 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : Hız göstergesi</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 206 : Hız göstergesi]]></description>
  <pubDate>Sat, 02 May 2026 13:06:39 +0000</pubDate>
  <lastBuildDate>Sat, 24 Sep 2016 22:26:38 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=42955</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[Hız göstergesi : Hiz gostergesinin arkasinda minik...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571791&amp;title=hiz-gostergesi#571791</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18169">TooJohn</a><br /><strong>Konu:</strong> 42955<br /><strong>Gönderim Zamanı:</strong> 24&nbsp;Eylül&nbsp;2016 Saat 22:26<br /><br />Hiz gostergesinin arkasinda minik motor var bu motoru hareket ettiren carklari sabit tutan tirnagin kirilmasi sonucu hiz gostergesi calismayabiliyor.<br />Bu ariza icin sanzuman indirmemiz lazim abi diyen adina usta demek istemedigim insanlarla tanistim.<br /><br /><span style="font-size:10px"><br /><br />Düzenleyen TooJohn - 24&nbsp;Eylül&nbsp;2016 Saat 22:49</span>]]>
   </description>
   <pubDate>Sat, 24 Sep 2016 22:26:38 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571791&amp;title=hiz-gostergesi#571791</guid>
  </item>
  <item>
   <title><![CDATA[Hız göstergesi : ayn&#305;s&#305; benim de ba&#351;&#305;ma geldi&#246;ncelikle...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571590&amp;title=hiz-gostergesi#571590</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=15673">talip206</a><br /><strong>Konu:</strong> 42955<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Eylül&nbsp;2016 Saat 13:39<br /><br />aynısı benim de başıma geldi<br />öncelikle  göstergenin şapka kısmını çıkartın. Kendinize ve aşağı doğru çekerseniz çıkar. Daha sonra gösterge camını çıkarın çok kolay çıkar. gösterge ibresi kendinize doğru çekip tekrar oturun. camı takmadan test sürüşüne çıkın. duruma göre olmazsa tekrar bastirin kendinize doğru çekin iyice yerine takilinca düzelir. ben 3 4 defa deneyerek tutturdum. Bu anlattıklarım 206 için geçerli tabi. Bilgi kısmında araç bilgilerini girmediginiz için 206 diye tahmin ediyorum. <span style="font-size:10px"><br /><br />Düzenleyen talip206 - 19&nbsp;Eylül&nbsp;2016 Saat 13:41</span>]]>
   </description>
   <pubDate>Mon, 19 Sep 2016 13:39:33 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571590&amp;title=hiz-gostergesi#571590</guid>
  </item>
  <item>
   <title><![CDATA[Hız göstergesi : Hocam sens&#246;rdende yapabilir. G&#246;sterge...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571577&amp;title=hiz-gostergesi#571577</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=14237">Cyrus35</a><br /><strong>Konu:</strong> 42955<br /><strong>Gönderim Zamanı:</strong> 19&nbsp;Eylül&nbsp;2016 Saat 08:20<br /><br />Hocam sensördende yapabilir. Gösterge motorunun çarkında da problem olabilir önce kesin teşhisi koymak lazım boşa masraf yapmamak için ilk olarak bi km tamircisine giderek en düşük yoldan bi km motorunu gösterebilirsiniz gösterge panelinin sökülmesi çok basit bir işlem zaten.]]>
   </description>
   <pubDate>Mon, 19 Sep 2016 08:20:15 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571577&amp;title=hiz-gostergesi#571577</guid>
  </item>
  <item>
   <title><![CDATA[Hız göstergesi : H&#305;z g&#246;stergesi uzun zamand&#305;r bozuk...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571560&amp;title=hiz-gostergesi#571560</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18602">Voltrantürk</a><br /><strong>Konu:</strong> 42955<br /><strong>Gönderim Zamanı:</strong> 18&nbsp;Eylül&nbsp;2016 Saat 23:15<br /><br />Hız göstergesi uzun zamandır bozuk daha doğrusu 120km yapsam dahi 90da takılı kalıyor conta yaktıktan sonra oluştu çözümü ve masrafı ne olur şimdiden teşekkür ederim ]]>
   </description>
   <pubDate>Sun, 18 Sep 2016 23:15:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42955&amp;PID=571560&amp;title=hiz-gostergesi#571560</guid>
  </item>
 </channel>
</rss>
