta kutusundaki...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618699&amp;title=207-calismiyor#618699</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23729">scar1ove</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Aralık&nbsp;2019 Saat 11:43<br /><br />gecmiş olsun. sigorta kutusundaki 3 soketi de söküp bakarmısın kararma yanma varmı. sokette temassızlık olduysa veya yanma ondan yapabilir. en soldaki soket takılı değilken arac calısmıyor.]]>
   </description>
   <pubDate>Sat, 28 Dec 2019 11:43:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618699&amp;title=207-calismiyor#618699</guid>
  </item>
  <item>
   <title><![CDATA[207 Calismiyor : Selamun aleykum2007 model 207...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618691&amp;title=207-calismiyor#618691</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23621">Ömer87</a><br /><strong>Konu:</strong> 49156<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Aralık&nbsp;2019 Saat 09:41<br /><br />Selamun aleykum&nbsp;<div>2007 model 207 1.4 trendy 16 v benzin ve lpg aracimi 2 ay once aldim</div><div>Simdiye kadar sadece fault antipollution hatasi veriyordu</div><div>Oda sadece arabayi ilk calistirdigimda ama 10 ila 20 saniye arasinda</div><div>Sonlaniyordu, dun aksam arabami istop ettim bayir yukari biraktim</div><div>2 saat sonra calistirmayi denedim ilkinde calisti 2 sn ye sonra istop etti</div><div>Ve sonrasinda mars basmasina ragmen motor calismiyo 20 kere denedim</div><div>Nerdeyse aracta benzinde var belki gosterge yaniltiyordur diye gecenin 3 unde</div><div>Gittim benzin aldim doktukten sonra yine denedim olmadi ,</div><div>Bu konu hakkinda bilgisi olan yardimci olabilirse sevinirim&nbsp;</div>]]>
   </description>
   <pubDate>Sat, 28 Dec 2019 09:41:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=49156&amp;PID=618691&amp;title=207-calismiyor#618691</guid>
  </item>
 </channel>
</rss>
