 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : LPG İÇİN YARDIM</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 308 T7 (2008-2013) : LPG İÇİN YARDIM]]></description>
  <pubDate>Mon, 04 May 2026 06:31:28 +0000</pubDate>
  <lastBuildDate>Fri, 01 Nov 2019 00:26:11 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=47352</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : bende prins marka lpg var Fan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=616943&amp;title=lpg-icin-yardim#616943</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=23636">mehkocao</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 01&nbsp;Kasım&nbsp;2019 Saat 00:26<br /><br />bende prins marka lpg var Fan açma problemi var.benzinde kullanıyorum şuan.yapabilecek bir usta bulamadım..taktırmadan bunun garantisini alın bence]]>
   </description>
   <pubDate>Fri, 01 Nov 2019 00:26:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=616943&amp;title=lpg-icin-yardim#616943</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : te&#351;ekk&#252;rederim forumda pek 308...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608819&amp;title=lpg-icin-yardim#608819</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7858">sosyete_60</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Kasım&nbsp;2018 Saat 21:06<br /><br />teşekkürederim forumda pek 308 kullanan yok galiba ben fikir veren olmadı yardımcı olan arkadaşlara teşekürederim&nbsp;]]>
   </description>
   <pubDate>Sat, 24 Nov 2018 21:06:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608819&amp;title=lpg-icin-yardim#608819</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM :   sosyete_60 Yazd&#305;:yokmu yard&#305;mc&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608816&amp;title=lpg-icin-yardim#608816</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17522">Karacocuk24</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Kasım&nbsp;2018 Saat 15:16<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: sosyete_60" alt="Orjinalini yazan: sosyete_60" style="vertical-align: text-bottom;" /> <strong>sosyete_60 Yazdı:</strong><br /><br />yokmu yardımcı olacak arkadaş</td></tr></table> kardesim insallah gonlune gore bir kit taktirirsin birde maslakta cevre otogaz var orasida candan muhendislikten eksik kalir yani yok eger istanbuldaysan orayi ara sor hatta git.konus candan muhendisligin insanlar uzerindeki en buyuk etkisi ustalik olayi ayri sosyal medyayi iyi kullaniyorlar cevre otogazi bir ara]]>
   </description>
   <pubDate>Sat, 24 Nov 2018 15:16:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608816&amp;title=lpg-icin-yardim#608816</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : yokmu yard&#305;mc&#305; olacak arkada&#351; ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608797&amp;title=lpg-icin-yardim#608797</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7858">sosyete_60</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Kasım&nbsp;2018 Saat 09:30<br /><br />yokmu yardımcı olacak arkadaş]]>
   </description>
   <pubDate>Fri, 23 Nov 2018 09:30:53 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608797&amp;title=lpg-icin-yardim#608797</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM :   Levent206xt Yazd&#305;:lpg &#246;l&#231;&#252;m&#252;n&#252;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608796&amp;title=lpg-icin-yardim#608796</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Kasım&nbsp;2018 Saat 09:06<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Levent206xt" alt="Orjinalini yazan: Levent206xt" style="vertical-align: text-bottom;" /> <strong>Levent206xt Yazdı:</strong><br /><br />lpg ölçümünü benzin ölçümü gibi yapamazsınız.çünkü gaz deposu her zaman aynı oranda gaz almaz.</td></tr></table><div><br></div><div>tabiki almaz kullanıma göre değişir :) aynı km de 25 lt gazda harcarsın 15 lt gazda harcarsın. artı buna birde benzin eklemek gerekiyor.</div>]]>
   </description>
   <pubDate>Fri, 23 Nov 2018 09:06:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608796&amp;title=lpg-icin-yardim#608796</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : lpg &#246;l&#231;&#252;m&#252;n&#252; benzin &#246;l&#231;&#252;m&#252; gibi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608792&amp;title=lpg-icin-yardim#608792</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21701">Levent206xt</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 21:52<br /><br />lpg ölçümünü benzin ölçümü gibi yapamazsınız.çünkü gaz deposu her zaman aynı oranda gaz almaz.]