 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Yerde Lekeler Var</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : Yerde Lekeler Var]]></description>
  <pubDate>Sun, 03 May 2026 21:58:55 +0000</pubDate>
  <lastBuildDate>Mon, 25 Jun 2018 23:23:01 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=46722</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Yerde Lekeler Var : &amp;#128077;Bilgimden emin de&#287;ildim....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604649&amp;title=yerde-lekeler-var#604649</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21382">Kysr038</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 23:23<br /><br />&#128077;<div>Bilgimden emin değildim. Bu sayede öğrenmiş oldum. Teşekkürler&nbsp;</div><div><br></div><div><br></div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 23:23:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604649&amp;title=yerde-lekeler-var#604649</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var :   Kysr038 Yazd&#305;:  RP393 Yazd&#305;: ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604648&amp;title=yerde-lekeler-var#604648</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 23:20<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Kysr038" alt="Orjinalini yazan: Kysr038" style="vertical-align: text-bottom;" /> <strong>Kysr038 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 307XS307" alt="Orjinalini yazan: 307XS307" style="vertical-align: text-bottom;" /> <strong>307XS307 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div></td></tr></table><div><br></div><div>hocam dediğin aklıma yattı. ve hemen sanayideki ustayı aradım. gerçi arabada antfriz yok normal su var. ve aynen dediklerini söyledim. dediki su kaçağı olsa yerde belirgin bi leke olmaz dedi. kartelden belki yağ kaçağı vardır dedi</div></td></tr></table><div><br></div><div>Antifiriz yok ise ustanın dedigi doğrudur, leke birakmaz. Antifiriz yağlı olduğu için leke olabilir diye düşündüm. Soner hocamin dediği gibi yağ filtresini kontrol etmekte fayda var. Motor çalıştığında yağ pompalanırken kaçak artabilir. Yada ısınıp soğuma sonrasında kaçak artıyor olabilir.</div></td></tr></table><div><br></div><div>Antifiriz ekleyecek olursanız kırmızı koymayın radyatör ,hortum, kalorifer petegi, devridaim contasi en hassas yerden deliyor. Mavi antifriz kullanın.&nbsp; İlk etapta olması gerekenden az antifriz koyun.&nbsp;</div></td></tr></table><div>Tam tersi miydi acaba</div><div>Geçen sene mavi antifriz koydurmuştum, aracın içine dahi aktı. Radyatör çatlak giderici sıvı ile çözümü buldum.&nbsp;</div><div>Forumdan yazılanları hatırladığım kadarıyla kırmızı antifrizin kaçak olayı daha az idi</div></td></tr></table><div><br></div><div>Kırmızı antifriz 2010 altı araçların motor bloklarına ve diğer motor elemanlarına uygun değil. Hele ki araçta sürekli antifiriz kullanılmamış ise İbrahim Tatlıses in şarkısı gibi "deler de geçeeer"&nbsp;<img src="https://forum.peugeotturkey.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /></div><div><br></div><div>Tabi bu mavi zararsız anlamına gelmiyor. Suyu pis ve petekleri pas olmuş bir araçta aynı etkiyi Mavi antifriz de gösterir. O nedenle bilinen iyi marka bir mavi antifirizi (Total, lukoil kullanıyorum.) alıştıra alıştıra koymakta fayda var.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 23:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604648&amp;title=yerde-lekeler-var#604648</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var :   RP393 Yazd&#305;:  RP393 Yazd&#305;: ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604647&amp;title=yerde-lekeler-var#604647</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21382">Kysr038</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 23:03<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 307XS307" alt="Orjinalini yazan: 307XS307" style="vertical-align: text-bottom;" /> <strong>307XS307 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div></td></tr></table><div><br></div><div>hocam dediğin aklıma yattı. ve hemen sanayideki ustayı aradım. gerçi arabada antfriz yok normal su var. ve aynen dediklerini söyledim. dediki su kaçağı olsa yerde belirgin bi leke olmaz dedi. kartelden belki yağ kaçağı vardır dedi</div></td></tr></table><div><br></div><div>Antifiriz yok ise ustanın dedigi doğrudur, leke birakmaz. Antifiriz yağlı olduğu için leke olabilir diye düşündüm. Soner hocamin dediği gibi yağ filtresini kontrol etmekte fayda var. Motor çalıştığında yağ pompalanırken kaçak artabilir. Yada ısınıp soğuma sonrasında kaçak artıyor olabilir.</div></td></tr></table><div><br></div><div>Antifiriz ekleyecek olursanız kırmızı koymayın radyatör ,hortum, kalorifer petegi, devridaim contasi en hassas yerden deliyor. Mavi antifriz kullanın.&nbsp; İlk etapta olması gerekenden az antifriz koyun.