 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : motor titreme</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 407 : motor titreme]]></description>
  <pubDate>Fri, 01 May 2026 21:33:12 +0000</pubDate>
  <lastBuildDate>Tue, 30 Aug 2016 10:47:14 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=42834</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[motor titreme : Te&#351;ekk&#252;r ederim ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570695&amp;title=motor-titreme#570695</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18494">zekai</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ağustos&nbsp;2016 Saat 10:47<br /><br />Teşekkür ederim]]>
   </description>
   <pubDate>Tue, 30 Aug 2016 10:47:14 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570695&amp;title=motor-titreme#570695</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : Abi benim de ara&#231; ilk calismada...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570693&amp;title=motor-titreme#570693</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18273">Dlkrn_48</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 30&nbsp;Ağustos&nbsp;2016 Saat 09:33<br /><br />Abi benim de araç ilk calismada baya bir sarsılıyor. Motor ust takozu bitmis degistirdim. Bir nebze etki etti ama sarsinti gecmedi]]>
   </description>
   <pubDate>Tue, 30 Aug 2016 09:33:37 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570693&amp;title=motor-titreme#570693</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : Tesekur ederim ola bilir ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570681&amp;title=motor-titreme#570681</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18494">zekai</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ağustos&nbsp;2016 Saat 20:03<br /><br />Tesekur ederim ola bilir]]>
   </description>
   <pubDate>Mon, 29 Aug 2016 20:03:24 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570681&amp;title=motor-titreme#570681</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : Gaz yemede sikinti yok ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570680&amp;title=motor-titreme#570680</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18494">zekai</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ağustos&nbsp;2016 Saat 20:01<br /><br />Gaz yemede sikinti yok ]]>
   </description>
   <pubDate>Mon, 29 Aug 2016 20:01:48 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570680&amp;title=motor-titreme#570680</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : Ara&#231; ilk &#231;al&#305;&#351;t&#305;&#287;&#305;nda gaz verdi&#287;inde...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570678&amp;title=motor-titreme#570678</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18273">Dlkrn_48</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ağustos&nbsp;2016 Saat 19:05<br /><br />Araç ilk çalıştığında gaz verdiğinde gazı alıyormu? yoksa gazı yerken de ara ara kesiliyor mu ?]]>
   </description>
   <pubDate>Mon, 29 Aug 2016 19:05:39 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570678&amp;title=motor-titreme#570678</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : motor takozlar&#305; kontrol ettir...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570674&amp;title=motor-titreme#570674</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 29&nbsp;Ağustos&nbsp;2016 Saat 18:07<br /><br />motor takozları kontrol ettir derim hocam]]>
   </description>
   <pubDate>Mon, 29 Aug 2016 18:07:16 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570674&amp;title=motor-titreme#570674</guid>
  </item> 
  <item>
   <title><![CDATA[motor titreme : Arkadaslar herkese selam benim...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570619&amp;title=motor-titreme#570619</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18494">zekai</a><br /><strong>Konu:</strong> 42834<br /><strong>Gönderim Zamanı:</strong> 28&nbsp;Ağustos&nbsp;2016 Saat 11:49<br /><br />Arkadaslar herkese selam benim 2.0 407de motoru ilk calistirmada motor zangir zangir titriyor gaza bastigimda kesiyor bir sure sonra bunu kesiyor sebebi ne ola bilir bunu brc tup taktirdiktan bir ay sonra yapmaya basladi nedeni ne ola bilir birde bunu benzinde biraksam bile yapiyor okadar fazlaki arabayi salliyor resmen servis yolu gorundu herhal..<br /><br /> <img src="https://forum.peugeotturkey.com/smileys/smiley7.gif" border="0" align="middle" /> ]]>
   </description>
   <pubDate>Sun, 28 Aug 2016 11:49:11 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42834&amp;PID=570619&amp;title=motor-titreme#570619</guid>
  </item> 
 </channel>
</rss>
