 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Su sesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : Arac&#305;n&#305;z Hakk&#305;ndaki T&#252;m Sorular : Su sesi]]></description>
  <pubDate>Sun, 03 May 2026 07:19:41 +0000</pubDate>
  <lastBuildDate>Fri, 02 Jan 2009 17:34:11 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=4359</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Su sesi : bu 206 lara has bir ar&#305;za de&#287;ildir, 106...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66105&amp;title=su-sesi#66105</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=388">TOLGA</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Ocak&nbsp;2009 Saat 17:34<br /><br />bu 206 lara has bir arıza değildir,<DIV>106 larda da görüldüğü duyulmuştur,</DIV>]]>
   </description>
   <pubDate>Fri, 02 Jan 2009 17:34:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66105&amp;title=su-sesi#66105</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi :    dejavu Yazd&#305;:senin kalorifer...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66091&amp;title=su-sesi#66091</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Ocak&nbsp;2009 Saat 17:18<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: dejavu" alt="Orjinalini yazan: dejavu" style="vertical-align: text-bottom;" /> <strong>dejavu Yazdı:</strong><br /><br />senin kalorifer sisteminde hava var.radyatörden hava aldırman gerekiyor.tecrübeyle sabittir</td></tr></table><br><u><i><b><font color="#ff0000">Lütfen tanışma başlığı açınız.Tecrübeyle sabittir!</font></b></i></u><br>]]>
   </description>
   <pubDate>Fri, 02 Jan 2009 17:18:26 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66091&amp;title=su-sesi#66091</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : senin kalorifer sisteminde hava...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66089&amp;title=su-sesi#66089</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 02&nbsp;Ocak&nbsp;2009 Saat 17:16<br /><br />senin kalorifer sisteminde hava var.radyatörden hava aldırman gerekiyor.tecrübeyle sabittir]]>
   </description>
   <pubDate>Fri, 02 Jan 2009 17:16:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=66089&amp;title=su-sesi#66089</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : ayn&#305; sorun bendede var ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63856&amp;title=su-sesi#63856</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=987">ixtanbul</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 15:35<br /><br />aynı sorun bendede var ]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 15:35:49 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63856&amp;title=su-sesi#63856</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : &#350;u durumda hortun de&#287;i&#351;meden....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63843&amp;title=su-sesi#63843</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=81">hasimayaz</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:56<br /><br />Şu durumda hortun değişmeden. Söylenilebilecek bir şey yok.. hatta bence yeşil antfrizdende kurtul..]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:56:29 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63843&amp;title=su-sesi#63843</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : bahsettigim kelep&#231;e radyat&#246;r deposunun...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63834&amp;title=su-sesi#63834</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=852">206Quick</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:41<br /><br /><P>bahsettigim kelepçe radyatör deposunun üstündeki 206 sı olan arkdaslar bilirler...</P>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:41:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63834&amp;title=su-sesi#63834</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : kelep&#231;e 100 ytl degil komple hortum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63833&amp;title=su-sesi#63833</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=852">206Quick</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:41<br /><br /><P><FONT style=": #efefef">kelepçe 100 ytl degil komple hortum o fiyata o kelepçe tek satılmıyo 2 3 tane yere baktım yok bende onu uhu bant tel falan biseyler yaptım cok sıkı oldu ama aradan hava kaçırıyor demekki </FONT></P>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:41:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63833&amp;title=su-sesi#63833</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi :   206Quick Yazd&#305;:eet ye&#351;il antifiriz...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63831&amp;title=su-sesi#63831</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=81">hasimayaz</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:37<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206Quick" alt="Orjinalini yazan: 206Quick" style="vertical-align: text-bottom;" /> <strong>206Quick Yazdı:</strong><br /><br />eet yeşil antifiriz kullanıyorum + radyatör yedek su deposuna giren hortumun ucundaki kelepçe kaybolmus :S bende onu simdilik yapıstırdım tutuyo ama su eksiltme yapıyo 100 ytl dediler komple almak lazımmıs o ufak kelepçede bulabilirmiyiz acaba</td></tr></table> <DIV>&nbsp;</DIV><DIV>Hiçbir kelepçe 100 ytl olamaz kardeş.. biraz daha ayrıntılı yada resim çekip gönderirsen daha net bakalım..</DIV><DIV>&nbsp;</DIV><DIV>Ben en son yeşila antfriz kullandığımda termostatı elime aldım.. </DIV>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:37:12 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63831&amp;title=su-sesi#63831</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi :    206Quick Yazd&#305;:eet ye&#351;il...