&nbsp;</div></td></tr></table><div>Tam tersi miydi acaba</div><div>Geçen sene mavi antifriz koydurmuştum, aracın içine dahi aktı. Radyatör çatlak giderici sıvı ile çözümü buldum.&nbsp;</div><div>Forumdan yazılanları hatırladığım kadarıyla kırmızı antifrizin kaçak olayı daha az idi</div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 23:03:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604647&amp;title=yerde-lekeler-var#604647</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var :   RP393 Yazd&#305;:  307XS307 Yazd&#305;: ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604646&amp;title=yerde-lekeler-var#604646</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 22:23<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 307XS307" alt="Orjinalini yazan: 307XS307" style="vertical-align: text-bottom;" /> <strong>307XS307 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div></td></tr></table><div><br></div><div>hocam dediğin aklıma yattı. ve hemen sanayideki ustayı aradım. gerçi arabada antfriz yok normal su var. ve aynen dediklerini söyledim. dediki su kaçağı olsa yerde belirgin bi leke olmaz dedi. kartelden belki yağ kaçağı vardır dedi</div></td></tr></table><div><br></div><div>Antifiriz yok ise ustanın dedigi doğrudur, leke birakmaz. Antifiriz yağlı olduğu için leke olabilir diye düşündüm. Soner hocamin dediği gibi yağ filtresini kontrol etmekte fayda var. Motor çalıştığında yağ pompalanırken kaçak artabilir. Yada ısınıp soğuma sonrasında kaçak artıyor olabilir.</div></td></tr></table><div><br></div><div>Antifiriz ekleyecek olursanız kırmızı koymayın radyatör ,hortum, kalorifer petegi, devridaim contasi en hassas yerden deliyor. Mavi antifriz kullanın.&nbsp; İlk etapta olması gerekenden az antifriz koyun.&nbsp;</div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 22:23:27 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604646&amp;title=yerde-lekeler-var#604646</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var :   307XS307 Yazd&#305;:  RP393 Yazd&#305;:sag...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604645&amp;title=yerde-lekeler-var#604645</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 22:18<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 307XS307" alt="Orjinalini yazan: 307XS307" style="vertical-align: text-bottom;" /> <strong>307XS307 Yazdı:</strong><br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div></td></tr></table><div><br></div><div>hocam dediğin aklıma yattı. ve hemen sanayideki ustayı aradım. gerçi arabada antfriz yok normal su var. ve aynen dediklerini söyledim. dediki su kaçağı olsa yerde belirgin bi leke olmaz dedi. kartelden belki yağ kaçağı vardır dedi</div></td></tr></table><div><br></div><div>Antifiriz yok ise ustanın dedigi doğrudur, leke birakmaz. Antifiriz yağlı olduğu için leke olabilir diye düşündüm. Soner hocamin dediği gibi yağ filtresini kontrol etmekte fayda var. Motor çalıştığında yağ pompalanırken kaçak artabilir. Yada ısınıp soğuma sonrasında kaçak artıyor olabilir.</div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 22:18:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604645&amp;title=yerde-lekeler-var#604645</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : birde hocam ya&#287; filtre kapa&#287;&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604634&amp;title=yerde-lekeler-var#604634</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 17:40<br /><br />birde hocam yağ filtre kapağını kontrol bizim araçların plastik olduğu için oradan da kaçırma ihtimali bar.&nbsp; bu arada aracına entifiriz koymayı ihmal etme sonra başka problemler karşına çıkmaya başlar.&nbsp;]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 17:40:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604634&amp;title=yerde-lekeler-var#604634</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var :   RP393 Yazd&#305;:sag lastik taraf&#305;ndan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604631&amp;title=yerde-lekeler-var#604631</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19642">307XS307</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 13:00<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: RP393" alt="Orjinalini yazan: RP393" style="vertical-align: text-bottom;" /> <strong>RP393 Yazdı:</strong><br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div></td></tr></table><div><br></div><div>hocam dediğin aklıma yattı. ve hemen sanayideki ustayı aradım. gerçi arabada antfriz yok normal su var. ve aynen dediklerini söyledim. dediki su kaçağı olsa yerde belirgin bi leke olmaz dedi. kartelden belki yağ kaçağı vardır dedi</div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 13:00:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604631&amp;title=yerde-lekeler-var#604631</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : sag lastik taraf&#305;ndan devridaim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604626&amp;title=yerde-lekeler-var#604626</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20055">RP393</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Haziran&nbsp;2018 Saat 08:49<br /><br />sag lastik tarafından devridaim kaçağı olabilir. Damlayan sıvı açık renkli kaygan ise antifrizdir. Aracı çalıştırın fan açtığı esnada altına bakın damlamaya başlarsa dediğim gibi soğutma suyudur.<div><br></div><div>Bu soğutma suyu yere damladiginda siyah leke birakir.<br><div><br></div><div><br></div></div>]]>
