 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Far Sensörü</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Far Sensörü]]></description>
  <pubDate>Sat, 02 May 2026 07:57:22 +0000</pubDate>
  <lastBuildDate>Fri, 06 Apr 2018 19:31:26 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=46298</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Far Sensörü :  Filimle kapatm&#305;&#351;sa direkt karanl&#305;&#287;a...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601581&amp;title=far-sensoru#601581</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14450">ersin61</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Nisan&nbsp;2018 Saat 19:31<br /><br />Filimle kapatmışsa direkt karanlığa düşüyor.Ondan da direk yanıyor olabilir..]]>
   </description>
   <pubDate>Fri, 06 Apr 2018 19:31:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601581&amp;title=far-sensoru#601581</guid>
  </item>
  <item>
   <title><![CDATA[Far Sensörü : aynen tek karde&#351;im sizin ara&#231;larda...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601573&amp;title=far-sensoru#601573</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Nisan&nbsp;2018 Saat 15:33<br /><br />aynen tek kardeşim sizin araçlarda camda hepsi.&nbsp;]]>
   </description>
   <pubDate>Fri, 06 Apr 2018 15:33:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601573&amp;title=far-sensoru#601573</guid>
  </item>
  <item>
   <title><![CDATA[Far Sensörü : Ya&#287;mur sens&#246;r&#252; ve far sens&#246;r&#252;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601572&amp;title=far-sensoru#601572</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20351">ORhun53</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Nisan&nbsp;2018 Saat 14:39<br /><br />Yağmur sensörü ve far sensörü tek diye biliyorum aynanın hemen arkasında cama yapışık.Xenon kitlerinden var]]>
   </description>
   <pubDate>Fri, 06 Apr 2018 14:39:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601572&amp;title=far-sensoru#601572</guid>
  </item>
  <item>
   <title><![CDATA[Far Sensörü : sens&#246;r&#252;n nerde oldu&#287;unu &#246;&#287;renmek...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601554&amp;title=far-sensoru#601554</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=1">GökhaN</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 06&nbsp;Nisan&nbsp;2018 Saat 09:21<br /><br />sensörün nerde olduğunu öğrenmek lazım sensör farların üzerinde değilse büyük ihtimallede değil alakası yoktur. Beyinli xenon dediğin normal xenon far kiti değil mi<br>]]>
   </description>
   <pubDate>Fri, 06 Apr 2018 09:21:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601554&amp;title=far-sensoru#601554</guid>
  </item>
  <item>
   <title><![CDATA[Far Sensörü : olabilir hocam onu s&#246;kt&#252;r&#252;p orjinal...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601505&amp;title=far-sensoru#601505</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2018 Saat 10:03<br /><br />olabilir hocam onu söktürüp orjinal sisteme geri dönmenizi tavisye ederim. illa xenon istiyorsanız yeni tip led olanlardan alın kablo vs. kesmeyede gerek kalmaz.&nbsp;]]>
   </description>
   <pubDate>Thu, 05 Apr 2018 10:03:56 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601505&amp;title=far-sensoru#601505</guid>
  </item>
  <item>
   <title><![CDATA[Far Sensörü : Arkada&#351;lar Merhaba;Arac&#305;m&#305;n cam&#305;n&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601504&amp;title=far-sensoru#601504</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20351">ORhun53</a><br /><strong>Konu:</strong> 46298<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Nisan&nbsp;2018 Saat 09:42<br /><br />Arkadaşlar Merhaba;<div>Aracımın camını benden önceki sahibi değiştirmiş far ve yağmur sensörü çalışmıyordu.Geçenlerde oto camcıya gittim ve sensörün önüne film çekti yağmur sensörü düzeldi.Ancak farlar sürekli açık gece gündüz demeksizin.Araçta beyinli xenon var acaba bundan dolayımı açık kalıyor sürekli.</div><div></div>]]>
   </description>
   <pubDate>Thu, 05 Apr 2018 09:42:19 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46298&amp;PID=601504&amp;title=far-sensoru#601504</guid>
  </item>
 </channel>
</rss>
