 <channel>
  <title>Peugeot T&#252;rkiye Forumlar&#305; : klima sıcak ufluyo</title>
  <description><![CDATA[XML içerik bağlantısı; Peugeot T&#252;rkiye Forumlar&#305; : 307 : klima sıcak ufluyo]]></description>
  <pubDate>Mon, 04 May 2026 08:59:53 +0000</pubDate>
  <lastBuildDate>Tue, 23 Aug 2016 00:39:41 +0000</lastBuildDate>
  <ttl>360</ttl>
  <WebWizForums:feedURL>https://forum.peugeotturkey.com/RSS_post_feed.asp?TID=42801</WebWizForums:feedURL>
  <image>
  </image>
  <item>
   <title><![CDATA[klima sıcak ufluyo : Herkeze tesekkur ederim bize yine...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570361&amp;title=klima-sicak-ufluyo#570361</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17886">kirelli</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 23&nbsp;Ağustos&nbsp;2016 Saat 00:39<br /><br />Herkeze tesekkur ederim bize yine usta yolu gorundu ]]>
   </description>
   <pubDate>Tue, 23 Aug 2016 00:39:41 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570361&amp;title=klima-sicak-ufluyo#570361</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : http://forum.peugeotturkey.com/forum_posts.asp?TID=22925 ...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570340&amp;title=klima-sicak-ufluyo#570340</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 17:03<br /><br />http://forum.peugeotturkey.com/forum_posts.asp?TID=22925]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 17:03:20 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570340&amp;title=klima-sicak-ufluyo#570340</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : hocam b&#252;y&#252;k ihtimal y&#246;nlendirme...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570339&amp;title=klima-sicak-ufluyo#570339</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 17:01<br /><br />hocam büyük ihtimal yönlendirme dişlileri sıyırmıştır.&nbsp;<div><br></div><div>http://www.peugeotmarket.com/PEUGEOT-307-KLIMA-YONLERDIRME-DISLI-TAMIR-KITI,PR-1463.html</div>]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 17:01:46 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570339&amp;title=klima-sicak-ufluyo#570339</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : Kontrol dijital ama ]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570337&amp;title=klima-sicak-ufluyo#570337</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17886">kirelli</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 16:40<br /><br />Kontrol dijital ama ]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 16:40:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570337&amp;title=klima-sicak-ufluyo#570337</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : Panel i&#231;indeki di&#351;li s&#305;yr&#305;lm&#305;st&#305;r.so&#287;u&#287;a...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570330&amp;title=klima-sicak-ufluyo#570330</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=18012">Vefa</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 14:32<br /><br />Panel içindeki dişli sıyrılmıstır.soğuğa alsanız bile sıcak üfler 306 da başıma geldi.Kontrol panelini söküp elimizle soğuğa çevirdik düzeldi bi ihtimal öyle olmuş olabilir.]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 14:32:35 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570330&amp;title=klima-sicak-ufluyo#570330</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : klima devreye giriyormu hocam...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570328&amp;title=klima-sicak-ufluyo#570328</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=16073">sonerkyl</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 13:52<br /><br />klima devreye giriyormu hocam çıt diye bir ses gelmesi lazım birde sizin klima kontrol paneli dijitalmi manuelmi.]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 13:52:28 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570328&amp;title=klima-sicak-ufluyo#570328</guid>
  </item>
  <item>
   <title><![CDATA[klima sıcak ufluyo : merhaba arac&#305;m 307 teknoplus klimay&#305;...]]></title>
   <link>https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570327&amp;title=klima-sicak-ufluyo#570327</link>
   <description>
    <![CDATA[<strong>Yazar:</strong> <a href="https://forum.peugeotturkey.com/member_profile.asp?PF=17886">kirelli</a><br /><strong>Konu:</strong> 42801<br /><strong>Gönderim Zamanı:</strong> 22&nbsp;Ağustos&nbsp;2016 Saat 13:42<br /><br />merhaba aracım 307 teknoplus klimayı açtığımda direk olarak sıcak ufluyo klima borularına elledigimde borular soğuk oluyo ama sıcak ufluyo sizce sebebi ne olabilir]]>
   </description>
   <pubDate>Mon, 22 Aug 2016 13:42:43 +0000</pubDate>
   <guid isPermaLink="true">https://forum.peugeotturkey.com/forum_posts.asp?TID=42801&amp;PID=570327&amp;title=klima-sicak-ufluyo#570327</guid>
  </item>
 </channel>
</rss>
