 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hararet Göstergesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Hararet Göstergesi]]></description>
  <pubDate>Sun, 03 May 2026 18:01:23 +0000</pubDate>
  <lastBuildDate>Wed, 14 Feb 2018 20:16:03 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=46056</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hararet Göstergesi : Su seviyesi sens&#246;r&#252; de ayn&#305; hatay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599679&amp;title=hararet-gostergesi#599679</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17562">ggitaristt</a><br /><strong>Konu:</strong> 46056<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Şubat&nbsp;2018 Saat 20:16<br /><br />Su seviyesi sensörü de aynı hatayı verdirir..<br>]]>
   </description>
   <pubDate>Wed, 14 Feb 2018 20:16:03 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599679&amp;title=hararet-gostergesi#599679</guid>
  </item>
  <item>
   <title><![CDATA[Hararet Göstergesi : termostat yada m&#252;&#351;&#252;r ar&#305;zas&#305; olabilir....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599677&amp;title=hararet-gostergesi#599677</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=4842">bjkamil</a><br /><strong>Konu:</strong> 46056<br /><strong>Gönderim Zamanı:</strong> 14&nbsp;Şubat&nbsp;2018 Saat 18:16<br /><br />termostat yada müşür arızası olabilir.]]>
   </description>
   <pubDate>Wed, 14 Feb 2018 18:16:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599677&amp;title=hararet-gostergesi#599677</guid>
  </item>
  <item>
   <title><![CDATA[Hararet Göstergesi : m&#252;&#351;&#252;re bakt&#305;r&#305;n ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599663&amp;title=hararet-gostergesi#599663</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17876">x571</a><br /><strong>Konu:</strong> 46056<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Şubat&nbsp;2018 Saat 22:01<br /><br />müşüre baktırın&nbsp;]]>
   </description>
   <pubDate>Tue, 13 Feb 2018 22:01:32 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599663&amp;title=hararet-gostergesi#599663</guid>
  </item>
  <item>
   <title><![CDATA[Hararet Göstergesi : Merhabalar, 2005 1.4 benzin+LPG...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599661&amp;title=hararet-gostergesi#599661</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=20936">Serkan01</a><br /><strong>Konu:</strong> 46056<br /><strong>Gönderim Zamanı:</strong> 13&nbsp;Şubat&nbsp;2018 Saat 18:35<br /><br />Merhabalar, 2005 1.4 benzin+LPG otomatik vites bir 206 aracım var. Araçla seyir halinde iken genelde 80-90 km civarı hızla giderken hararet göstergesi birden 70'den 130'a yükseliyor ve stop ışığını yakarak uyarı vermeye başlıyor. Tabi bende aracımı durdurmak zorunda kalıyorum.Sahsi fikrim motor o kadar ısınmıyor ancak sistem birden motor sıcak uyarısı ile ibreyi 130 a cikariyor.Bu sorunu yasadigimda bir kez radyatör içindeki suyu boşaltıp tekrar doldurdum stop Edip tekrar çalıştırdığınızda hararet 130 da tekrar 70lere indi. Sorun nedir sizce neye bakılmalı. Geçen hafta sonu yine aynı sorunu yaşadım stop Edip bir kaç kez tekrar çalıştirdigimda araçta akü bosalircasina mars başladı dedim akü bitti.takviye ile çalıştırdık, Akü için gittiğimde elektrik kaçağı olduğunu söyledi usta. Biraz karışık yazdım ama değerli yorumlarınızı bekliyorum. Saygılar.]]>
   </description>
   <pubDate>Tue, 13 Feb 2018 18:35:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=46056&amp;PID=599661&amp;title=hararet-gostergesi#599661</guid>
  </item>
 </channel>
</rss>
