 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Stop braking system</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 207 : Stop braking system]]></description>
  <pubDate>Sat, 02 May 2026 18:40:32 +0000</pubDate>
  <lastBuildDate>Sun, 30 Apr 2017 02:07:16 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=43907</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Stop braking system : bakt&#305;n&#305;z m&#305;? sorun neymi&#351;?bana;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=584958&amp;title=stop-braking-system#584958</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=12880">zerzevat</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Nisan&nbsp;2017 Saat 02:07<br /><br />baktınız mı? sorun neymiş?<div><br></div><div>bana; &nbsp;"hidrolik yağı azalmış" gibi geldi?</div>]]>
   </description>
   <pubDate>Sun, 30 Apr 2017 02:07:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=584958&amp;title=stop-braking-system#584958</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : bilgisayarda &#231;&#305;kar hata kodu hocam....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580517&amp;title=stop-braking-system#580517</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 25&nbsp;Şubat&nbsp;2017 Saat 10:35<br /><br />bilgisayarda çıkar hata kodu hocam.]]>
   </description>
   <pubDate>Sat, 25 Feb 2017 10:35:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580517&amp;title=stop-braking-system#580517</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : Tamam kardesim sagolasin ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580509&amp;title=stop-braking-system#580509</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19211">Akguntanju4545</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Şubat&nbsp;2017 Saat 23:45<br /><br />Tamam kardesim sagolasin]]>
   </description>
   <pubDate>Fri, 24 Feb 2017 23:45:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580509&amp;title=stop-braking-system#580509</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : G&#246;rebilirsiniz benim ara&#231; antipollitoun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580505&amp;title=stop-braking-system#580505</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18239">Furkan979</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Şubat&nbsp;2017 Saat 23:08<br /><br />Görebilirsiniz benim araç antipollitoun faulty veriyodu lgp dir diye umursamadım bilgisayara bi bağlıdılar bujinin teki  bozuk çıktı yani göstermekte fayda var ]]>
   </description>
   <pubDate>Fri, 24 Feb 2017 23:08:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580505&amp;title=stop-braking-system#580505</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : Peki kardesim ben bunu bilgisayara...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580504&amp;title=stop-braking-system#580504</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19211">Akguntanju4545</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Şubat&nbsp;2017 Saat 23:04<br /><br />Peki kardesim ben bunu bilgisayara baglatip hatanin neyden kaynaklandigini ogrenebilirmiyim]]>
   </description>
   <pubDate>Fri, 24 Feb 2017 23:04:55 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580504&amp;title=stop-braking-system#580504</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : hocam &#351;&#246;yle s&#305;ralay&#305;m1-&#246;n diskler2-balatalar3-abs...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580502&amp;title=stop-braking-system#580502</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Şubat&nbsp;2017 Saat 22:31<br /><br />hocam şöyle sıralayım<div>1-ön diskler</div><div>2-balatalar</div><div>3-abs sensörleri</div><div>4-en kötü ihtimal abs beyni</div><div>yukarıda söylediklerimden biri yada bir kaçı sebep olabilir.</div>]]>
   </description>
   <pubDate>Fri, 24 Feb 2017 22:31:05 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580502&amp;title=stop-braking-system#580502</guid>
  </item>
  <item>
   <title><![CDATA[Stop braking system : Hayirli aksamlar kardeslerim.....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580501&amp;title=stop-braking-system#580501</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=19211">Akguntanju4545</a><br /><strong>Konu:</strong> 43907<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Şubat&nbsp;2017 Saat 21:57<br /><br />Hayirli aksamlar kardeslerim.. <img src="https://forum.peugeotturkey.com/smileys/smiley1.gif" border="0" align="middle" /> <br /><br />1.4 trendy benzinli 207 aracim var normalde her gün bindigim zaman stop braking system hatasi vermiyor..<br /><br />Ama bigun boyunca hic binmeyip diger gun binecek oldum mu ilk basta kontagi actigim zaman calistirmadan once stop braking system diyo <br /><br />Sonra calistirip biraz yol yaptim mi arabayi stop edip tekrar kontagi actigim zaman o hatayi vermiyor sadece dedgim gibi bigun boyunca araci kullanmazsam o hatayi veriyor sizce neden olabilir simdiden hepinize tesekkurler <img src="https://forum.peugeotturkey.com/smileys/smiley2.gif" border="0" align="middle" /> ]]>
   </description>
   <pubDate>Fri, 24 Feb 2017 21:57:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43907&amp;PID=580501&amp;title=stop-braking-system#580501</guid>
  </item>
 </channel>
</rss>
