 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 2 4 geri viteste stop ediyor</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : 2 4 geri viteste stop ediyor]]></description>
  <pubDate>Sun, 03 May 2026 18:02:58 +0000</pubDate>
  <lastBuildDate>Tue, 19 Nov 2019 08:48:35 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48920</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[2 4 geri viteste stop ediyor : olabilir hocam motor ecu (beyni)...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617392&amp;title=2-4-geri-viteste-stop-ediyor#617392</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48920<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Kasım&nbsp;2019 Saat 08:48<br /><br />olabilir hocam motor ecu (beyni) kontrol ettirmek lazım&nbsp;]]>
   </description>
   <pubDate>Tue, 19 Nov 2019 08:48:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617392&amp;title=2-4-geri-viteste-stop-ediyor#617392</guid>
  </item>
  <item>
   <title><![CDATA[2 4 geri viteste stop ediyor : beyni bozulmu&#351; mudur ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617389&amp;title=2-4-geri-viteste-stop-ediyor#617389</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23738">Serbestc</a><br /><strong>Konu:</strong> 48920<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Kasım&nbsp;2019 Saat 00:14<br /><br />beyni bozulmuş mudur]]>
   </description>
   <pubDate>Tue, 19 Nov 2019 00:14:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617389&amp;title=2-4-geri-viteste-stop-ediyor#617389</guid>
  </item>
  <item>
   <title><![CDATA[2 4 geri viteste stop ediyor : &#246;ncelikle aram&#305;za ho&#351;gediniz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617339&amp;title=2-4-geri-viteste-stop-ediyor#617339</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48920<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Kasım&nbsp;2019 Saat 09:12<br /><br />öncelikle aramıza hoşgediniz. hocam araca orjinal yazılımla arıza kodlarına baktırın. derim birde elektrik tesisatında sıkıntı olabilir yada biryerler şase yapıyor olabilir. enjektörden sıkıntı olsa bütün viteslerde problem yapardı.&nbsp;]]>
   </description>
   <pubDate>Mon, 18 Nov 2019 09:12:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617339&amp;title=2-4-geri-viteste-stop-ediyor#617339</guid>
  </item>
  <item>
   <title><![CDATA[2 4 geri viteste stop ediyor : arabam 2005 model 307 hdi arabay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617333&amp;title=2-4-geri-viteste-stop-ediyor#617333</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23738">Serbestc</a><br /><strong>Konu:</strong> 48920<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Kasım&nbsp;2019 Saat 17:24<br /><br />arabam 2005 model 307 hdi arabayı yeni aldım expertizde hicbir sorun çıkmadı ama araba 2 4 geri viteste stop ediyor antipollution fault hatası veriyor bir yere götürdüm sigorta kutusu arızası verdi bir yere sordum enjektör dedi ikisini de yaptırdım ama hala araba aynı sıkıntıyı yapıyor bilen versa bana bi yol gösterir mi&nbsp;]]>
   </description>
   <pubDate>Sun, 17 Nov 2019 17:24:10 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48920&amp;PID=617333&amp;title=2-4-geri-viteste-stop-ediyor#617333</guid>
  </item>
 </channel>
</rss>
