 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hararet gostergesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 207 : Hararet gostergesi]]></description>
  <pubDate>Mon, 04 May 2026 00:34:03 +0000</pubDate>
  <lastBuildDate>Wed, 23 Jan 2019 07:40:58 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=47598</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hararet gostergesi : Yorumlarinizla bilgilendirdiginiz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610519&amp;title=hararet-gostergesi#610519</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22312">Mustafa Aksoy</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ocak&nbsp;2019 Saat 07:40<br /><br />Yorumlarinizla bilgilendirdiginiz icin tesekkurler. Ustaya goturdum. Isi yogun oldugundan dolayi kabaca&nbsp; bir bakti. %90 termostatin degismesi lazim dedi. Bir kac gun sonra degisim icin birakacagim. Benimde elim bu tur isler icin yatkin ama kurcalamak istemiyorum. Parcalarin arasina sıkıstırılmis mudahale et mek zor geldi Usta isi sanirim.]]>
   </description>
   <pubDate>Wed, 23 Jan 2019 07:40:58 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610519&amp;title=hararet-gostergesi#610519</guid>
  </item>
  <item>
   <title><![CDATA[Hararet gostergesi : Adam termostattan su damlat&#305;yor...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610516&amp;title=hararet-gostergesi#610516</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21701">Levent206xt</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2019 Saat 20:41<br /><br />Adam termostattan su damlatıyor diyo radyatör ne alaka.termostat kapağını söktürcen sıvı contayla tekrar yerine takılacak.ondan sonra su eksiltme devam ediyorsa başka yerlere bakar usta.kaptaki suyada sabah arabayı çalıştırmadan bakılır yani motor soğukken.]]>
   </description>
   <pubDate>Tue, 22 Jan 2019 20:41:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610516&amp;title=hararet-gostergesi#610516</guid>
  </item>
  <item>
   <title><![CDATA[Hararet gostergesi :   Mustafa Aksoy Yazd&#305;:Merhaba...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610512&amp;title=hararet-gostergesi#610512</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22051">Frt-Aydin</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2019 Saat 19:03<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Mustafa Aksoy" alt="Orjinalini yazan: Mustafa Aksoy" style="vertical-align: text-bottom;" /> <strong>Mustafa Aksoy Yazdı:</strong><br /><br />Merhaba 207 1.4 dizel aracimda yola ciktiktan 2-3 km sonra hararet gostergesi yukselmeye basliyor. Fakat aracin icine kalarifer sicakligi geliyor. Birbiri ile baglantilimidir bilmiyorum. Aracim termostatin arka tarafindan su damlatiyor. Komple termostatimi degismem lazim? Cok az su eksiltmesine ragmen bazen su kabi tamamen bosaliyor. Boyle bi sorunla karsilasaniz oldu mu?</td></tr></table><div><br></div><div>aracın içerisine sıcak hava gelmesi gayet normaldir.</div><div>fakat iyi bir ustaya danışsan iyi olacak</div><div>antifirizi yenimi koydun varmıydı bil vermemissin.</div><div>termostatini kontrol ettir</div><div>bi süre kendinde gozlemle&nbsp;</div><div>gökhan arkadasımızında dediği gibi radyatörü kontrol ettir</div><div>birde sürücü tarafında petegin oldugu yeri gözlemlesen iyi olur</div><div><br></div><div>benim aracında onceleri ufak ufak su kaybı oluyodu hiçç peteğin oraya bakmadım takı bi gün söför tarafı sırılsıklam oldugunda anladık oringlerden su kacırdıgını</div>]]>
   </description>
   <pubDate>Tue, 22 Jan 2019 19:03:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610512&amp;title=hararet-gostergesi#610512</guid>
  </item>
  <item>
   <title><![CDATA[Hararet gostergesi : Yeni olmadi 1-2 aydir boyle. Kis...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610506&amp;title=hararet-gostergesi#610506</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22312">Mustafa Aksoy</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2019 Saat 07:17<br /><br />Yeni olmadi 1-2 aydir boyle. Kis basladiginda diyelim. Ama termostatin oralarda su damlatma izleri var.sabah arabanin altina baktigimda da islak. Termostat tan supheleniyorum.&nbsp;]]>
   </description>
   <pubDate>Tue, 22 Jan 2019 07:17:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610506&amp;title=hararet-gostergesi#610506</guid>
  </item>
  <item>
   <title><![CDATA[Hararet gostergesi : merhabakapta ve hortumda genelde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610496&amp;title=hararet-gostergesi#610496</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1">GökhaN</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ocak&nbsp;2019 Saat 00:39<br /><br />merhaba<div><br></div><div>kapta ve hortumda genelde birşey olmuyor radyatörü değiştirmen gerekiyordur diye düşünüyorum. uzun süredirmi böyle yenimi oldu? Yeni olduysa antifiriz değiştirmenden veya cukura düşmenden olabilir</div>]]>
   </description>
   <pubDate>Tue, 22 Jan 2019 00:39:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610496&amp;title=hararet-gostergesi#610496</guid>
  </item>
  <item>
   <title><![CDATA[Hararet gostergesi : Merhaba 207 1.4 dizel aracimda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610492&amp;title=hararet-gostergesi#610492</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=22312">Mustafa Aksoy</a><br /><strong>Konu:</strong> 47598<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Ocak&nbsp;2019 Saat 22:39<br /><br />Merhaba 207 1.4 dizel aracimda yola ciktiktan 2-3 km sonra hararet gostergesi yukselmeye basliyor. Fakat aracin icine kalarifer sicakligi geliyor. Birbiri ile baglantilimidir bilmiyorum. Aracim termostatin arka tarafindan su damlatiyor. Komple termostatimi degismem lazim? Cok az su eksiltmesine ragmen bazen su kabi tamamen bosaliyor. Boyle bi sorunla karsilasaniz oldu mu?]]>
   </description>
   <pubDate>Mon, 21 Jan 2019 22:39:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47598&amp;PID=610492&amp;title=hararet-gostergesi#610492</guid>
  </item>
 </channel>
</rss>
