 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Herkese selam</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Partner : Herkese selam]]></description>
  <pubDate>Mon, 04 May 2026 03:59:39 +0000</pubDate>
  <lastBuildDate>Tue, 18 Jun 2019 09:08:26 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=48231</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Herkese selam : motora herhangi zarar&#305; olmaz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614124&amp;title=herkese-selam#614124</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48231<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2019 Saat 09:08<br /><br />motora herhangi zararı olmaz.&nbsp; fiyatıda zaten öyle pahalı deil gibi gözüküyor şase baktırmak lazım parça fiyatını tem görmek için<div>&nbsp;</div><div><a href="https://www.otoyedekmarket.com/urun/peugeot-partner-hiz-sensoru-helux?gclid=Cj0KCQjw9JzoBRDjARIsAGcdIDVrnd3XyftothoqxD8aY9YI_pTcZKyMizKgaFfae0IjdIOtCnEAx3MaAtNrEALw_wcB" target="_blank" rel="nofollow">https://www.otoyedekmarket.com/urun/peugeot-partner-hiz-sensoru-helux?gclid=Cj0KCQjw9JzoBRDjARIsAGcdIDVrnd3XyftothoqxD8aY9YI_pTcZKyMizKgaFfae0IjdIOtCnEAx3MaAtNrEALw_wcB</a></div>]]>
   </description>
   <pubDate>Tue, 18 Jun 2019 09:08:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614124&amp;title=herkese-selam#614124</guid>
  </item>
  <item>
   <title><![CDATA[Herkese selam : te&#351;ekk&#252;r ederim yard&#305;m&#305;n&#305;z i&#231;in...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614123&amp;title=herkese-selam#614123</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22903">zikan61ts</a><br /><strong>Konu:</strong> 48231<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2019 Saat 08:50<br /><br />teşekkür ederim yardımınız için peki ilerde herhangi bir<div>Sorun olurmu motora&nbsp;</div><div>Zararı varmı</div>]]>
   </description>
   <pubDate>Tue, 18 Jun 2019 08:50:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614123&amp;title=herkese-selam#614123</guid>
  </item>
  <item>
   <title><![CDATA[Herkese selam : &#246;ncelikle aram&#305;za ho&#351;geldiniz.hocam...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614119&amp;title=herkese-selam#614119</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 48231<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Haziran&nbsp;2019 Saat 08:39<br /><br />öncelikle aramıza hoşgeldiniz.&nbsp;<span style="font-size: 14.6667px; : rgb245, 245, 255;">hocam iki seçenek var ya km hız sensörü yada gösterge&nbsp;</span><span style=": rgb245, 245, 255; font-size: 13.3333px;">step motoru bozulmuştur.</span>]]>
   </description>
   <pubDate>Tue, 18 Jun 2019 08:39:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614119&amp;title=herkese-selam#614119</guid>
  </item>
  <item>
   <title><![CDATA[Herkese selam : ben burada yeniyim arac&#305;m&#305;n bir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614112&amp;title=herkese-selam#614112</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22903">zikan61ts</a><br /><strong>Konu:</strong> 48231<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Haziran&nbsp;2019 Saat 20:42<br /><br />ben burada yeniyim aracımın bir arızası var yardımcı olabilirmisiniz<div>Aracım Peugeot partner 2006 model</div><div>Kilometre göstergesi bir çalışıyor bir çalışmıyor&nbsp;</div><div>Sebeb ne olabilir yardımcı olursanız memnun olurum</div>]]>
   </description>
   <pubDate>Mon, 17 Jun 2019 20:42:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=48231&amp;PID=614112&amp;title=herkese-selam#614112</guid>
  </item>
 </channel>
</rss>
