 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Disk Balata Değişimi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 207 : Disk Balata Değişimi]]></description>
  <pubDate>Sat, 02 May 2026 04:21:17 +0000</pubDate>
  <lastBuildDate>Sun, 04 Jun 2017 14:45:00 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=44497</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Disk Balata Değişimi : arkada&#351;lar otamatik &#351;anzuman ustas&#305;y&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=587012&amp;title=disk-balata-degisimi#587012</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18474">TUNAYCAN</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 04&nbsp;Haziran&nbsp;2017 Saat 14:45<br /><br />arkadaşlar otamatik şanzuman ustasıyım skıntınız oldugunda arayın 05545485711<div><br></div>]]>
   </description>
   <pubDate>Sun, 04 Jun 2017 14:45:00 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=587012&amp;title=disk-balata-degisimi#587012</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi :   sonerkyl Yazd&#305;:tahminin fren...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585987&amp;title=disk-balata-degisimi#585987</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19466">CemDemiral</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 11:56<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: sonerkyl" alt="Orjinalini yazan: sonerkyl" style="vertical-align: text-bottom;" /> <strong>sonerkyl Yazdı:</strong><br /><br />tahminin fren hidrolik yağı hiç değişmemiştir. Bence bir daha ki yağ bakımdan fren hidrolik yağınıda değiştir. Benim 206 hiç değişmemiş boşaltırken ilk başta biraz pislik gelmişti. Şimdi fren tepkisi daha aracın.&nbsp;</td></tr></table><div><br></div><div>abi hidroliğe baktım normal seviyede ama sanki biraz kararmış gibi dediğin gibi sanırım hiç değişmemiş 4bin km kaldı bakıma idare etsin o zaman onu da değiştiririz ama ben yinede bir gidip göstermek istiyorum sorun falan çıkmasın :S</div>]]>
   </description>
   <pubDate>Thu, 18 May 2017 11:56:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585987&amp;title=disk-balata-degisimi#585987</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi : tahminin fren hidrolik ya&#287;&#305; hi&#231;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585980&amp;title=disk-balata-degisimi#585980</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:57<br /><br />tahminin fren hidrolik yağı hiç değişmemiştir. Bence bir daha ki yağ bakımdan fren hidrolik yağınıda değiştir. Benim 206 hiç değişmemiş boşaltırken ilk başta biraz pislik gelmişti. Şimdi fren tepkisi daha aracın.&nbsp;]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:57:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585980&amp;title=disk-balata-degisimi#585980</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi :   sonerkyl Yazd&#305;:Cem balata spreyi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585978&amp;title=disk-balata-degisimi#585978</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19466">CemDemiral</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:48<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: sonerkyl" alt="Orjinalini yazan: sonerkyl" style="vertical-align: text-bottom;" /> <strong>sonerkyl Yazdı:</strong><br /><br />Cem balata spreyi alıp güzelce bir temizle diskleri balataları. Fren hidrolik yağını değiştirmeni tavsiye ederim.</td></tr></table><div><br></div><div>Abi sprey aldım bugün sıktım az önce hidrolik aklıma gelmedi onada bakayım sonucu söylerim abi.</div>]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:48:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585978&amp;title=disk-balata-degisimi#585978</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi :   Karacocuk24 Yazd&#305;:Dikkatli...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585976&amp;title=disk-balata-degisimi#585976</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19466">CemDemiral</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:47<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Karacocuk24" alt="Orjinalini yazan: Karacocuk24" style="vertical-align: text-bottom;" /> <strong>Karacocuk24 Yazdı:</strong><br /><br />Dikkatli kullanin duzelecektir i&#537;e git gel derken yolunuz otobanmi yoksa surekli dur kalkmi yapiyorsunuz</td></tr></table><div><br></div><div>trafikteyim önce eşimi işe bırakıyorum ordan işe geçiyorum aynı olay akşam çıkışta oluyor.</div>]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:47:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585976&amp;title=disk-balata-degisimi#585976</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi : Cem balata spreyi al&#305;p g&#252;zelce...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585975&amp;title=disk-balata-degisimi#585975</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:47<br /><br />Cem balata spreyi alıp güzelce bir temizle diskleri balataları. Fren hidrolik yağını değiştirmeni tavsiye ederim.]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:47:22 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585975&amp;title=disk-balata-degisimi#585975</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi : Dikkatli kullanin duzelecektir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585974&amp;title=disk-balata-degisimi#585974</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17522">Karacocuk24</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:45<br /><br />Dikkatli kullanin duzelecektir i&#537;e git gel derken yolunuz otobanmi yoksa surekli dur kalkmi yapiyorsunuz]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:45:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585974&amp;title=disk-balata-degisimi#585974</guid>
  </item>
  <item>
   <title><![CDATA[Disk Balata Değişimi : Selamlar arkada&#351;lar iyi forumlar......]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585968&amp;title=disk-balata-degisimi#585968</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19466">CemDemiral</a><br /><strong>Konu:</strong> 44497<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Mayıs&nbsp;2017 Saat 10:29<br /><br />Selamlar arkadaşlar iyi forumlar...<div><br></div><div>&nbsp; 1 hafta önce Ön fren diskleri Göral serviste değiştirdim diskler yan sanayi balatalar orjinal Peugeot marka logolu aldım. 1 hafta olmasına rağmen frenler eskiye oranla çok yumuşak geliyor, ve köküne kadar basmama rağmen anca yavaşlıyor 110 KM hızla ani fren denemesi yaptım bugün ama eskisine oranla çok geç durdu araba Allah korusun acil bir durumda bu araba durmaz diye korkar oldum. Alışma süresi var 1-3 gün arası dediler bazı tanıdıklarda 250-300 km yapman lazım dediler ama ben zaten günlük 60 km yol yapıyorum sadece işe git gel buda 1 haftada 420 km yol oluyor ki akşamlar gezme hariç.&nbsp;</div><div><br></div><div>&nbsp; Biraz fikir verirseniz çok sevinirim.</div>]]>
   </description>
   <pubDate>Thu, 18 May 2017 10:29:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=44497&amp;PID=585968&amp;title=disk-balata-degisimi#585968</guid>
  </item>
 </channel>
</rss>
