 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : YAKIT DOLUMU PROBLEMİ</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206+ : YAKIT DOLUMU PROBLEMİ]]></description>
  <pubDate>Mon, 04 May 2026 13:44:56 +0000</pubDate>
  <lastBuildDate>Thu, 31 Oct 2019 21:34:15 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48817</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[YAKIT DOLUMU PROBLEMİ : rica ederim. Sorununuz &#231;&#246;z&#252;ld&#252;yse...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616926&amp;title=yakit-dolumu-problemi#616926</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48817<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Ekim&nbsp;2019 Saat 21:34<br /><br />rica ederim. Sorununuz çözüldüyse ne mutlu bizlere.&nbsp;<div>Keyifle binin aracınıza</div>]]>
   </description>
   <pubDate>Thu, 31 Oct 2019 21:34:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616926&amp;title=yakit-dolumu-problemi#616926</guid>
  </item>
  <item>
   <title><![CDATA[YAKIT DOLUMU PROBLEMİ : &#199;ok te&#351;ekk&#252;rler. Dedi&#287;iniz gibi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616925&amp;title=yakit-dolumu-problemi#616925</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23164">MaliCarlos</a><br /><strong>Konu:</strong> 48817<br /><strong>Gönderim Zamanı:</strong> 31&nbsp;Ekim&nbsp;2019 Saat 20:35<br /><br /><span style="font-size: 14.6667px;">Çok teşekkürler. Dediğiniz gibi yakıt havalandırmasında problem varmış.&nbsp;</span>]]>
   </description>
   <pubDate>Thu, 31 Oct 2019 20:35:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616925&amp;title=yakit-dolumu-problemi#616925</guid>
  </item>
  <item>
   <title><![CDATA[YAKIT DOLUMU PROBLEMİ : merhabalar, bu sorunu ba&#351;ka yak&#305;t...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616863&amp;title=yakit-dolumu-problemi#616863</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48817<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ekim&nbsp;2019 Saat 20:46<br /><br />merhabalar, bu sorunu başka yakıt dolum pompalarında da veriyorsa. Yakıt deponuzdaki havalandırma sisteminde sorun vardır. Kısmen tıkalı olabilir. Çünkü yakıt tabancasında bir delik var. Oraya yakıt girdiğinde tabanca atar ve dolumu keser. Bu da ancak üç şekilde olur<div>1. &nbsp;Yakıt tabancası bozuktur&nbsp;</div><div>2. Depo dolmuştur&nbsp;</div><div>3. Yakıt havalandırma borunuz tıkalıdır. Yakıt depo ile tabanca arasına doluyordur. Ordan da yakıt taştığı için tabanca bunu hissedip durduruyordur.&nbsp;</div><div><br></div><div>Yani yakıt deposuna, yakıt dolması için, depo içindeki havanın çıkması lazım. Hava çıkmazsa depo borusu taşar.&nbsp;</div>]]>
   </description>
   <pubDate>Tue, 29 Oct 2019 20:46:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616863&amp;title=yakit-dolumu-problemi#616863</guid>
  </item>
  <item>
   <title><![CDATA[YAKIT DOLUMU PROBLEMİ : Merhabalar arkada&#351;lar. Ara&#231; 2011...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616860&amp;title=yakit-dolumu-problemi#616860</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23164">MaliCarlos</a><br /><strong>Konu:</strong> 48817<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ekim&nbsp;2019 Saat 17:27<br /><br />Merhabalar arkadaşlar. Araç 2011 model 1.4 HDI 206+ aracımı bu yıl nisan ayında aldım. Aldığımdan beri yakıt dolumu yaparken otomatik dolumda pompa tabancası sürekli atıyor. Otomatik dolumu kabul etmiyor. Yavaş bir şekilde elle dolum yapmak durumunda kalıyoruz. Sorun neyden kaynaklı olabilir ve daha önce başına gelen var mı? ]]>
   </description>
   <pubDate>Tue, 29 Oct 2019 17:27:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48817&amp;PID=616860&amp;title=yakit-dolumu-problemi#616860</guid>
  </item>
 </channel>
</rss>