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 21:52:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608792&amp;title=lpg-icin-yardim#608792</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : technomax serisi 3000 tl civar&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608789&amp;title=lpg-icin-yardim#608789</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 17:43<br /><br />technomax serisi 3000 tl civarı olması lazım kardeşim. bende çok araştırdım zamanında prinse karar kıldım en son]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 17:43:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608789&amp;title=lpg-icin-yardim#608789</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : abi inan bende takt&#305;rma isterimde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608777&amp;title=lpg-icin-yardim#608777</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7858">sosyete_60</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 09:29<br /><br />abi inan bende taktırma isterimde rakamlar çok fazla atiker gold 2400 tl banada göre ideal bi rakam lovato obdıı 3100 tl biraz zorlar&nbsp; prins hiç sormadım zaten 5000 tl&nbsp; hayatta vermem atiker kit bağlattıran arkadaşlar lütfen bana yardımcı olun&nbsp;&nbsp;]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 09:29:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608777&amp;title=lpg-icin-yardim#608777</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : hocam bizim ara&#231;lar vakum manifolta...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608776&amp;title=lpg-icin-yardim#608776</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 09:22<br /><br />hocam bizim araçlar vakum manifolta az olduğu için iki marka öneriliyor genelde. biri lavato obd 2 kit diğeri prins technomax ve silvirline modeli ben technomax modeli taktırdım haziran ayında 18000 km maşalllah bir sıkıntı çekmedim şimdiye problemsiz biniyorum. pazartasi günü depoyu fulledim 40 lt gaz aldı 130 tl ye dün akşama kadar 202 km yol yapmışım tekrar fulledim. 53 tl gaz aldı. Tech ile silvir arasında bir kaç ufak fark var sadece enejektörler - yazılım vs.&nbsp;]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 09:22:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608776&amp;title=lpg-icin-yardim#608776</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : onlar&#305;da arad&#305;m &#305;srar ile lovato...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608775&amp;title=lpg-icin-yardim#608775</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7858">sosyete_60</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 09:06<br /><br />onlarıda aradım ısrar ile lovato takalım diyolar atiker grant modeli kiti taktırıpda sorunsuz kulananlar var 5000 tl lik mazemeyi usta rezil eder 2500 mazemeyi usta vezir eder tamammen işcilik ile alakalı diye düşünüyorum]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 09:06:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608775&amp;title=lpg-icin-yardim#608775</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : Hangi ildesin bilmiyorum ama her...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608771&amp;title=lpg-icin-yardim#608771</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=9228">ismailkaya</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Kasım&nbsp;2018 Saat 00:53<br /><br />Hangi ildesin bilmiyorum ama her şey parana bakar en uygunu atiker grant sanırım sen en iyisi ruhsatın fotoğrafinı çek sonra o fotoğrafı CANDAN MÜHENDİSLİK var. internete bak LPG montajında uzmanlar watsaptan ruhsatın fotoğrafını yolla ben aracıma lpg taktırmak istiyorum de sorunsuz bir kit taktırmak istiyorum diye yaz tavsiye ettiğiniz kitin fiyatını ve taksit seçeneklerini de sor . Ben bursa dan gezme amaçlı&nbsp; ist. gitiğimde CANDAN MÜH. taktırdım atiker grant taktılar 2.500 + YAĞ KATKISIYLA BERABER 2.600 &#8378; Civarı tuttu sabah tostumu ve öğle yemeğimi söylediler 2 haftadır lpg li araç kullanıyorum şuana kadar çok memnunum aracım 307 1.4 90 hp motor versiyonu olanından.&nbsp;]]>
   </description>
   <pubDate>Thu, 22 Nov 2018 00:53:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608771&amp;title=lpg-icin-yardim#608771</guid>
  </item>
  <item>
   <title><![CDATA[LPG İÇİN YARDIM : Arkada&#351;lar merhaba bende 2010...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608764&amp;title=lpg-icin-yardim#608764</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7858">sosyete_60</a><br /><strong>Konu:</strong> 47352<br /><strong>Gönderim Zamanı:</strong> 21&nbsp;Kasım&nbsp;2018 Saat 18:13<br /><br />Arkadaşlar merhaba bende 2010 model 308 1.6 vti 120 hp motora sahip bir aracım var aracıma lpg kit montaj yaptırmak istiyorum herkez ayrı birşey diyor bana yardımcı olun lütfen kimisine soruyorum aracınıza atiker grand marka kit gayet iyi olur kimisine soruyorum lovato obd ıı iyi olur kimisine soruyorum prinsden başka kit olmaz bağlatan arkadaş varmı bana yardımcı olun&nbsp;]]>
   </description>
   <pubDate>Wed, 21 Nov 2018 18:13:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47352&amp;PID=608764&amp;title=lpg-icin-yardim#608764</guid>
  </item>
 </channel>
</rss>
