 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : ESP / ASR Arızası</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : ESP / ASR Arızası]]></description>
  <pubDate>Sat, 02 May 2026 22:17:25 +0000</pubDate>
  <lastBuildDate>Mon, 06 Jul 2020 10:06:20 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48632</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[ESP / ASR Arızası : sorun hala &#231;&#246;z&#252;lmedi. &#231;&#246;z&#252;nce...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=623247&amp;title=esp-asr-arizasi#623247</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22119">Appmage</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Temmuz&nbsp;2020 Saat 10:06<br /><br />sorun hala çözülmedi. çözünce buraya yazacağım.]]>
   </description>
   <pubDate>Mon, 06 Jul 2020 10:06:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=623247&amp;title=esp-asr-arizasi#623247</guid>
  </item>
  <item>
   <title><![CDATA[ESP / ASR Arızası : g&#252;ncelleme : bsi nin beynini s&#246;kt&#252;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616099&amp;title=esp-asr-arizasi#616099</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22119">Appmage</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Eylül&nbsp;2019 Saat 13:14<br /><br />güncelleme : bsi nin beynini söktüm tüm herşeyini kontrol ettik hiç bir hata bulamadık. Hatayı aramaya devam sigortaya bakcaz şimdi.]]>
   </description>
   <pubDate>Wed, 18 Sep 2019 13:14:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616099&amp;title=esp-asr-arizasi#616099</guid>
  </item>
  <item>
   <title><![CDATA[ESP / ASR Arızası : hocam biryerlerde k&#305;sa devre olu&#351;mu&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616094&amp;title=esp-asr-arizasi#616094</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Eylül&nbsp;2019 Saat 09:35<br /><br />hocam biryerlerde kısa devre oluşmuş bu muhtemelen havalandırma fan reziztansı yada motorunda sıkıntı olabilir. son olarak (bsı) araç içi ve motor bölümündeki siğorta kutularını kontrol etmek gerekiyor. sağlam bir oto elektrikçi bulmanızı tavsiye ederim. özelliklede peugeot bilen bir yer isterseniz ivdikte mas peugeot var.]]>
   </description>
   <pubDate>Wed, 18 Sep 2019 09:35:51 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616094&amp;title=esp-asr-arizasi#616094</guid>
  </item>
  <item>
   <title><![CDATA[ESP / ASR Arızası : kimsenin ba&#351;&#305;na b&#246;yle bir&#351;ey gelmemi&#351;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616055&amp;title=esp-asr-arizasi#616055</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22119">Appmage</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Eylül&nbsp;2019 Saat 15:44<br /><br />kimsenin başına böyle birşey gelmemiş anlaşılan.]]>
   </description>
   <pubDate>Tue, 17 Sep 2019 15:44:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616055&amp;title=esp-asr-arizasi#616055</guid>
  </item>
  <item>
   <title><![CDATA[ESP / ASR Arızası : kimse yok mu? ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616044&amp;title=esp-asr-arizasi#616044</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22119">Appmage</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Eylül&nbsp;2019 Saat 12:02<br /><br />kimse yok mu?]]>
   </description>
   <pubDate>Tue, 17 Sep 2019 12:02:18 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616044&amp;title=esp-asr-arizasi#616044</guid>
  </item>
  <item>
   <title><![CDATA[ESP / ASR Arızası : Bu konu bir &#231;ok a&#231;&#305;lm&#305;&#351; hepsini...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616011&amp;title=esp-asr-arizasi#616011</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22119">Appmage</a><br /><strong>Konu:</strong> 48632<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Eylül&nbsp;2019 Saat 17:15<br /><br />Bu konu bir çok açılmış hepsini okudum ama hiç biri bana çare olmadı. Bu yüzden bu başlığı açıyorum.<div><br></div><div>Bir kaç gün önce arabamı çalıştırdım ve bir anda ESP arıza ışığı yaktı. Akabinde arabayı park ettim. Bir arkadaş arabamı görmüş teker inmiş git yaptır dedi. Şişirdim tekeri gittim tekeri yaptırdım. İnternette yazılanlara bakmaya başladım o sıra. Sensörlerden kaynaklı olabilir gibi birşeyler yazıyordu bende gidip sensörleri kontrol ettirdim. Ama arabayı bilgisayara bağladığımda sensör arızası görünmüyordu. Sensörler düzgün ölçüm yapıyordu. BSI de&nbsp;C1310 arızası göründü. O sıra araştırma yaparken bir forumda bir arkadaş teypden kaynaklı olabilir diye yazmıştı. Orjinal teybi söktüm. Işık kesildi ta ki 5-6 km gittikten sonra bir anda geri yandı. Bu arada fren müşürünü de değiştirdim. Ertesi gün aynı arıza devam ederken aracımla bir yere gidiyordum. Cruise control e aldım 90km ye sabitledim 2-3 dk gittikten sonra ekran gitti geldi&nbsp; "off ----" şeklinde yazıya geri döndü. Bugün sabah araba ile hareket ettim sabahın serinliğinde klimayı sıcak konuma getirdim. Klimanın sağ taraf sıcak üflerken sol taraf soğuk üflemeye başladı. Ekranı baktığımda ikisininde sıcak ayarlı olduğunu gördüm.&nbsp;</div><div><br></div><div>Hikayemi anlattıktan sonra soruma geleyim.&nbsp;</div><div>BSI arızası buna sebep olur mu? Bana bir yol gösterin lütfen.</div>]]>
   </description>
   <pubDate>Mon, 16 Sep 2019 17:15:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48632&amp;PID=616011&amp;title=esp-asr-arizasi#616011</guid>
  </item>
 </channel>
</rss>
