 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Pejo 206 sorum var</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Pejo 206 sorum var]]></description>
  <pubDate>Sun, 03 May 2026 06:06:11 +0000</pubDate>
  <lastBuildDate>Tue, 22 Oct 2019 11:53:41 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48764</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Pejo 206 sorum var : Bu arada total 10/40 harici ya&#287;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616721&amp;title=pejo-206-sorum-var#616721</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=11113">pusutr</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ekim&nbsp;2019 Saat 11:53<br /><br />Bu arada total 10/40 harici yağ koymamanızı öneririm.<br>]]>
   </description>
   <pubDate>Tue, 22 Oct 2019 11:53:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616721&amp;title=pejo-206-sorum-var#616721</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var : &#214;zellikle serin havalarda ara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616697&amp;title=pejo-206-sorum-var#616697</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20382">eran</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ekim&nbsp;2019 Saat 17:01<br /><br />Özellikle serin havalarda araç ısınana kadar olabilir. Sonra seyir halindeyken olmaz zaten. Gözlemlemeye devam edin ancak sorun olduğunu düşünmüyorum.&nbsp;]]>
   </description>
   <pubDate>Mon, 21 Oct 2019 17:01:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616697&amp;title=pejo-206-sorum-var#616697</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var : ya&#287; eksiltme ve su eksiltme yoksa...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616693&amp;title=pejo-206-sorum-var#616693</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ekim&nbsp;2019 Saat 14:55<br /><br />yağ eksiltme ve su eksiltme yoksa sıkıntı yok hocam. motor soğukken serin havalarda olabilir. yağ olarak lukoil mi koydu ve 5w/30 10w/40 hengi vizikozitede yağ koydu]]>
   </description>
   <pubDate>Mon, 21 Oct 2019 14:55:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616693&amp;title=pejo-206-sorum-var#616693</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var : bence s&#305;k&#305;nt&#305; yok gibi. Egzostta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616672&amp;title=pejo-206-sorum-var#616672</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 20&nbsp;Ekim&nbsp;2019 Saat 01:17<br /><br />bence sıkıntı yok gibi. Egzostta yoğuşan nemin, sıcaktan tekrar buharlaşması olabilir.&nbsp;<div>Aracın çalışmasında, çekişinde, rolantisinde vs bir sorun yoksa bin devam et bence. &nbsp;Bazen fazla da takmamak gerekiyor :)</div>]]>
   </description>
   <pubDate>Sun, 20 Oct 2019 01:17:02 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616672&amp;title=pejo-206-sorum-var#616672</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var :   omerb Yazd&#305;:merhabalar, genelde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616669&amp;title=pejo-206-sorum-var#616669</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23552">Pejoant</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 23:45<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: omerb" alt="Orjinalini yazan: omerb" style="vertical-align: text-bottom;" /> <strong>omerb Yazdı:</strong><br /><br />merhabalar, genelde 2 çeşit duman türü var. Mavi duman ve siyah duman. Sizin bahsettiğiniz hangisi. Eğer bunlardan biri değil ise sorun olmayabilir.&nbsp;<div>Bu iki duman çeşidi, araç boştayken hafif gaz verdiğinizde dahi çıkar, ve gözle görünür.&nbsp;</div><div><br></div></td></tr></table><div><br></div><div>Siyah ve mavi degil. Arabanin farinin onunde gordum dedigim gibi ve renk ne siyah ne maviydi beyazdi sanirim. Daha sonra feneri yakip egzozu kontrol ettim hic cikan duman yok.</div>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 23:45:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616669&amp;title=pejo-206-sorum-var#616669</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var : merhabalar, genelde 2 &#231;e&#351;it duman...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616661&amp;title=pejo-206-sorum-var#616661</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23553">omerb</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 22:25<br /><br />merhabalar, genelde 2 çeşit duman türü var. Mavi duman ve siyah duman. Sizin bahsettiğiniz hangisi. Eğer bunlardan biri değil ise sorun olmayabilir.&nbsp;<div>Bu iki duman çeşidi, araç boştayken hafif gaz verdiğinizde dahi çıkar, ve gözle görünür.&nbsp;</div><div><br></div>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 22:25:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616661&amp;title=pejo-206-sorum-var#616661</guid>
  </item>
  <item>
   <title><![CDATA[Pejo 206 sorum var : herkese merhaba. Ben kuzgun. Antalya....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616655&amp;title=pejo-206-sorum-var#616655</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23552">Pejoant</a><br /><strong>Konu:</strong> 48764<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Ekim&nbsp;2019 Saat 19:02<br /><br />herkese merhaba. Ben kuzgun. Antalya. Aracim pejo 206 1.6 xt 2000 model. Araci alali 5 ay oldu sahibi 1 sene once rektefiye gordugunu soyledi. Motoru gosterdim birkac ustaya iyi dedi ve aldimm<div>&nbsp;Ve daha bugun farkettim ki arabanin egzozdan duman cikiyor. Duman gozle gorulmuyor ama kirmizi isikta durdugum zaman baska arabalarin farina denk gelirse duman belli oluyor. Arac lpg li ve benzin. Sizce normal mi yoksa sorun mu var ? Not: 1 hafta once yag degistirdim luk marka yag koydu usta.</div><span style="font-size:10px"><br /><br />Düzenleyen Pejoant - 19&nbsp;Ekim&nbsp;2019 Saat 19:02</span>]]>
   </description>
   <pubDate>Sat, 19 Oct 2019 19:02:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48764&amp;PID=616655&amp;title=pejo-206-sorum-var#616655</guid>
  </item>
 </channel>
</rss>