   </description>
   <pubDate>Mon, 25 Jun 2018 08:49:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604626&amp;title=yerde-lekeler-var#604626</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : ya&#287; yeni de&#287;i&#351;ti 1 ay falan oluyor....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604618&amp;title=yerde-lekeler-var#604618</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19642">307XS307</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2018 Saat 22:54<br /><br />yağ yeni değişti 1 ay falan oluyor. ama dediğiniz gibi bi ara sanayiye gideyim. belki iyi sıkmamış bile olabilirler]]>
   </description>
   <pubDate>Sun, 24 Jun 2018 22:54:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604618&amp;title=yerde-lekeler-var#604618</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : zaten 1 damla 1 damla damlad&#305;&#287;&#305;nda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604615&amp;title=yerde-lekeler-var#604615</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21269">Selçuk55</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2018 Saat 19:04<br /><br />zaten 1 damla 1 damla damladığında anlamanız biraz zor aylar sonra yarım litre eksilir büyük ihtimal karter tapasından sızıyor yağ değişimimiz gelince tapayı değişin<div><br></div>]]>
   </description>
   <pubDate>Sun, 24 Jun 2018 19:04:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604615&amp;title=yerde-lekeler-var#604615</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : lekelerin oldu&#287;u yer araban&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604613&amp;title=yerde-lekeler-var#604613</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19642">307XS307</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2018 Saat 18:17<br /><br />lekelerin olduğu yer arabanın arkası değilde ön tarafında. yani arabanın altı ön 2 lastiğin ortası gibi. hatta sağ lastiğe daha yakın. ayrıca ara sıra arabadan indiğim anda pis bi koku geliyo ve hemen kayboluyo. hararet kokusu gibi. ama 1 ay önce contadan su kaçağı vardı onu yaptırdım. manifolta su damlıyordu. o halloldu su eksiltme yok hararetde yapmıyor. motor yağına bakıyorum ondanda eksilme yok]]>
   </description>
   <pubDate>Sun, 24 Jun 2018 18:17:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604613&amp;title=yerde-lekeler-var#604613</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : Karter tapas&#305; olabilir contalardan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604608&amp;title=yerde-lekeler-var#604608</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21269">Selçuk55</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2018 Saat 16:32<br /><br />Karter tapası olabilir contalardan kaçırabilir direksiyon kutusundan kaçırabilir yağ kaçıyor biyerden<img src="https://forum.peugeotturkey.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" />]]>
   </description>
   <pubDate>Sun, 24 Jun 2018 16:32:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604608&amp;title=yerde-lekeler-var#604608</guid>
  </item>
  <item>
   <title><![CDATA[Yerde Lekeler Var : merhaba arkada&#351;lar. arabada ya&#287;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604604&amp;title=yerde-lekeler-var#604604</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19642">307XS307</a><br /><strong>Konu:</strong> 46722<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Haziran&nbsp;2018 Saat 15:37<br /><br />merhaba arkadaşlar. arabada yağ eksiltme yok su eksiltme yok. ama geçen gün arabanın altında yerde 4-5 adet su bardağı altı büyüklüğünde lekeler gördüm küçüklü büyüklü. benim arabadan değildir belki diyerek temiz bir yere parkettim. ertesi gün baktım yine aynı lekeler. bu neyin nesidir ?&nbsp;<div><br></div><div>not: 4-5 parça lekenin en az 3 tanesi koyu renk siyah yağ veya boya gibi. diğer ikisi daha açık renk su gibi. ayrıca arabanın altına bi kaç dakika detaylı şekilde baktım damlayan bişeyde göremedim. ne ara o lekeler oluşuyo ve neden oluyo bilmiyorum</div>]]>
   </description>
   <pubDate>Sun, 24 Jun 2018 15:37:09 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46722&amp;PID=604604&amp;title=yerde-lekeler-var#604604</guid>
  </item>
 </channel>
</rss>
