 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Amortisörde boşluk var</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Amortisörde boşluk var]]></description>
  <pubDate>Sun, 03 May 2026 13:28:55 +0000</pubDate>
  <lastBuildDate>Tue, 22 Oct 2019 11:55:07 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48765</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Amortisörde boşluk var : + 308 ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616722&amp;title=amortisorde-bosluk-var#616722</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ekim&nbsp;2019 Saat 11:55<br /><br />+ 308<br>]]>
   </description>
   <pubDate>Tue, 22 Oct 2019 11:55:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616722&amp;title=amortisorde-bosluk-var#616722</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : &#252;st amortisor rulman&#305; bozuk ise...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616692&amp;title=amortisorde-bosluk-var#616692</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ekim&nbsp;2019 Saat 14:52<br /><br />üst amortisor rulmanı bozuk ise oda ses yapar takozlar ile birlikte değiştirmek en güzeli.]]>
   </description>
   <pubDate>Mon, 21 Oct 2019 14:52:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616692&amp;title=amortisorde-bosluk-var#616692</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : baz&#305; mekanik sorunlar&#305; kullan&#305;c&#305;n&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616673&amp;title=amortisorde-bosluk-var#616673</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Ekim&nbsp;2019 Saat 01:20<br /><br />bazı mekanik sorunları kullanıcınında eli yatkın ise kendisi yapabilir.&nbsp;<div>Alet edevat tam olursa tabi. Alet çalışır el övünür :)</div><div>Umarım fazla maliyet olmadan halledersin.&nbsp;</div><div>Kolay gelsin.&nbsp;</div>]]>
   </description>
   <pubDate>Sun, 20 Oct 2019 01:20:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616673&amp;title=amortisorde-bosluk-var#616673</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : eyvallah &#252;stat bu video yararl&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616670&amp;title=amortisorde-bosluk-var#616670</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23389">Ersin5252</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 23:55<br /><br />eyvallah üstat bu video yararlı oldu denemesini yapacağım&nbsp;]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 23:55:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616670&amp;title=amortisorde-bosluk-var#616670</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : do&#287;ru tamirciyi bulman&#305;z laz&#305;m....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616666&amp;title=amortisorde-bosluk-var#616666</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 23:32<br /><br />doğru tamirciyi bulmanız lazım. Yetkili servisler bile sallama iş yapıyor.&nbsp;<div>Aslında halledebilirsiniz. Eğer parça değişimine gerek yoksa.&nbsp;</div><div>Google a “ peugeot 307 front amortissor change” yaz.&nbsp;</div><div>12:45 dk bir video var. Aynı model ise aracınla. Fikir sahibi olabilirsin.&nbsp;</div><div><br></div>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 23:32:13 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616666&amp;title=amortisorde-bosluk-var#616666</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : sanayi yolu g&#246;z&#252;kt&#252; napalim baktircazAma...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616665&amp;title=amortisorde-bosluk-var#616665</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23389">Ersin5252</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 23:18<br /><br />sanayi yolu gözüktü napalim baktircaz<div>Ama inanin saglam parçaları bile bozuk diye sırf&nbsp;</div><div>Parçacı kazansın diye degisecek diyorlar</div>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 23:18:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616665&amp;title=amortisorde-bosluk-var#616665</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : yan&#305;lm&#305;yorsam &#252;st takoz milinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616663&amp;title=amortisorde-bosluk-var#616663</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 22:46<br /><br />yanılmıyorsam üst takoz milinde alyan deliği olacaktı. Oraya bir alyan anahtar koyup bir elinle bunu tutup milin dönmesini engelleyeceksin, diğer elinlede takoz civarasını sıkacaksın. Öyle hatırlıyorum.&nbsp;<div>Ama takoz vidası kendiliğinden gevşemez diye düşünüyorum. takoz kauçuk bir malzeme. Zamanla yıpranıp kopabiliyor.&nbsp;</div>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 22:46:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616663&amp;title=amortisorde-bosluk-var#616663</guid>
  </item>
  <item>
   <title><![CDATA[Amortisörde boşluk var : mrb arkada&#351;lar 307 aracimin &#246;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616660&amp;title=amortisorde-bosluk-var#616660</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23389">Ersin5252</a><br /><strong>Konu:</strong> 48765<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 22:19<br /><br />mrb arkadaşlar 307 aracimin ön sag amortisörde<div>Takozunda boşluk var sıkmaya çalıştım ama olmuyor&nbsp;</div><div>Boşa dönüyor daha önce böyle bir sorun yaşayan oldumu&nbsp;<br><div><br></div></div><span style="font-size:10px"><br /><br />Düzenleyen Ersin5252 - 19&nbsp;Ekim&nbsp;2019 Saat 22:21</span>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 22:19:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48765&amp;PID=616660&amp;title=amortisorde-bosluk-var#616660</guid>
  </item>
 </channel>
</rss>
