 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 2008 için ön diskler ankara</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : 2008 için ön diskler ankara]]></description>
  <pubDate>Sat, 02 May 2026 10:55:31 +0000</pubDate>
  <lastBuildDate>Tue, 08 May 2018 22:28:33 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=46474</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[2008 için ön diskler ankara : Say&#305;n sonerkyl yard&#305;mlar&#305;n&#305;z ve...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602841&amp;title=2008-icin-on-diskler-ankara#602841</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21300">biyolog</a><br /><strong>Konu:</strong> 46474<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Mayıs&nbsp;2018 Saat 22:28<br /><br />Sayın sonerkyl yardımlarınız ve telefon için tesekkur ederim.]]>
   </description>
   <pubDate>Tue, 08 May 2018 22:28:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602841&amp;title=2008-icin-on-diskler-ankara#602841</guid>
  </item>
  <item>
   <title><![CDATA[2008 için ön diskler ankara :   biyolog Yazd&#305;:2008 i&#231;in &#246;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602799&amp;title=2008-icin-on-diskler-ankara#602799</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 46474<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Mayıs&nbsp;2018 Saat 08:47<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: biyolog" alt="Orjinalini yazan: biyolog" style="vertical-align: text-bottom;" /> <strong>biyolog Yazdı:</strong><br /><br />2008 için ön diskleri ankara da nerde bulabilirim.Tavsiye edilecek yetkili servis dısı bir yer için tesekkur ederim&nbsp;</td></tr></table><div><br></div><div>öncelikle aramıza hoşgeldiniz. hocam ankarada peugeot yedek parça için fatih ali imran peugeotta atakana özyüreğe ulaşın selamımı söyleyin size yardımcı olacaktır parça konusunda.&nbsp;</div><div>yerleri şaşmazda&nbsp;</div><div>cep tel : 0545 503 79 75 atakan özyürek</div>]]>
   </description>
   <pubDate>Tue, 08 May 2018 08:47:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602799&amp;title=2008-icin-on-diskler-ankara#602799</guid>
  </item>
  <item>
   <title><![CDATA[2008 için ön diskler ankara : 2008 i&#231;in &#246;n diskleri ankara da...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602789&amp;title=2008-icin-on-diskler-ankara#602789</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=21300">biyolog</a><br /><strong>Konu:</strong> 46474<br /><strong>Gönderim Zamanı:</strong> 08&nbsp;Mayıs&nbsp;2018 Saat 00:21<br /><br />2008 için ön diskleri ankara da nerde bulabilirim.Tavsiye edilecek yetkili servis dısı bir yer için tesekkur ederim&nbsp;]]>
   </description>
   <pubDate>Tue, 08 May 2018 00:21:25 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46474&amp;PID=602789&amp;title=2008-icin-on-diskler-ankara#602789</guid>
  </item>
 </channel>
</rss>
