 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : 407 Çekiş Sorunu</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : 407 Çekiş Sorunu]]></description>
  <pubDate>Sun, 03 May 2026 17:41:07 +0000</pubDate>
  <lastBuildDate>Mon, 17 Oct 2016 15:45:57 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=43084</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[407 Çekiş Sorunu :  gaz kelebe&#287;ine bak&#305;lmad&#305; ama...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572732&amp;title=407-cekis-sorunu#572732</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17140">Bilgili42</a><br /><strong>Konu:</strong> 43084<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2016 Saat 15:45<br /><br />gaz kelebeğine bakılmadı ama usta ondan yapmaz dedi bunların üstünde 2 adet gaz kelebeği var biri kullanılan biri yedek soketi çıkarsam yedegemi taksam<div></div>]]>
   </description>
   <pubDate>Mon, 17 Oct 2016 15:45:57 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572732&amp;title=407-cekis-sorunu#572732</guid>
  </item>
  <item>
   <title><![CDATA[407 Çekiş Sorunu : peki gaz kelebe&#287;ine bak&#305;ld&#305;m&#305;....]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572703&amp;title=407-cekis-sorunu#572703</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43084<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2016 Saat 11:16<br /><br />peki gaz kelebeğine bakıldımı.&nbsp;]]>
   </description>
   <pubDate>Mon, 17 Oct 2016 11:16:40 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572703&amp;title=407-cekis-sorunu#572703</guid>
  </item>
  <item>
   <title><![CDATA[407 Çekiş Sorunu :  Turbo Hortumlar&#305; Kontrol edildi...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572701&amp;title=407-cekis-sorunu#572701</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17140">Bilgili42</a><br /><strong>Konu:</strong> 43084<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2016 Saat 11:08<br /><br />Turbo Hortumları Kontrol edildi&nbsp; mazotu değiştirdim pek bi fark yok ]]>
   </description>
   <pubDate>Mon, 17 Oct 2016 11:08:31 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572701&amp;title=407-cekis-sorunu#572701</guid>
  </item>
  <item>
   <title><![CDATA[407 Çekiş Sorunu : &#246;ncelikle mazot filtresini bak&#305;n...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572695&amp;title=407-cekis-sorunu#572695</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 43084<br /><strong>Gönderim Zamanı:</strong> 17&nbsp;Ekim&nbsp;2016 Saat 10:32<br /><br />öncelikle mazot filtresini bakın yakıtla alakalı bir durumda olabilir. turbo hortumları ve contalarınıda kontrol ettilermi. .<span style="font-size:10px"><br /><br />Düzenleyen sonerkyl - 17&nbsp;Ekim&nbsp;2016 Saat 10:45</span>]]>
   </description>
   <pubDate>Mon, 17 Oct 2016 10:32:21 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572695&amp;title=407-cekis-sorunu#572695</guid>
  </item>
  <item>
   <title><![CDATA[407 Çekiş Sorunu :  Herkese merhaba arkada&#351;lar.&#214;nceden...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572649&amp;title=407-cekis-sorunu#572649</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17140">Bilgili42</a><br /><strong>Konu:</strong> 43084<br /><strong>Gönderim Zamanı:</strong> 16&nbsp;Ekim&nbsp;2016 Saat 12:03<br /><br />Herkese merhaba arkadaşlar.<div>&nbsp;</div><div>Önceden aracım kalkışlarda cok seriydi&nbsp; bi antalyaya gidip geldim aracımın çekişi resmen gitti.</div><div>&nbsp;</div><div>araba gaz tepkimesi çok düştü yokuşlarda bayılıp kalıyor sollamaya bile çıkmıyorum.</div><div>&nbsp;</div><div>1 hafta öncesinden baskı balata değiştirdim.</div><div>dün servise gittim akışmetre kontrol edildi enjektörler söküldü,egr iptal edildi sonuç hüsran&nbsp;araç yine gitmiyor bir bakmadığımız turbo kaldı ne yapacağımı sasırdım. </div><div>&nbsp;</div><div>yardımlarınızı bekliyorum.</div>]]>
   </description>
   <pubDate>Sun, 16 Oct 2016 12:03:36 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=43084&amp;PID=572649&amp;title=407-cekis-sorunu#572649</guid>
  </item>
 </channel>
</rss>
