 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 206 turbo</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : 206 turbo]]></description>
  <pubDate>Sat, 02 May 2026 10:24:59 +0000</pubDate>
  <lastBuildDate>Fri, 11 Nov 2016 10:27:17 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=43220</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[206 turbo : rica ederim mert payla&#351;&#305;m&#305;n&#305; bekleriz....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573858&amp;title=206-turbo#573858</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 11&nbsp;Kasım&nbsp;2016 Saat 10:27<br /><br />rica ederim mert paylaşımını bekleriz.&nbsp;]]>
   </description>
   <pubDate>Fri, 11 Nov 2016 10:27:17 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573858&amp;title=206-turbo#573858</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : Tamam abi &#231;ok te&#351;ekk&#252;r ederim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573819&amp;title=206-turbo#573819</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18235">mrtttt53</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 17:36<br /><br />Tamam abi çok teşekkür ederim 0 almak en mantıklısı gibi dediğine de kesinlikle dikkat edeceğim.En geç 1 2 ay içinde yaptıracagm resimde çekebilirsem burda paylaşırım.]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 17:36:59 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573819&amp;title=206-turbo#573819</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : yok mert hat&#305;rlad&#305;&#287;&#305;m kadar&#305;yla...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573818&amp;title=206-turbo#573818</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 17:30<br /><br />yok mert hatırladığım kadarıyla kkk ve garret turbo firmaları &nbsp;ford ve peugeot firmlarına turbo tedariği yapan firmlar olacaktı. ikinci el konusunda gelince sahibinden bak bi vardır kesinlikle. bu arada turbo değişimi yapıldıktan sonra araç hemen çalıştırılmamalı yağ ve filtreler değiştirilmelidir. turbo hortumları ve içleri temizlendikten sonra araç yağ bakımı yapılmalı ve araç öyle çalıştırılmalıdır. bazı ustlar hemen marşa basar ve sıfır tubonun kısa sürede bozulmasına sebep olabilir.kısacası tubo hortumları temizlenmesi gerekir.<span style="font-size:10px"><br /><br />Düzenleyen sonerkyl - 11&nbsp;Kasım&nbsp;2016 Saat 10:26</span>]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 17:30:54 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573818&amp;title=206-turbo#573818</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : Abi bu kkk yansanayi de&#287;il mi?2....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573817&amp;title=206-turbo#573817</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18235">mrtttt53</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 17:09<br /><br />Abi bu kkk yansanayi değil mi?<br />2. El satsam ne civarda eder piyasasını biliyor musun?]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 17:09:45 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573817&amp;title=206-turbo#573817</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : 800 tl fiyat var nette tamir i&#351;i...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573813&amp;title=206-turbo#573813</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 16:26<br /><br />800 tl fiyat var nette tamir işi pek belli olmuyor mert malesef kimi yıllarca kullanıyor kimisi 1 yıl içinde tekrar arıza yapıyor. şans işi ikinci el olarak satabilirsin tabikide her malın alıcısı vardır. uygun verdikten sonra&nbsp;<div><br></div><div>http://www.peugeotmarket.com/PEUGEOT-207-14-HDI-TURBO-KKK,PR-3549.html</div>]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 16:26:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573813&amp;title=206-turbo#573813</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : Abi tamire 500 600 civar&#305; tutar...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573812&amp;title=206-turbo#573812</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18235">mrtttt53</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 16:15<br /><br />Abi tamire 500 600 civarı tutar diye fiyat aldım.Orjinal turboya 900 1000tl fiyat veriyolar üstüne bir de işciligi borusu var.<br /><br />Orjinali alsam tamir edilebilir turboyu çöpe atmak saçma gibi geliyor acaba 2. El satmak mümkün müdür eskisini?]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 16:15:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573812&amp;title=206-turbo#573812</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : mert tamiri yap&#305;l&#305;yor oda 400-500...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573811&amp;title=206-turbo#573811</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 15:18<br /><br />mert tamiri yapılıyor oda 400-500 tl civarlarında yapıyorlar genelde. orjinali 800 tl civarında olacaktı maddi açıdan sıkıntı yok diyorsan 200-300 tl verip sıfırını almak daha mantıklı tabi. birde turbo patlamasını bekleme başka sıkıntılar çıkarabilir karşına&nbsp;]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 15:18:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573811&amp;title=206-turbo#573811</guid>
  </item>
  <item>
   <title><![CDATA[206 turbo : Selam arkada&#351;lar 134binde ald&#305;&#287;&#305;m...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573810&amp;title=206-turbo#573810</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18235">mrtttt53</a><br /><strong>Konu:</strong> 43220<br /><strong>Gönderim Zamanı:</strong> 10&nbsp;Kasım&nbsp;2016 Saat 14:55<br /><br />Selam arkadaşlar 134binde aldığım 206ımı 160bine getirdim aldığımdan beri turbo ötüyor ancak son zamanlarda sesi daha bir arttı ki çekişte düşmeye başladı, yokuşlarda belirgin olarak tıkanmaya başladı vitesi 2ye düşürmem gerekiyor artık önceden böyle değildi, yakıt tüketimini pek ölçemedim az da olsa artmış olabilir.<br />Hep gittigim usta sökelim tamire yollayalm diyor, yeni turbo almayı düşündüm ancak orjinali çok pahalı, bir de boruları var borularda ucuz degil.<br />Turbo tamamen ömrünü doldurmadan tamir ettirip gereken boruları orjinalle değiştirmek mi mantıklı ya da genelde söylendiği gibi turbo patlasın yaptırrız mantığı mı doğrudur &#128513;<br />Tavsiyeniz nedir? ]]>
   </description>
   <pubDate>Thu, 10 Nov 2016 14:55:44 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43220&amp;PID=573810&amp;title=206-turbo#573810</guid>
  </item>
 </channel>
</rss>
