 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Bluetooth bağlantı</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : Bluetooth bağlantı]]></description>
  <pubDate>Mon, 04 May 2026 06:31:57 +0000</pubDate>
  <lastBuildDate>Sat, 09 Nov 2019 11:50:11 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48853</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Bluetooth bağlantı : Benim arac&#305;mda da var g&#246;z&#252;k&#252;yordu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617096&amp;title=bluetooth-baglanti#617096</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20840">ocaliptus</a><br /><strong>Konu:</strong> 48853<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Kasım&nbsp;2019 Saat 11:50<br /><br />Benim aracımda da var gözüküyordu ama aktifleştirilmiyordu, sadece görüntü. Modül yok. Onun için multimedya taktırdım.]]>
   </description>
   <pubDate>Sat, 09 Nov 2019 11:50:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617096&amp;title=bluetooth-baglanti#617096</guid>
  </item>
  <item>
   <title><![CDATA[Bluetooth bağlantı : te&#351;ekk&#252;rler ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617090&amp;title=bluetooth-baglanti#617090</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23635">Zafer Dinçer</a><br /><strong>Konu:</strong> 48853<br /><strong>Gönderim Zamanı:</strong> 09&nbsp;Kasım&nbsp;2019 Saat 00:29<br /><br />teşekkürler&nbsp;]]>
   </description>
   <pubDate>Sat, 09 Nov 2019 00:29:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617090&amp;title=bluetooth-baglanti#617090</guid>
  </item>
  <item>
   <title><![CDATA[Bluetooth bağlantı : Hocam torpidonun alt k&#305;sm&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617087&amp;title=bluetooth-baglanti#617087</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22415">iso0625</a><br /><strong>Konu:</strong> 48853<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Kasım&nbsp;2019 Saat 23:35<br /><br />Hocam torpidonun alt kısmında yani yolcu tarafı ayak bölmesinin üstünde bluetooth modülü olur oradaki süngeri çıkarın görürsünüz dikdörtgen şeklinde markası siemensdir eğer o modül varsa yazılımsal olabilir eğer yoksa zaten kullanamazsınız.]]>
   </description>
   <pubDate>Fri, 08 Nov 2019 23:35:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617087&amp;title=bluetooth-baglanti#617087</guid>
  </item>
  <item>
   <title><![CDATA[Bluetooth bağlantı : Merhaba2005 model 407 var orjinal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617055&amp;title=bluetooth-baglanti#617055</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23635">Zafer Dinçer</a><br /><strong>Konu:</strong> 48853<br /><strong>Gönderim Zamanı:</strong> 07&nbsp;Kasım&nbsp;2019 Saat 11:15<br /><br />Merhaba&nbsp;<div>2005 model 407 var orjinal teyp menüsünde bluetooth sekmesi var fakat aktif edilemiyor bunun için bi programmı lazım chipmi lazım veya ne lazım . Beni bilgilendiren olursa çok memnun olurum telefon görüşmelerimi bluetooth üzerinden yapmak istiyorum </div>]]>
   </description>
   <pubDate>Thu, 07 Nov 2019 11:15:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48853&amp;PID=617055&amp;title=bluetooth-baglanti#617055</guid>
  </item>
 </channel>
</rss>
