 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Yakit sorunu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Yakit sorunu]]></description>
  <pubDate>Fri, 01 May 2026 23:34:59 +0000</pubDate>
  <lastBuildDate>Thu, 22 Dec 2016 11:33:20 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=43366</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Yakit sorunu : Cevaaaappppppp ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576100&amp;title=yakit-sorunu#576100</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18966">ahmettartan</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Aralık&nbsp;2016 Saat 11:33<br /><br />Cevaaaappppppp]]>
   </description>
   <pubDate>Thu, 22 Dec 2016 11:33:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576100&amp;title=yakit-sorunu#576100</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : Haa bi de lpg hoturtumlar&#305; da...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576098&amp;title=yakit-sorunu#576098</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18966">ahmettartan</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Aralık&nbsp;2016 Saat 11:21<br /><br />Haa bi de lpg hoturtumları da değişti]]>
   </description>
   <pubDate>Thu, 22 Dec 2016 11:21:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576098&amp;title=yakit-sorunu#576098</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : Ayn&#305; sorun ben de de var 2004...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576097&amp;title=yakit-sorunu#576097</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18966">ahmettartan</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Aralık&nbsp;2016 Saat 11:20<br /><br />Aynı sorun ben de de var 2004 model 1.6 otomatik 307<br /><br />Benimki 62krş yalkıyor çıldıracağım...<br />Lpg Beyin değişti bujiler değişti. Sübaplar değişti termostat değişti radyatör değişti ama hala düzelmedi... Bi yardım bi fikir....]]>
   </description>
   <pubDate>Thu, 22 Dec 2016 11:20:52 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=576097&amp;title=yakit-sorunu#576097</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : Baska akil verebilecek kimse var...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575148&amp;title=yakit-sorunu#575148</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18901">Emrebbr</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Aralık&nbsp;2016 Saat 20:22<br /><br />Baska akil verebilecek kimse var mi arkadaslar]]>
   </description>
   <pubDate>Mon, 05 Dec 2016 20:22:23 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575148&amp;title=yakit-sorunu#575148</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : Lpg regulatoru degismis ondan...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575118&amp;title=yakit-sorunu#575118</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18901">Emrebbr</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Aralık&nbsp;2016 Saat 13:11<br /><br />Lpg regulatoru degismis ondan bi sikinti olabilir mi ?<span style="font-size:10px"><br /><br />Düzenleyen Emrebbr - 05&nbsp;Aralık&nbsp;2016 Saat 20:10</span>]]>
   </description>
   <pubDate>Mon, 05 Dec 2016 13:11:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575118&amp;title=yakit-sorunu#575118</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu :   Emrebbr Yazd&#305;:Arkadaslar herkese...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575090&amp;title=yakit-sorunu#575090</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17876">x571</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Aralık&nbsp;2016 Saat 09:14<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Orjinalini yazan: Emrebbr" alt="Orjinalini yazan: Emrebbr" style="vertical-align: text-bottom;" /> <strong>Emrebbr Yazdı:</strong><br /><br />Arkadaslar herkese merhaba, ben yaklasik iki ay once 2000 model otomatik 206 xt aldim,aracim lpgli ancak km de yaklasik 40 kurus yakiyor (70 tl gaz=160km) araca sibop ayari yapildi,hava filtresi ve bujiler degisti,lpg hortumlari degisti lpg ayari yapildivs ancak bir turlu yakiti dusuremedim benzin gostergesi bozuk oldugu icin benzinde hiz deneme sansim olmadi,sanzimani iyi durumda,bu araclarda bu yakit normal midir, manuellerde 22-25 krs arasi otomatikte 30-35 krs olmasi gerekir diye dusunuyorum , bu sorunu yasayip cozen veya bilen varsa, bilgi verirse sevinirim.tesekkurler</td></tr></table><br><br>nissan pikap gibi yakıyor seninki. ben yazın lpg 2.3 iken hesaplamıştım km ye&nbsp; 15-16 krş yakıyordu. lpg de montaj çok önemli.o kadar şey değişip hala sonuç alınamadıysadandik montaj olabilir.<br>]]>
   </description>
   <pubDate>Mon, 05 Dec 2016 09:14:04 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575090&amp;title=yakit-sorunu#575090</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : 40 kuru&#351; &#231;ok hocam bende 307 var...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575086&amp;title=yakit-sorunu#575086</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17937">conywolker</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Aralık&nbsp;2016 Saat 00:13<br /><br />40 kuruş çok hocam bende 307 var 2.25 civarı lpg fiyatı burda şuanda Ankaradayım ayrıca, 80 90 TL ye 380-400 km yol yapıyorum,<div>yazın aynı fiyatlara 420-440 km oluyor bu şehir içi 1.6 16V 110bg aracım</div><div><br></div><div>40 kuruş aşırı yüksek bir rakam senin mak. 25 kuruş olur diye düşünüyorum</div>]]>
   </description>
   <pubDate>Mon, 05 Dec 2016 00:13:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575086&amp;title=yakit-sorunu#575086</guid>
  </item> 
  <item>
   <title><![CDATA[Yakit sorunu : Arkadaslar herkese merhaba, ben...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575085&amp;title=yakit-sorunu#575085</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18901">Emrebbr</a><br /><strong>Konu:</strong> 43366<br /><strong>Gönderim Zamanı:</strong> 05&nbsp;Aralık&nbsp;2016 Saat 00:09<br /><br />Arkadaslar herkese merhaba, ben yaklasik iki ay once 2000 model otomatik 206 xt aldim,aracim lpgli ancak km de yaklasik 40 kurus yakiyor (70 tl gaz=160km) araca sibop ayari yapildi,hava filtresi ve bujiler degisti,lpg hortumlari degisti lpg ayari yapildivs ancak bir turlu yakiti dusuremedim benzin gostergesi bozuk oldugu icin benzinde hiz deneme sansim olmadi,sanzimani iyi durumda,bu araclarda bu yakit normal midir, manuellerde 22-25 krs arasi otomatikte 30-35 krs olmasi gerekir diye dusunuyorum , bu sorunu yasayip cozen veya bilen varsa, bilgi verirse sevinirim.tesekkurler]]>
   </description>
   <pubDate>Mon, 05 Dec 2016 00:09:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43366&amp;PID=575085&amp;title=yakit-sorunu#575085</guid>
  </item> 
 </channel>
</rss>
