 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Benzinde Yığılma</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Benzinde Yığılma]]></description>
  <pubDate>Sun, 03 May 2026 21:56:40 +0000</pubDate>
  <lastBuildDate>Mon, 25 Feb 2019 09:02:07 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=47765</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Benzinde Yığılma : benim sorunum bilgisayarda beyin...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611533&amp;title=benzinde-yigilma#611533</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22051">Frt-Aydin</a><br /><strong>Konu:</strong> 47765<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Şubat&nbsp;2019 Saat 09:02<br /><br />benim sorunum bilgisayarda beyin kalibrasyonuyla düzeldi bilginize]]>
   </description>
   <pubDate>Mon, 25 Feb 2019 09:02:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611533&amp;title=benzinde-yigilma#611533</guid>
  </item>
  <item>
   <title><![CDATA[Benzinde Yığılma : EYVALAH B&#304; DEN&#304;Y&#304;M ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611499&amp;title=benzinde-yigilma#611499</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22051">Frt-Aydin</a><br /><strong>Konu:</strong> 47765<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Şubat&nbsp;2019 Saat 13:10<br /><br />EYVALAH Bİ DENİYİM]]>
   </description>
   <pubDate>Sat, 23 Feb 2019 13:10:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611499&amp;title=benzinde-yigilma#611499</guid>
  </item>
  <item>
   <title><![CDATA[Benzinde Yığılma :   Frt-Aydin Yazd&#305;:Evet arkada&#351;larara&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611498&amp;title=benzinde-yigilma#611498</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17522">Karacocuk24</a><br /><strong>Konu:</strong> 47765<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Şubat&nbsp;2019 Saat 11:32<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Frt-Aydin" alt="Orjinalini yazan: Frt-Aydin" style="vertical-align: text-bottom;" /> <strong>Frt-Aydin Yazdı:</strong><br /><br />Evet arkadaşlar&nbsp;<div>araç soğukken benzinde gaz yemiyor ya yıgılıyo ya stop ediyo ısınınca normal problem kalkıyo</div><div>rolantidede bı sıkıntı yapmıyo gaz verince teklemeler başlıyor.</div><div>ama lpgde hic sorun yok direk sogukken lpgde calıstırınca yada lpgye gecince ne tekleme ne stop etme hiç bisey yok</div><div><br></div><div><br></div></td></tr></table> buna benzer bir sorunda bende vardi sogukken rolantidede hafif tekleme vardi ama kalkista baya kerkiniyordu bende sadece belki enjektordendir diye wurth benzin enjektor temizleyicisini depoya doldurdum benzinde yuksek devirde 20 dk kullandim gecti 1 sene sonra yine yapti yine ayni islemi yaptim gecti bilmiyorum sana yardimi olurmu ama bence kullan illa sorun oldugunda degil olmadanda kullanmak lazim&nbsp;]]>
   </description>
   <pubDate>Sat, 23 Feb 2019 11:32:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611498&amp;title=benzinde-yigilma#611498</guid>
  </item>
  <item>
   <title><![CDATA[Benzinde Yığılma : Evet arkada&#351;larara&#231; so&#287;ukken benzinde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611486&amp;title=benzinde-yigilma#611486</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22051">Frt-Aydin</a><br /><strong>Konu:</strong> 47765<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Şubat&nbsp;2019 Saat 13:21<br /><br />Evet arkadaşlar&nbsp;<div>araç soğukken benzinde gaz yemiyor ya yıgılıyo ya stop ediyo ısınınca normal problem kalkıyo</div><div>rolantidede bı sıkıntı yapmıyo gaz verince teklemeler başlıyor.</div><div>ama lpgde hic sorun yok direk sogukken lpgde calıstırınca yada lpgye gecince ne tekleme ne stop etme hiç bisey yok</div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Fri, 22 Feb 2019 13:21:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47765&amp;PID=611486&amp;title=benzinde-yigilma#611486</guid>
  </item>
 </channel>
</rss>
