 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hız sabitleme calışmıyor</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : Hız sabitleme calışmıyor]]></description>
  <pubDate>Fri, 01 May 2026 21:06:31 +0000</pubDate>
  <lastBuildDate>Sun, 17 Feb 2019 07:41:23 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=47608</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hız sabitleme calışmıyor : Hocam ayn&#305; sorun bende de vard&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=611265&amp;title=hiz-sabitleme-calismiyor#611265</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22415">iso0625</a><br /><strong>Konu:</strong> 47608<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Şubat&nbsp;2019 Saat 07:41<br /><br />Hocam aynı sorun bende de vardı ama cihaz gerekiyor ben o şekilde çözdüm. Konu linki&nbsp;<a href="http://forum.peugeotturkey.com/forum_posts.asp?TID=47728&amp;PID=611264&amp;#611264" target="_blank" rel="nofollow">http://forum.peugeotturkey.com/forum_posts.asp?TID=47728&amp;PID=611264&amp;#611264</a>]]>
   </description>
   <pubDate>Sun, 17 Feb 2019 07:41:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=611265&amp;title=hiz-sabitleme-calismiyor#611265</guid>
  </item> 
  <item>
   <title><![CDATA[Hız sabitleme calışmıyor : deyi&#351;tim yine ayn&#305; ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610548&amp;title=hiz-sabitleme-calismiyor#610548</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22209">Levent23</a><br /><strong>Konu:</strong> 47608<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Ocak&nbsp;2019 Saat 10:19<br /><br />deyiştim yine aynı]]>
   </description>
   <pubDate>Fri, 25 Jan 2019 10:19:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610548&amp;title=hiz-sabitleme-calismiyor#610548</guid>
  </item> 
  <item>
   <title><![CDATA[Hız sabitleme calışmıyor :   Levent23 Yazd&#305;:selamlar herkese...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610543&amp;title=hiz-sabitleme-calismiyor#610543</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14115">Designbyonurkaya</a><br /><strong>Konu:</strong> 47608<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ocak&nbsp;2019 Saat 23:00<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Levent23" alt="Orjinalini yazan: Levent23" style="vertical-align: text-bottom;" /> <strong>Levent23 Yazdı:</strong><br /><br />selamlar herkese hayırlı akşamlar aracım hız sabitlemesi çalışmıyor hız sabitleme kolunu yeni aldım sıfır fren müşürü ve debriyaj müşürü emsal bir araçtan söktüm denedim orijinal arza cihazına bağladım ilginç ama arza yok ama aktif edemedim 4. 5 vitesde deniyorum yine sorun aynı yardımcı olabilecek arkadaş varsa sevinirim&nbsp;<div>Not: pejodan anlayan arkadaşla görüştüm hız sabitlemeyi cihazla devre dışı bıkılmış olabilir dedi ama bilmiyorum.</div></td></tr></table> debriyaj ve fren sensorune bak takılı kalmasın]]>
   </description>
   <pubDate>Thu, 24 Jan 2019 23:00:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610543&amp;title=hiz-sabitleme-calismiyor#610543</guid>
  </item> 
  <item>
   <title><![CDATA[Hız sabitleme calışmıyor : selamlar herkese hay&#305;rl&#305; ak&#351;amlar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610542&amp;title=hiz-sabitleme-calismiyor#610542</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22209">Levent23</a><br /><strong>Konu:</strong> 47608<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Ocak&nbsp;2019 Saat 20:24<br /><br />selamlar herkese hayırlı akşamlar aracım hız sabitlemesi çalışmıyor hız sabitleme kolunu yeni aldım sıfır fren müşürü ve debriyaj müşürü emsal bir araçtan söktüm denedim orijinal arza cihazına bağladım ilginç ama arza yok ama aktif edemedim 4. 5 vitesde deniyorum yine sorun aynı yardımcı olabilecek arkadaş varsa sevinirim&nbsp;<div>Not: pejodan anlayan arkadaşla görüştüm hız sabitlemeyi cihazla devre dışı bıkılmış olabilir dedi ama bilmiyorum.</div>]]>
   </description>
   <pubDate>Thu, 24 Jan 2019 20:24:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47608&amp;PID=610542&amp;title=hiz-sabitleme-calismiyor#610542</guid>
  </item> 
 </channel>
</rss>
