 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Ses sistemi sorunu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Peugeot Ses Sistemleri : Ses sistemi sorunu]]></description>
  <pubDate>Mon, 04 May 2026 21:52:17 +0000</pubDate>
  <lastBuildDate>Tue, 30 Oct 2018 21:10:30 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=47275</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Ses sistemi sorunu : 2 cikislilarda o ayari ben birturlu...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608245&amp;title=ses-sistemi-sorunu#608245</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 47275<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2018 Saat 21:10<br /><br />2 cikislilarda o ayari ben birturlu cozemedim. Ben de deneyerek yapiyordum. 9350kullandim onda direk 3 ciksi vardi o ayar yoktu her kanali ayri ayarliyordum. <br>]]>
   </description>
   <pubDate>Tue, 30 Oct 2018 21:10:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608245&amp;title=ses-sistemi-sorunu#608245</guid>
  </item>
  <item>
   <title><![CDATA[Ses sistemi sorunu :   Alicilik Yazd&#305;:Bobinleri kontrol...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608244&amp;title=ses-sistemi-sorunu#608244</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 47275<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2018 Saat 21:02<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Alicilik" alt="Orjinalini yazan: Alicilik" style="vertical-align: text-bottom;" /> <strong>Alicilik Yazdı:</strong><br /><br />Bobinleri kontrol edin istersneiz. Bir de amfide frekans ayari ne alemde ?<br></td></tr></table><div><br></div><div>Amfi de frekans ayarlarıni çok kurcaladim birşey değişmedi en son eski haline getirdim.</div><div>Az önce indim bahçeye gizli menüdeki pre out ayarlarina baktım.</div><div>Rear-rear , preout-full dü.&nbsp;</div><div><br></div><div>Rear-sub, preout-full yaptım düzeldi gibi geldi ama rahatsizlik vermemek için sesi çok acamadim . Sabah evden uzakta deneyeceğim bakalım.</div><div>Aslında rear-sub subwoofer bağlı olduğunda seçilmesi lazım diye biliyorum ama ne hikmetse düzeldi gibime geldi. Ovalellerde temiz ve tok bir ses oldu değiştirince.</div><span style="font-size:10px"><br /><br />Düzenleyen RP393 - 30&nbsp;Ekim&nbsp;2018 Saat 21:03</span>]]>
   </description>
   <pubDate>Tue, 30 Oct 2018 21:02:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608244&amp;title=ses-sistemi-sorunu#608244</guid>
  </item>
  <item>
   <title><![CDATA[Ses sistemi sorunu : Bobinleri kontrol edin istersneiz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608243&amp;title=ses-sistemi-sorunu#608243</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=7967">Alicilik</a><br /><strong>Konu:</strong> 47275<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2018 Saat 20:56<br /><br />Bobinleri kontrol edin istersneiz. Bir de amfide frekans ayari ne alemde ?<br>]]>
   </description>
   <pubDate>Tue, 30 Oct 2018 20:56:30 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608243&amp;title=ses-sistemi-sorunu#608243</guid>
  </item>
  <item>
   <title><![CDATA[Ses sistemi sorunu : &#304;yi ak&#351;amlar,Arac&#305;mda pioneer...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608242&amp;title=ses-sistemi-sorunu#608242</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 47275<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ekim&nbsp;2018 Saat 19:56<br /><br />İyi akşamlar,<div><br></div><div>Aracımda pioneer 4350ub teyp, roadstar 6050 amfi , önde 16 cm JBL mid takımı , arkada 2 adet Pioneer 6966s oval hoparlör mevcut.</div><div><br></div><div>Midlerin bağlı olduğu kanal (front) hpf de , ovallerin bağlı olduğu kanal (rear) full ayarında. Gain ikisinde de %40 civarı.</div><div><br></div><div>Sesi 20 den fazla açınca ovaller boğuk çalıyor. Basslar üst üste biniyor. Kapıdaki midler de sorun yok . Sebebi nedir bilenler yardımcı olursanız sevinirim.</div><div><br></div><div>1 ay öncesi öncesine kadar Jbl 250 rms sub bağlı halde yine yukarda saydığım 4 hoparlör bağlıydı. O zaman ovaller gümbür gümbür çalıyordu. Şimdi direk 1 er kanala bağlılar ama verim yok.&nbsp;</div><div><br></div><div>Amfi 3000 watt , rms bilgisi bulamadım.</div><div>Jbl mid 70 rms</div><div>Pioneer oval 60 rms</div><div><br></div><span style="font-size:10px"><br /><br />Düzenleyen RP393 - 30&nbsp;Ekim&nbsp;2018 Saat 19:58</span>]]>
   </description>
   <pubDate>Tue, 30 Oct 2018 19:56:07 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=47275&amp;PID=608242&amp;title=ses-sistemi-sorunu#608242</guid>
  </item>
 </channel>
</rss>