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63828&amp;title=su-sesi#63828</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:35<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206Quick" alt="Orjinalini yazan: 206Quick" style="vertical-align: text-bottom;" /> <strong>206Quick Yazdı:</strong><br /><br />eet yeşil antifiriz kullanıyorum + radyatör yedek su deposuna giren hortumun ucundaki kelepçe kaybolmus :S bende onu simdilik yapıstırdım tutuyo ama su eksiltme yapıyo 100 ytl dediler komple almak lazımmıs o ufak kelepçede bulabilirmiyiz acaba</td></tr></table><br><font color="#990000"><u><i><b>Biraz detaylı araştırısan mutlaka bulursun dostum.Olmadı ustan başka bi çözüm bulsun.</b></i></u></font><br>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:35:34 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63828&amp;title=su-sesi#63828</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : Ne G&#252;zel &#304;&#351;te Karde&#351;im Otantik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63827&amp;title=su-sesi#63827</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:35<br /><br /><P>Ne Güzel İşte Kardeşim Otantik :)</P><P>Sistemde Hava Var Kanımça</P>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:35:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63827&amp;title=su-sesi#63827</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : eet ye&#351;il antifiriz kullan&#305;yorum...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63816&amp;title=su-sesi#63816</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=852">206Quick</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:22<br /><br />eet yeşil antifiriz kullanıyorum + radyatör yedek su deposuna giren hortumun ucundaki kelepçe kaybolmus :S bende onu simdilik yapıstırdım tutuyo ama su eksiltme yapıyo 100 ytl dediler komple almak lazımmıs o ufak kelepçede bulabilirmiyiz acaba ]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:22:42 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63816&amp;title=su-sesi#63816</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi :    hasimayaz Yazd&#305;:Sorun %99...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63815&amp;title=su-sesi#63815</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:19<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: hasimayaz" alt="Orjinalini yazan: hasimayaz" style="vertical-align: text-bottom;" /> <strong>hasimayaz Yazdı:</strong><br /><br /><p>Sorun %99 radyatörden.. Peugeotlar sudakihavayı otomatik olarak alır. ama radyatör veya hortum tıkanmaları sese sebebiyet verebilir. Ayrıca aracında kırmızı antifriz kullanmalısın yoksa yeşil antifriler bizim araçlarda ciddi korozyon sıkıntılarına sebebiyet verebiliyor.</p><p>Aracında su seviyesi için sensör var. Tehlikeli miktarda eksilme olursa stop uyarısı ve sesi verecektir. Bence sıkıntı edilecek bir şey değil.</p></td></tr></table><br><font color="#990000"><u><i><b><br>Valla ben en son su sesi duyduğumda hiç hayırlı şeyler olmadı Haşim Abi<img src="https://forum.peugeotturkey.com/smileys/smiley19.gif" border="0" alt="Cry" /></b></i></u></font><br>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:19:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63815&amp;title=su-sesi#63815</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : Sorun %99 radyat&#246;rden.. Peugeotlar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63813&amp;title=su-sesi#63813</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=81">hasimayaz</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:16<br /><br /><P>Sorun %99 radyatörden.. Peugeotlar sudakihavayı otomatik olarak alır. ama radyatör veya hortum tıkanmaları sese sebebiyet verebilir. Ayrıca aracında kırmızı antifriz kullanmalısın yoksa yeşil antifriler bizim araçlarda ciddi korozyon sıkıntılarına sebebiyet verebiliyor.</P><P>Aracında su seviyesi için sensör var. Tehlikeli miktarda eksilme olursa stop uyarısı ve sesi verecektir. Bence sıkıntı edilecek bir şey değil.</P>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:16:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63813&amp;title=su-sesi#63813</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi :    206Quick Yazd&#305;:valla bi ustaya...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63808&amp;title=su-sesi#63808</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=2">Guests</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:13<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: 206Quick" alt="Orjinalini yazan: 206Quick" style="vertical-align: text-bottom;" /> <strong>206Quick Yazdı:</strong><br /><br />valla bi ustaya gösterdim soguk havada normal dedi bilemiyorum</td></tr></table><br><br><font color="#990000"><u><i><b>Yakıtla çalışan bir araçta su sesi duymak tehlike demektir.Arkadaşım daha detaylı bilgi verirsen yardımcı olabilirim.</b></i></u></font><br>]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:13:01 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63808&amp;title=su-sesi#63808</guid>
  </item>
  <item>
   <title><![CDATA[Su sesi : 206 qu&#305;k kulalnan arkada&#351;larada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63803&amp;title=su-sesi#63803</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=8">sinan-s</a><br /><strong>Konu:</strong> 4359<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Aralık&nbsp;2008 Saat 14:06<br /><br />206 quık kulalnan arkadaşlarada sormak lazım.Onlar yaşamışlar mı böle bişi..Görünce konuyu yazarlar buraya]]>
   </description>
   <pubDate>Mon, 29 Dec 2008 14:06:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=4359&amp;PID=63803&amp;title=su-sesi#63803</guid>
  </item>
 </channel>
</rss>
